Yes, using layout-card. Thereās an example near the bottom of the readme here: https://github.com/thomasloven/lovelace-layout-card
That feels like a bit too much work, and a new configuration method - with associated documentation and confusement - for a minimal simplification of something thatĀ“s already very easy.
attributes:
next_pickup_in_days: *
Just want to say that this worked brilliantly, thanks!
completely missed that option, working nicely indeed, thank you very much!
hmmm, I think I saw the sensors appear, but now only see an empty cardā¦must have ben a cache thing, still loading my previous config.
also, using the single * without quotes results in an error:
while scanning an alias in "/config/lovelace/views/view_Tijd_agenda.yaml", line 34, column 34 expected alphabetic or numeric character, but found '\n' in "/config/lovelace/views/view_Tijd_agenda.yaml", line 34, column 35
using
- type: 'custom:auto-entities'
card:
type: glance
filter:
include:
- domain: sensor
attributes:
managed to take out the domain: sensor, but canāt use the *, and need to set
card:
type: glance
filter:
include:
- attributes:
next_pickup_in_days: '! none'
And with quotes?
card:
type: glance
title: "'! none'"
filter:
include:
- attributes:
sort:
attribute: next_pickup_in_days
method: attribute
numeric: true
- type: divider
card:
type: glance
title: "'*'"
filter:
include:
- attributes:
next_pickup_in_days: '*'
sort:
method: attribute
numeric: true
results in:
no error in the log or inspector
Hi all
Iām having issue moving from monster-card
to auto-entities
This is the one not working
# - type: custom:monster-card
card:
type: entities
show_header_toggle: false
show_empty: false
filter:
include:
- entity_id: 'sensor.illumination_1234567890'
icon: mdi:weather-sunny
options:
secondary_info: last-changed
- entity_id: 'sensor.teclast_battery'
icon: mdi:battery-50
options:
- entity_id: 'sensor.lumi_plug'
icon: mdi:speedometer
options:
- entity_id: 'input_boolean.announce_shellies'
icon: mdi:alarm-light
options:
- entity_id: 'sensor.temp_shelly_2_5_finestra_sala'
icon: mdi:thermometer
options:
When I use auto-entities
I donāt see this card, while using the monster-card
all works.
Iāve tried the auto-entities
with and without single quotes.
Other auto-entities
card I have moved from monster-card
work fines
Any suggestion?
use a core entities cardā¦ You donāt seem to use any of the special features auto-entities card offers?
if you only want to show these 5 entities, thereās no need for the auto-entities card.
It could also be that icon:
is not a valid filter.
Yes, itās true, but probably I was using some special features before and now I changed to ānormalā core entities card. I will try this way.
Yes, that did the trick, thanks!
Removing the icon:
now itās working.
Hi, thanks for all you awesome cards!
I am using your card to add entities through wildcards, but I want to rename one. For now I would like to avoid adapting the āfriendly nameā.
Using options:
I indeed can change the name when adding it through entities:
but due the wildcards I get duplicates which I cant avoid with unique:
Hi guys,
I am trying to list all my devices battery levels. Adding this:
include:
- entity_id: '*battery*'
Shows only battery entities, but I also have some ābattery_levelā states for my sensors and binary_sensors - e.g. :
binary_sensor.living_room_motion - battery_level: 49
sensor.bedroom_temperature - battery_level: 49
Is there a way to combine all these into a single card using auto-entities?
Rather than states you mean attributes I think (or state attributes). But Iām afradi I donāt know how to do it. I did it with two cards in the end.
You can add another filter to include
to get the entities with a battery attribute, but youād need some other kind of entity row to display them:
include:
- attributes:
battery: "*"
options:
type: custom:some-battery-attribute-showing-entity-row
Got similar situation. Thanks for pointing that thread.
In auto entities wiki numerical comparison it states:
filter:
include:
- attributes:
battery: "<= 50" # Attribute battery_level is 50 or less
While in reality this one throws āCannot convert undefined or null to objectā for me
Anyway got sorted out by post referenced by Ralf
filter:
include:
# - attributes:
# battery: "<= 95" # Attribute battery_level is 50 or less
- entity_id: sensor.*.battery_level*
state: <= 95
Other topic:can I filter badges by this miracle?
EDIT: After one slight adjustment I donāt get error, but it does not return any result:
- attributes:
Is it possible to use card-mod styling inside of the auto-entities card?
should be possible, you can add styles to the card. You can even have it filled custom cards automatically with the use of layout-card.
Btw, @thomasloven, we can use group and domain as a filter (for use with layout-card) however we can, not have a list of entities. If an entity is defined we need to define separate options for each entity. Would it be possible to support a list (preferable comma separated) within the filters? That would be really awesome if that would be possible.
e.g.
- type: custom:auto-entities
filter:
include:
- entity_id: switch.device_1, switch.device_2, light.light_1, media_player.living
options:
type: custom:button-card
entity: this.entity_id
sort:
method: name
numeric: true
card:
type: custom:layout-card
min_columns: 1
max_columns: 1
justify_content: start
layout: vertical
I just tried to add styling to a type: section
and it didnāt work
Not sure if itās what you asked for but if so here is what I use and works for me for styling entities:
show_empty: false
filter:
include:
- attributes:
battery_level: "=0"
entity_id: "binary_sensor.visonic*"
options:
icon: 'mdi:battery-10'
style: |
ha-card {
margin:0px 0px 0px 0px !important;
border: none !important;
border-shadow: none !important;
state-badge {
margin: -5px 0px 0px 0px !important;
Good idea. Iāll see to adding that.
