Hello all,
Iām strugling with list of tasmota devices.
it is possible to create hyperlink from list with ip?
tap_action:
action: url
url_path: this.entity_id
Hello all,
tap_action:
action: url
Happy Bew Year to you! Iāll give it a go tomorrow. Thanks for your help
only now starting with dark mode, I stumble upon this issue of not being able to set options for it using the auto-entities card with Map. Filed (edit: and closed, see below) an issue in the repo options not functional on Map card Ā· Issue #241 Ā· thomasloven/lovelace-auto-entities Ā· GitHub but thought it might be good to post/ask here too:
- type: custom:auto-entities
card:
type: map
show_empty: false
filter:
include:
- domain: person
options:
hours_to_show: 48
dark_mode: true
not:
state: home
card works fine, with the exception of the options, which are simply not applied.
please have a look? thanks!
EDIT
o dear, how stupid of me. this is all there is to it:
card:
type: map
hours_to_show: 48
dark_mode: true
nvm me.
Yes, these are card-wide options.
new challengeā¦
replace:
filter:
include:
- entity_id: sensor.*_actueel
state: '>30'
with a state following an input_number.power_threshold
filter:
include:
state: '> input_number.power_threshold' # or states('input_number.power_threshold')
would be awesome ofc (like we can do with numeric state triggers, but I believe we need to use the template option, which is still a bit more complexā¦
anyone with a quick fix, that doesnt iterate over all states|sensor ?
hi i try to make a card with a tap action. The tap action need a id that is in the attribute of the sensor.
{{state_attr("this.entity_id", "id")}}
how can i do this?
This code dont work - it works if i insert 1 instead of ā{{state_attr(āthis.entity_idā, āidā)}}ā, but the id is different for every one of the sensores.
card:
show_header_toggle: false
title: Fryser
type: entities
filter:
include:
- entity_id: sensor.*template_grocy_stk_*
options:
tap_action:
action: call-service
service: grocy.consume_product_from_stock
service_data:
product_id: '{{state_attr("this.entity_id", "id")}}'
amount: 1
transaction_type: CONSUME
exclude:
- state: unavailable
sort:
method: state
numeric: true
reverse: true
I do not think that product_id supports templates. Also, this.entity_id is not supposed to be used in quotes.
ok do you have any idea how i can do this with auto entities?
Use ātemplateā option of the card.
i have tryed this and a lot more
service_data:
product_id:
template: '{{state_attr("this.entity_id", "id")}}'
amount: 1
but this dont work. how would you do it?
Does the āproduct_idā option has a ātemplateā option?
I guess - NO.
Use only options accordingly to Docs.
Earlier I advised to use a ātemplateā option of āauto-entitiesā card. This option allows to specify lists by using jinjia.
maybe this is an option, but i dont know about jinjia. could you please help?
Is there a way to template options? Or anyone has any other idea?
Instead of changing my entity name, I only want to change the name, which is displayed.
So instead of āabc Rssi Deviceā the rows should only display āabcā.
I thought about
options:
type: custom:multiple-entity-row
secondary_info: last-changed
show_state: false
{{ states('this.entity_id') }}
entities:
- entity: this.entity_id
and then have some jinja2 instead of the states() above. This here was only for test purposes, if I can template, but this seems to be not the case?
Possible with auto-entities::template option.
Is there any documentation or example? Found only the filter template in docs.
Kind of this code
The template produces a list of records (entities + options).
Also, you may try (just a guess) with template-entity-row since you need to change names.
One issue I am trying to solve is the issue with HA setting the last_changed value of all sensors on HA restart. I have a card that shows sensors that have changed in XX minutes and it works great EXCEPT after a server restart and all the sensors show back up. I would like to add an exclude filter like this:
{%- if as_timestamp(states('sensor.time_online')) < (as_timestamp(state.last_changed) - 60 ) -%}
Reason for the 60 is that the last_changed date does not match the time online exactly but they seem to always be within 60 seconds.
Since you can not use a template within the exclude, is there another way to accomplish this? Note I did just try make a filter template that does produce what I want but it seems to only update once or twice a minute which is a bit slow.
Aaah. No I thnik I understood it already better. I will template all this then including row-type, options. etc. Thought before, that I only template the entity list and everyting else apply as before if I would use include instead.
And after reading a lot of your posts in the past, I thing with that I will get the same sorting problems, etc. as you had before. So I will switch to template-entity-row in this usecase.
But some questions around another example from you above:
cards:
- type: 'custom:auto-entities'
card:
type: entities
title: Batteries
style: |
ha-card .card-content {
padding-bottom: 0px !important;
entities:
- type: button
icon: 'mdi:blank'
action_name: Full list
tap_action:
action: navigate
navigation_path: /lovelace/battery
unique: entity
show_empty: true
filter:
template: >
{% set WARNING_LEVEL = states('input_number.battery_level_check')|float
-%} {%- set batteries = expand('group.batteries') -%} {%- for battery in
batteries -%}
{%- set LEVEL = states(battery.entity_id)|float -%}
{%- if LEVEL <= WARNING_LEVEL -%}
{ 'entity': battery.entity_id,
'secondary_info': 'last-changed',
'style': ':host { {%- if states(config.entity) == "unknown" -%}
--paper-item-icon-color: brown;
{%- elif states(config.entity)|float <= states("input_number.battery_level_critical") | float -%}
--paper-item-icon-color: red;
{%- elif states(config.entity)|float <= states("input_number.battery_level_warning") | float -%}
--paper-item-icon-color: rgb(250,218,67);
{%- else -%}
--paper-item-icon-color: green;
{%- endif %} }'
{%- endif -%}
{%- endfor -%}
sort:
method: state
reverse: false
ignore_case: false
attribute: null
first: 0
count: 1000
numeric: true
There is still the sort part. Why?
Did you ever find a solution for this? I currently have the following card set up:
title: Docker
icon: mdi:docker
cards:
- type: 'custom:vertical-stack-in-card'
cards:
- type: glance
entities:
- entity: sensor.docker_local_containers_total
- entity: sensor.docker_local_images
- entity: sensor.docker_local_version
title: Docker on NUC
card:
type: entities
entities:
- type: section
label: Not running
filter:
include:
- entity_id: "sensor.docker_local_*"
not:
state: "running"
exclude:
- name: "Docker local *"
show_empty: false
card:
type: entities
entities:
- type: section
label: High cpu usage
filter:
include:
attributes:
1cpu_percentage: ">= 5"
options:
type: custom:template-entity-row
state: "{{ state_attr('this.entity_id', '1cpu_percentage') }} %"
show_empty: false
sort:
method: attribute
attribute: 1cpu_percentage
reverse: true
card:
type: entities
entities:
- type: section
label: High memory usage
filter:
include:
attributes:
memory: ">= 1024"
options:
state: "{{ state_attr('this.entity_id', 'memory') | int }} MB"
show_empty: false
sort:
method: attribute
attribute: memory
reverse: true
This results in the following card:
I would like the empty sections to be hidden but show_empty: false
doesnāt work, because the sections themselves make the cards not empty.
Not sure if this is the answer, but this is what I do:
show_empty: false
card:
type: entities
title: Devices Down
