I have an (iOS) device integrated by the official HA Companion app. It provides a battery state sensor storing the Low Power Mode in an attribute.
I want auto-entities to show all entities with state Low Power Mode: true. Unfortunately, auto-entities seems to not being able to handle the “not so precise” naming of this attribute.
E. g. this is working for the default attribute within a normal entities card:
- type: attribute
entity: sensor.phone_battery_state
attribute: 'Low Power Mode'
But with auto-entities nothing is displayed. Doesn’t matter how I write the Low Power Mode. Bug or am I using it wrong?
As for “Low Power Mode” attribute.
In my experience, if some attribute is displayed as “Xxx Yyy Zzz”, that means that it’s actual name is “xxx_yyy_zzz”.
But this particular “Mobile App” integration is smth strange…
Check these templates:
We use templates in Configuration to create template sensors, why not using templates in Frontend?)))
I do not think this is supported…
Every attribute which I have seen is a kind of “xxx_yyy_zzz” - and is presented in UI as “Xxx Yyy Zzz” - let’s call these attributes NORMAL. These attributes from Mobile App are STRANGE (I would call them in Russian by another word - and the whole Mobile App integration is unstable and unreliable, IMHO).
Thank you VERY MUCH! The output is pretty much exactly what I was looking for. Think I need to start using templates in the UI to get even more out of whole HA.
I’m not brave enough to raise an issue for the mobile_app integration but I double what you said - that’s not a ‘normal’ naming convention and it’s from the official app… anyway, auto-entities is working for now
got to love the new integration_entities template options, and a very nice template for auto-entities indeed!
what’s your issue with it? I must confess after having switched over to the mobile app completely, and drop all other trackers, I havent seen an issue in location anymore.
Login is smooth as can be, local and external, and now we even have local notifications
Do you mean “Why do you dislike Mobile App integration”?
It is an off-topic here )))
Because sensors like “battery level” are updating ONLY when I open the Companion App. I got iPad Air 2, iPhone 5S, iPhone 6S+ - all of them have “Background app refresh = ON” option in iOS settings but this does not help. And another issue is that Companion App is too buggy to be used. And one more issue is that iPhone 5S, 6S+ sometimes even cannot open a dashboard, just displaying a white screen. May be the latest iPad & iPhone work smooth.
ok, I see, and yes, its needs some more modern devices than my older iPad Air, on 12.5.5… other than that, I think its really nice, and not buggy at all. but yep off-topic… sorry.
I might be running into an issue while using this auto-entities thingie. I’m using it happily to display all my Shelly’s with an indicator whether or not a software upgrade is available. That works just fine. Since Shelly supports a button-type to OTA update the unit, I thought I might factor that in as a tap-action to these buttons.
Tapping to button to invoke the action displays the confirmation window just nicely with the entity_id of the shelly to be updated. However, it fails with:
Failed to call service button/press. must contain at least one of entity_id, device_id, area_id
If I separate the button from the auto-entities code, it works fine.
I’m using the exact config to only show the mediaplayers (different sonos devices) currently playing. BUT, and here comes the question, how do you give the options used by the entities in this type of card (auto-entities)
Question to be clear : How can I show the media_player AND the artwork in full-cover modus in above script ? artwork: full-cover ← where to put it in the above script ?
But if you are using the default media_player card, there are no additional attributes? If you are using the media player entity, there are no additional attributes here either.
hey all, im still dont understand how to code, but i do learn from examples
Id like to make the lights On into a Folder Entity??
where do i add this code
type: custom:fold-entity-row
head:
type: section
label: Lights On
HOWEVER, when I use Template in the Developer Tools, the result shows the list of all batteries (with %) along with all the sensors that have a battery.
The intention would be to only have to specify the card type once - instead for each entity that is included. I guess I could contruct a regex for entity_id but that would probably not look very nice either.
Idea is to show a list of shelly devices that have a firmware upgrade due and offer the option to upgrade in place. The secondary info, once it displays at all, should show the current and new firmware.
At the bottom of the list (via include) come the remaining shelly devices with the current firmware installed as secondary info.
I understand that I cannot use options: for templates, which would make this easier. Correct?
