šŸ”¹ Auto-entities - Automatically fill cards with entities
Thanks. Missed that option. Cheers.
Is it possible to change the name of an entity with auto-entities?
Like in type: entities
entity: sensor.rain
This doesnā€™t work:
            - type: custom:auto-entities
              show_empty: false
              card:
                type: entities
                show_header_toggle: false
              filter:
                include:
                  - entity_id: sensor.rain
options:
Great, thanks.
Just one more question. One of my sensors reports seconds and it would be better to see the information in minutes. Is there a way to do that calculation directly in lovelace without adding a template sensor for each sensor that should transformed?
HI Thomas,
using this auto-entities card:
    card:
      type: entities
      title: Github repos
    entities:
      - entity: automation.github_repo_update
        secondary_info: last-triggered
    filter:
      include:
        - entity_id: sensor.github*
          options:
            type: custom:dummy-entity-row
#            state: >
#              {% if state_attr(config.entity,'latest_release_url') %}
#              {{ state_attr(config.entity,'latest_release_url').split('tag/')[1]}}
#              {% else %} Not set
#              {% endif %}
#            secondary: >
#              {{ state_attr(config.entity,'latest_commit_message')}}
  #            secondary: "{{ as_timestamp(states[config.entity].last_changed)| timestamp_custom('%X - %D') }}"
          sort:
            method: name
stopped working altogether now, because of this error, which is logged
2020-02-12 09:56:10 ERROR (SyncWorker_7) [homeassistant.components.github.sensor] GitHub error for custom-cards/vertical-stack-in-card: 401 {'message': 'Bad credentials', 'documentation_url': 'https://developer.github.com/v3'}
2020-02-12 09:56:10 ERROR (SyncWorker_7) [homeassistant.components.github.sensor] Error setting up GitHub platform. Check previous errors for details
How could HA think this is a vertical-stack-in-cardā€¦?
Donā€™t understand the Github credentials error either, and I have even refreshed the token. But thatā€™s maybe another matter. Turning to you here for the ā€˜cardā€™ issue reported.
Iā€™m sorry for taking my time with this one. I had to sleep on it because itā€™s so utterly confusing.
I mean, assuming - of course - that you have determined that this error is caused by auto-entities, and are not just pasting random error messages here without even reading them - itā€™s weird how frontend errors suddenly show up in the backend log, isnā€™t it?
To make it even weirder, the errors show an integration name which just happens to be the very same that the sensor you include in a dummy-entity-row belongs to. Crazy coincidence, right?
Wouldnā€™t it be an even more amazing coincidence if the repository address in the first error message happened to match one that you are monitoring with a github sensor? The mere idea boggles the mind!
Alas, as it stands now Iā€™m absolutely baffled. Iā€™ve never before seen a lovelace card turn into a teapot (lacking any description at all on how ā€œstopped working altogetherā€ manifests, Iā€™ll assume it throws a HTTP 418 error). And ā€œbecause of [an] errorā€ none the lessā€¦
Fascinating
well, now this is a very special reply of yours. Iā€™ll swallow the sarcasmā€¦
I was just as baffled as you are. Really sorry for being such an idiot, truly am.
Still, your response made me see what is wrong, so thank you very much indeed. The sensor config for the vertical-stack-in-card GitHub repo is erroring out, rather than it being an error for a vertical-stack-in-card Lovelace config. Which I have not, hence me being baffled. Again: I beg your pardon.
Because of that, the full set of GitHub sensors isnā€™t created. (ā€˜stopped working all togetherā€™) I see that now.
Because this is my sensor setup (If one of these returns an error, the full sensor config is being blocked)
  - platform: github
    access_token: !secret github_token
    entity_namespace: Github
    scan_interval: 3600
    repositories:
      - path: home-assistant/home-assistant
      - path: thomasloven/hass-browser_mod
      - path: dnguyen800/air-visual-card
      - path: thomasloven/lovelace-auto-entities
      - path: custom-cards/bar-card
      - path: custom-cards/bignumber-card
      - path: custom-cards/button-card
      - path: thomasloven/lovelace-card-mod
      - path: thomasloven/lovelace-card-tools
#      - path: custom-cards/config-template-card
      - path: maykar/custom-header
#      - path: iammexx/home-assistant-config/tree/master/ui/darksky
#        name: Darksky weather card
      - path: custom-cards/decluttering-card
      - path: custom-cards/entity-attributes-card
        name: Entity attributes
      - path: thomasloven/lovelace-fold-entity-row
        name: Fold entity row
      - path: custom-cards/gauge-card
      - path: custom-cards/group-card
      - path: thomasloven/lovelace-layout-card
      - path: DBuit/light-popup-card
      - path: iantrich/list-card
      - path: gadgetchnnel/lovelace-card-templater
        name: Card templater
      - path: kalkih/mini-graph-card
      - path: kalkih/mini-media-player
        name: Mini media player
      - path: benct/lovelace-multiple-entity-row
        name: Multiple entity row
      - path: gurbyz/power-wheel-card
      - path: iantrich/restriction-card
      - path: custom-cards/secondaryinfo-entity-row
        name: Secondary info row
      - path: kalkih/simple-weather-card
      - path: thomasloven/lovelace-slider-entity-row
        name: Slider entity row
      - path: thomasloven/lovelace-state-switch
#      - path: bramkragten/custom-ui/tree/master/swipe-card
      - path: thomasloven/lovelace-template-entity-row
        name: Template entity row
#      - path: rodrigofragadf/lovelace-cards/tree/master/tiles-card
      - path: thomasloven/lovelace-toggle-lock-entity-row
        name: Toggle lock entity row
      - path: ofekashery/vertical-stack-in-card
        name: Vertical stack in card
      - path: royto/waze-card
      - path: sgttrs/lovelace-weather-card-chart
        name: Weather card chart
Hope I will get a chance to ask you about the issue I have with the (now commented) templates I use when the card type is template-entity-row. Ive posted it on the correct thread. They keep switching between showing the template, and the template output.
Iā€™m sorry for the hard words.
Itā€™s justā€¦ as Iā€™m seeing parts of your configuration evolve, and seeing what you are making from my plugins, I believe Iā€™m starting to understand your capabilities and how you think about this kind of things.
ā€¦and you could have cracked that one yourself - absolutely no doubt! - if youā€™d just looked it all over once more before posting.
I also believe people in general learn more by solving problems themselves. Iā€™m not trying to discourage anyone from asking for help, justā€¦ give it some rest and then try once more before asking. Perhaps just stepping back a minute will help seeing things differently.
Iā€™m glad you solved it. I tried to be a bit helpful behind all that stupid sarcasm, and Iā€™m happy you saw that - I was almost certain you would.
As for your other problem, I think Iā€™m starting to understand whatā€™s happening, and itā€™s possible that the new version released yesterday might actually fix it.
Sorry.
Thx mate. Really. Much appreciated!
Will check the update soon and report back :+1:
update
indeed seems to have fixed it:
only left (for me in this card) is the need for a more-info on tap.
    card:
      type: entities
#      title: Github repos
      header:
        type: picture
        image: /local/images/github_owler.png
    entities:
    filter:
      include:
          options:
            type: custom:template-entity-row
            state: >
              {% else %} Not set
              {% endif %}
            secondary: >
#  #            secondary: "{{ as_timestamp(states[config.entity].last_changed)| timestamp_custom('%X - %D') }}"
          sort:
            method: name}
when clicking a row, nothing happens. Would be really nice if you could explain to me how I can enable that. If needed, Iā€™ll hop over to the template-entity-row thread.
aamof, it would be great if we could use both tap and hold action. tap for more-info, hold for url navigation to the repoā€¦
    filter:
      include:
          options:
            state: >
              {% else %} Not set
              {% endif %}
            secondary: >
          sort:
            method: name
          tap_action:
            action: more-info
          hold_action:
            url_path: >
              {{ state_attr(config.entity,'latest_release_url')}}
hope you will consider.
HI Thomas,
please let me bother you once again, really sorry, and yes, Ive been trying to look at this from all angles (known to meā€¦)
Iā€™ve been checking this for the last few hours, but canā€™t find the answer, other than the combination of glance core card and auto-entities (and/or template-entity-row) has some incompatibilities.
Ive even made various forms of template sensors, which use custom_timestamp or not for state, and now finally wound up using a template sensor that has the timestamp for state, and an attribute_template ā€˜dateā€™, using the custom_timestamp.
posted here Iā€™ll summarize:
using the entities card this works perfectly
  - type: 'custom:auto-entities'
    card:
      type: entities
    filter:
      include:
        - entity_id: sensor.*_trash_timestamp
          options:
            state: >
              {{state_attr(config.entity,'date')}}
    sort:
      method: state
but using the exact same setup with glance card (also tried custom:hui-glance-card), the sensors are displayed with their state, and not the template-entity-row templates for state.
    card:
      type: glance
    filter:
      include:
          options:
            state: >
    sort:
      method: state
Am I missing the obvious here, because of tunnel vision, or is this an incompatibilityā€¦
once again: sorry if this sounds really noobish, I am simply out of ideas.
What happens when you manually place them into a glance card without the custom card? As a test.
As a matter of fact, I think that is what is happening just nowā€¦
the states of these sensors are the timestamps, so that would be the same output?
btw, I created these timestamp sensors for the reliability of the sort order, based on state. (just like the alarm sensors you and I worked on so intenselyā€¦)
  - type: glance
    title: Timestamp
    entities:
      - sensor.gft_trash_timestamp
      - sensor.papier_trash_timestamp
      - sensor.plastic_verpakkingsafval_trash_timestamp
      - sensor.restafval_trash_timestamp
Well, I think this requires an Issue: FeatureRequest on the front end. Looks like the issue is with glance not accepting timestamp device_class.
yeah, something is not right, timestamps are not compatible with glance
but thereā€™s more, I tried this next:
  - type: glance
    title: Timestamp
    columns: 4
    entities:
      - type: custom:template-entity-row
        state: >
          {{state_attr('sensor.gft_trash_timestamp','date')}}
        state: >
          {{state_attr('sensor.papier_trash_timestamp','date')}}
        state: >
          {{state_attr('sensor.plastic_verpakkingsafval_trash_timestamp','date')}}
        state: >
          {{state_attr('sensor.restafval_trash_timestamp','date')}}
but that wont work either, glance doesnā€™t accept a card for an entity, like entities card does. it even stumbles on the columns in this case:
Well the timestamp device_class is only ā€˜meantā€™ for timestamps in the past. Iā€™ve always thought that was stupid, but thatā€™s the case. So, to me, itā€™s no surprise that they donā€™t work in the future on glances, etc.
Glance cards canā€™t take custom stuff (yet?). So for a glance card youā€™re stuck with glance buttons.
probably need to create some custom card buttons thenā€¦ thing is I need to order then based on the timestamp, which poses a new challenge altogetherā€¦ no sure if the auto-entities card does that, but will try before I ask :wink:
somehow I feel a tweak coming up nextā€¦ #fingerscrossed
Is it possible to make this card work with cards that only take one entity? Such as media-control card? The idea would be that it then expanded out to show multiple copies of the card if the filter returned more than one entity.
Hi Thomas,
to have auto-entities select the only 4 sensors in my setup with an attribute next_pickup_in_days I think I need to do this:
    card:
      type: glance
    filter:
      include:
        - domain: sensor
          attributes:
            next_pickup_in_days: '! none'
wouldnā€™t it be a future possibility to change the config into:
    card:
      type: glance
    filter:
      include:
        - attributes: next_pickup_in_days
meaning, filter all entities that have an attribute next_pickup_in_days?
would you accept a feature request for this? I feel it would make the auto-entities even more powerful.
thanks for considering.
