šŸ”¹ Auto-entities - Automatically fill cards with entities
Although that does work, I was really hoping for a solution that would allow me to keep the sections as I find that more visually appealing. Thank you for your suggestion, though!
I am not sure but will try to explain.
  1. Lets imagine that the template returns a list if entity_ids.
    One record = one entity.
    These records may be sorted by state, name etc.
  2. The template returns a list of records:
entity: xxxxxxx
Again , each record = entity, they may be sorted.
I do not know how the card knows that THIS IS A LIST OF ENTITIES…
  1. The template returns a list of records:
type: custom:declutterin-card
template: some_template
variables:
  - AAAAAAAA: ....
  - BBBBBBB: ....
Each record cannot be explicitly associated with some entity; in fact, it may represent several entities.
In this case we have to sort in the template itself.
At least I understood. Thanks. This makes sense. Thought before, That with template, the sorting is per Definition ignored. But if it still tries to sort sortable template output, thats great.
Any way to show secondary info with templates (I’d like to see last-changed under each entity without using another card). FYI - I use the template since I have entities in groups in groups:
      - type: custom:auto-entities
        card:
          type: entities
          show_header_toggle: false
          state_color: true
        filter:
          template: >-
            {{ expand(states.group.lights_all) | selectattr('state', 'in',
            ('on', 'open', 'unlocked', 'not_home')) | map(attribute='entity_id')
            | list }}
        sort:
          method: friendly_name
Scroll up a little, there was a link to example. Also, you may use a magical ā€œsearch in threadā€ feature.
Hey all, im still pretty knew, im not a coder and i can figure out most things by looking at examples, but im having trouble trying to excluding automations from my list. Can someone help me out here pls? i know its easy
card:
  type: entities
  title: Doors Currently Open
  state_color: true
filter:
  include:
    - entity_id: '*door*'
      state: 'on'
exclude:
  - domain: automation
sort:
  method: none
show_empty: false
wrong indentation
I have another one
im trying to have auto entities create graphs for my device batteries. im not a coder, what does this error mean
Cannot read properties of undefined (reading ā€˜length’)
card:
  type: entities
  title: Devices Battery Level's
  state_color: false
filter:
  include:
    - entity_id: '*battery_level*'
      options:
        type: custom:mini-graph-card
        hours_to_show: 96
        points_per_hour: 0.4
        animate: true
        align_icon: left
        align_header: left
        upper_bound: 100
        lower_bound: 0
  exclude: []
sort:
  reverse: false
  numeric: true
Wrong.
options - for each entity.
Since you need graphs - why have you specified ā€œtype: entitiesā€?
The right code is (example):
card:
  name: Devices Battery Level's
  hours_to_show: 24
  points_per_hour: 60
  align_icon: left
  align_header: left
  lower_bound: 0
  line_width: 1
  show:
    fill: false
    labels: true
filter:
  include:
    - entity_id: sensor.battery_*
I have card like this:
card:
  type: entities
  state_color: true
  title: Presence OFF
filter:
  include:
    - name: presence_*
      options:
        secondary_info: last-updated
      state: 'off'
  exclude: []
sort:
  method: last_updated
  numeric: true
  reverse: true
This shows me ā€œdeadā€ or missing devices on my network. But some of my devices are long-term off and I am fine with it, but don’t want to remove them. Usually the way to detect this is that their last update is the same as date of last HA start.
I have added input_datetime helper that gets stored current datetime 2 minutes after start of HA.
I would like to add additional filtration to this card where if it’s attribute last-updated < my stored value it is not shown.
I am struggling to get it working and I am not sure if that is even possible.
It should be somehow like this …
{{ as_timestamp(states('input_datetime.last_boot_timestamp')) | int > last-updated }}
{{ as_timestamp(states('input_datetime.last_boot_timestamp')) | int }}
… but it did not work for me.
I would appreciate suggestions. Thanks.
you can template card options with custom:config-template-card which embeds your full config you posted here and allows to input a template as you like it to be
Thank you for your answer. I had a look at config-template-card but I fail to see how to do that. The documentation seems a bit sparse. It seems like the entities that are watched must be explicitly stated, but my list needs to come from auto-entities.
I really need just to add another filter to auto-entities.
If you could give some example it would be greatly appreciated.
Thank you.
well, that scenario (auto-entities filling a config-template-card) has just been added as a FR by me in the repo…
other than that, I thought you wanted to template some of the cards options (not the entities), and that is quite possible.
would you know of a way to have an auto-entities filled grid card with custom:button-cards with a template filter?
I have made the confg with auto-entities and a fixed filter set, (where the button-card is used in the options: field) but can not make it happen using a filter: template (because that wont accept options…)
I do hope I make a user error. but believe I tried it all…
      card:
        type: grid
        title: Test Icon color Buttons
        columns: 4
      card_param: cards
      filter:
        include:
          - entity_id: sensor.*_actueel
            options:
              type: custom:button-card
              aspect_ratio: 1/1
              show_state: true
              template: support_custom_ui
        exclude:
          - state: '<20'
      sort:
        method: state
        numeric: true
and this wrks too:
        card:
          type: entities
          card_mod: &mod
            style: |
              ha-card {
                box-shadow: none;
                margin: -16px -16px 0px -16px;
        filter:
          template: >
            {% set threshold = states('input_number.power_threshold')|float(0) %}
            {% set ns = namespace(above_threshold=[]) %}
            {% for s in states.sensor
             |selectattr('entity_id','search','_actueel')
             if s.state|float(0) > threshold %}
            {% set ns.above_threshold = ns.above_threshold + [s.entity_id] %}
            {% endfor %}
            {{ns.above_threshold}}
        sort:
          method: state
          numeric: true
works fine, but replacing the
      filter:
        include:
with the template from the second example doesnt work, because we can no longer set options in that case…
hope you see what I am missing
why, because i literally have no idea what im doing lol i dont know code, its trial an error for atm
I was hoping that each battery would have its own graph card not all battery devices on the one graph.
card:
  type: vertical-stack
card_param: cards
filter:
  include:
      options:
        entities:
          - this.entity_id
Thanks for helping :slight_smile:
This is what i have and now this error??
The ā€œentityā€ option was removed, please use ā€œentitiesā€
card:
card_param: cards
filter:
  include:
      options:
        entities:
          - this.entity_id
I do not see any errors:
Bugger! This is what i see.
@Mariusthvdb
    card:
      type: grid
      columns: 4
    card_param: cards
    filter:
      template: >-
        {% set threshold = states('input_number.test_number')|float(0) -%} {%-
        for s in states.sensor|selectattr('entity_id','search','battery_')
           if s.state|float < threshold -%}
              'type': 'custom:button-card',
              'entity': s.entity_id,
              'aspect_ratio': '1/1',
              'show_state': 'true'
        {%- endfor %}
    sort:
      method: state
      numeric: true
