The method:
property is Required for sorting.
of courseā¦ sorry I missed that. Still, no sure Im doing it as it should now:
- type: custom:auto-entities
card:
type: entities
title: All Scripts auto
show_header_toggle: false
filter:
include:
- domain: script
options:
secondary_info: last-triggered
sort:
method: attribute
attribute: last_triggered
reverse: true
it does make a difference, but is not consistent over the full list:
the scripts which havenāt been triggered yet donāt show a secondary_info line, do they cause havoc? Why are they not listed at the bottom ?
That may very well be the problem. last_triggered
is a rather new feature which I havenāt looked into yet, but since Itās a timestamp I imagine it should require some special treatmentā¦
sure, I made the PR for showing it on Lovlace-cards secondary_info in the first placeā¦
Just now added the ābugā discussion to add a āneverā on that row if not yet triggered: https://github.com/home-assistant/home-assistant-polymer/issues/4428
awaiting that, do you have any suggestions for the order in this auto-card? Could I maybe only show the last 5 last_triggered entities by adding count: 5, to prevent constant re-rendering of the view?
please let me put forward another challenge I canāt find the solution for yet. Id like to auto create a card with all views to be able to create a āCastā card. I now have this manually setup:
- type: entities
title: Cast Control
entities:
- type: cast
view: 'home'
- type: cast
view: 'home_assistant'
- type: cast
view: 'lights'
I can add all 23 tabs (ā¦) of course, but couldnāt I somehow use the auto-entities card to create this. Simply follow the setup in ui-lovelace.yaml, and read the title (name) and path (view) into this cardā¦
edit probably no, since these arenāt entitiesā¦maybe something like lovelace_gen could do thisā¦
Hi there,
Iām trying to use auto-entities,layout-card and the button card to show lights as buttons if they are on.
It works like a charm but I like to put a header over the buttons (e.g. markdown card). I set the parameter show_empty:false in auto-entities-card. If there are no lights on, the auto-entities-card is not shown. But how could I hide a the header?
Example:
- type: vertical-stack
cards:
- type: markdown
content: '#### Eingeschaltete Lampen'
show_empty: false
filter:
include:
- domain: light
state: "on"
options:
type: custom:button-card
entity_id: this.entity_id
card:
type: custom:layout-card
layout: horizontal
min_columns: 3
struggling with the exclude of an attribute to be unavailable, please help me how I should code it in the auto-entities config:
card:
type: entities
title: Multiple lights
filter:
include:
- domain: light
options:
type: custom:multiple-entity-row
entity: this.entity_id
toggle: true
primary:
attribute: brightness
unit: '%'
secondary:
attribute: color_temp
tertiary:
attribute: rgb_color
info:
exclude:
- attributes:
color_temp: unavailable
everything works, up to the excludeā¦ Shows all of my lights, with the 3 attributes.
Of course I will create two configs, 1 for color_temp and one for rob_color, but for now this is an exercise.
I can use the template filter to do this:
{%- for light in states.light %}
{%- if light.state == "on" and light.attributes.color_temp != unavailable %}
{{ light.entity_id}},
{%- endif %}
{%- endfor %}
but because of the mentioned caveat (no auto reload) I donāt wat to use that.
Please have a look what I should do? thanks!
update
once you know what to look for, things get nice:
card:
type: entities
filter:
include:
- domain: light
state: 'on'
attributes:
rgb_color: '! none'
options:
toggle: true
secondary_info: last-changed
primary:
unit: '%'
secondary:
- domain: light
state: 'on'
attributes:
color_temp: '! none'
options:
toggle: true
primary:
unit: '%'
secondary:
thanks Thomas and @benct for creating 2 magical cards working together!
Hi! Is it possible to support expanding a light group in to the component entities? Liek you do with group, but with light group.
Thank you,
James
No. For all intents and purposes a light group is a light. There are no ways for the frontend to extract itās constituents.
OK; thanks. Thatās a shame. Currently have to specify the groups twice (as light groups to use them as lights and as group groups!) in order to tidy up my lovelace.yaml and use the group card.
building on my post above excluding the entities color_temp: ā! noneā I am now trying the opposite, and only show lights with color_temp: 'none'
, or automations with last_triggered: 'none'
bit that fails completely.
Canāt we filter on a not set attribute?
Found a solution by myself. I wrap it in a conditional card. Only problem is that I need a group with all lights to handle the condition (auto-entities filters the same group than). Thatās not the perfect way because new lights need to be added to the group but it works.
Is it possible to use Jinja2 templates in attributes filter?
something like this:
filter:
include:
- attributes:
last_seen: "< {{(as_timestamp(now())-3600)}}"
or it is needed to use the template filter with the mentioned restriction?
Edit: And if the template filter is used is it possible to set the options for another card like include filter?
One of the last updates to this card has stopped working correctly with geo_location entities that can come and go. I am getting the dreaded yellow bar error when an entity is no longer available instead of it just disappearing. When I refresh it disappears. This was always automatically handled but one of the latest updates has stopped.
building on š¹ Auto-entities - Automatically fill cards with entities
I finale found the way to do soā¦:
card:
type: entities
title: Lights only brightness
filter:
exclude:
- domain: light
attributes:
rgb_color: '! none'
- domain: light
attributes:
include:
- domain: light
attributes:
brightness: '! none' # filter browser_mod
state: 'on'
options:
toggle: true
primary:
unit: '%'
what surprised me was I needed to declare the exclusions almost completely double, and could not ad both attributes under the same exclusion. anyways, this give me exactly what I hoped for, (next to the other auto-entities lights cards, explicitly Including the rgb_color and color_temp lights)
nice!
Turns out this is actually a problem with fold-entity-row, which is fixed in release 12.
I have two questions. First, how can I specify a list to the name filter? For example, I would only like to only display entities that have friendly names of ā550ā, ā231Nā, ā235ā, ā235Nā or ā553Kā.
Secondly, the documentation says that one can nest auto-entities. Iām not exactly sure if that is the same thing that is done on multiple cards on the example image (for example, the card āBasic filtersā has multiple sections with different auto-entities). I tried to replicate this, but did not get it working. If possible, could you post a example configuration of a card that has multiple section of different auto-entities.
Thank you as always, your work with these custom cards is phenomenal.
Easiest way is to add one filter for each name:
include:
- name: "550"
- name: "231N"
- name: "235"
Of course, if thereās a regularity to the names, you might be able to match them with a regular expression like:
include:
- name: /[0-9]{3}[NK]?/
Nesting auto-entities means to put one auto-entities inside another, like
card:
As I say, it can be done, but I donāt see any reason to do it.
The cards in the picture uses section rows to divide different filtered parts, like in the 5th example in the readme on github.
@thomasloven I am using this card. Config:
- type: entities
entities:
card:
type: custom:fold-entity-row
head:
type: section
label: Current Incidents
open: true
filter:
include:
- entity_id: "geo_location.nsw_fire_service_feed_*"
- entity_id: "geo_location.lightning_strike_*"
exclude:
- state: unknown
show_empty: true
sort:
method: state
Set to sort by state but this happens:
Obviously sorting alphabeticallyā¦ is there any way to sort by the numeric value of the state?
