šŸ”¹ Auto-entities - Automatically fill cards with entities
Not Away, not away - must be not _home.
bingo! rock on dude, thank you
Here is what I use to display the friendly name in the primary field of my mushroom template card:
primary: '{{ state_attr(entity, "friendly_name") }}'
Thank you! That advice got me on the right track, and I was able to accomplish everything and more. Here is the fix:
type: custom:auto-entities
card:
  square: false
  type: grid
  columns: 1
filter:
  include:
    - name: /Climate Sensor Temperature/
      options:
        type: custom:mushroom-template-card
        icon: mdi:thermometer
        primary: >
          {{state_attr(entity,'friendly_name') | replace('Climate Sensor
          Temperature','') }}
        secondary: |
          {{states(entity)+" Ā°F"}}
        icon_color: |-
          {% set state=states('this.entity_id') %}
          {% if state > '70' %}
            red
          {% elif state > '69' %}
            orange
          {% else %}
            yellow
          {% endif %}
  exclude:
    - state: unavailable
sort:
  method: state
  reverse: true
  numeric: true
show_empty: false
card_param: cards
And if anyone else is going down a similar rabbit hole, here is my finished code which includes more intricate color-coding:
card:
  square: false
  type: grid
  columns: 2
filter:
  include:
    - name: /Temperature/
      options:
        primary: >
          Temperature','') | replace('Temperature','') }}
        secondary: |
        icon_color: |-
          {% if state >= '-80' and state < '-20' %}
            #cbdbf4
          {% elif state >= '-20' and state < '-10' %}
            #7591b9
          {% elif state >= '-10' and state < '0' %}
            #7591b9
          {% elif state >= '0' and state < '10' %}
            #7591b9
          {% elif state >= '10' and state < '20' %}
            #4d6591
          {% elif state >= '20' and state < '30' %}
            #39517f
          {% elif state >= '30' and state < '32' %}
            #2f4775
          {% elif state >= '32' and state < '35' %}
            #275b80
          {% elif state >= '35' and state < '40' %}
            #275b80
          {% elif state >= '40' and state < '45' %}
            #275b80
          {% elif state >= '45' and state < '50' %}
            #256789
          {% elif state >= '50' and state < '55' %}
            #287593
          {% elif state >= '55' and state < '60' %}
            #438190
          {% elif state >= '60' and state < '65' %}
            #648d89
          {% elif state >= '65' and state < '70' %}
            #879a84
          {% elif state >= '70' and state < '75' %}
            #aba87d
          {% elif state >= '75' and state < '80' %}
            #c0a978
          {% elif state >= '80' and state < '85' %}
            #c19d61
          {% elif state >= '85' and state < '90' %}
            #c38a53
          {% elif state >= '90' and state < '95' %}
            #be704c
          {% elif state >= '95' and state < '100' %}
            #af4b4e
          {% elif state >= '100' and state < '105' %}
            #9e294c
          {% elif state >= '105' and state < '110' %}
            #87203e
          {% elif state >= '110' and state < '115' %}
            #6e1531
          {% elif state >= '115' and state < '120' %}
            #560c25
          {% elif state >= '120' and state < '150' %}
            #3d0216
          {% else %}
            black
          {% endif %}
  exclude:
    - state: unknown
    - name: PirateWeather*
    - name: OpenWeatherMap*
sort:
  method: state
  reverse: true
  numeric: true
show_empty: false
card_param: cards
Hi. I wonder if I could filter by one entity but show another entity by replacing chars in the filtered entity name, like the following (note: I donā€™t fully understand the syntax of the auto-entities card so I have most probably errors in the code below). Aim: to filter mobile devices to only those which are actually charging (sensor.XXX_battery_state = ā€˜chargingā€™) but then display their battery levels instead (sensor.XXX_battery_state >> replacing ā€˜_stateā€™ for ā€˜_levelā€™ >> sensor.XXX_battery_level). Thanks.
card:
  type: entities
filter:
  include:
    - entity_id: sensor.*battery_state
      state: charging
      options:
        entity: |
          {{ this.entity_id | replace('_state', '_level') }}
sort:
  method: state
  numeric: false
show_empty: false
Hi
Today I learned the purpose of <card_param>
An option I did overlook for a long time.
The <card_param> option allows to generate the entries into another card object then the default entities:. As several cards list there entries under different objects then entities, this allow to still populate them with auto entities.
I want to share a short more challenging example. Auto populate a ā€˜history-explorerā€™ card. This particular card is a little more complex as the entities are declared in sub keys of a list of graph types. So not a simple rename using <card_param>. Using a template filter makes that possible:
This is a simple history-explorer card, configured in the standard way:
type: custom:history-explorer-card
graphs:
  - type: line
    entities:
      - entity: sensor.temperatures_bedroom
      - entity: sensor.temperatures_living
This is the same card, but populated with auto-entities:
card_param: graphs
filter:
  template: >
    {%- set entities = state_attr('sensor.temperatures_binnen','entity_id') or
    {%- set ns = namespace(lines=[]) -%}
    {%- for entity in entities -%}
      {%- set ns.lines = ns.lines + [{'entity': entity }] -%}
    {%- endfor -%}
    {%- set graph=[
             {'type': 'line',
              'entities': ns.lines},
    {{ graph }}
card:
Simple things, like your request, can be done using a template filter.
With the template-entity-row you can generate rows with whatever you like, instead of an entity. I used them to list devices
Then consider closing your issue in auto-entities github.
ā€¦It is closed
Thank you for your help with the history explorer card. Been looking so long for that.
I got some extra gray hair as well to get that working :face_with_peeking_eye:
Haha Iā€™ve lost hair over thisā€¦
Iā€™ve circled back to trying to get auto entities and history Explorer to work together two or three times over the last couple of years and had still not come up with a solution.
I think I even raised a feature request on the repository for history Explorer asking to be able to provide the graph definitions from a template
I knew the solution needed <card_param> but I just couldnā€™t get it t work.
This is going to make my Bayesian sensor diagnostics page maintenance free.
Even you have posted that example long time ago, have you found solutions for the open items?
I have started to adopt the idea a little bit:
type: custom:template-entity-row
  {{state_attr(config.entity, 'friendly_name')|regex_replace(find='17Track Paket
  ', replace='', ignorecase=True)}}
secondary: |-
  {% if state_attr(config.entity, 'location') %}
    {% if state_attr(config.entity, 'location') == "CN" %}
      China:
    {% else %}
      {{state_attr(config.entity, 'location')}}:
    {% endif %}
  {% endif %}
  {% if state_attr(config.entity, 'info_text') %}
    {{state_attr(config.entity, 'info_text')}}
  {% endif %}
icon: |
  {% if states(config.entity) == "In Transit" %}
    mdi:truck-delivery
  {% elif states(config.entity) == "Delivered" %}
    mdi:package-variant
  {% elif states(config.entity) == "Not Found" %}
    mdi:briefcase-search
  {% elif states(config.entity) == "Returned" %}
    mdi:directions-fork
  {% elif states(config.entity) == "Undelivered" %}
    mdi:help-box
  {% elif states(config.entity) == "Expired" %}
    mdi:timer-off
  {% elif states(config.entity) == "Collection" %}
    mdi:package-variant-closed
  {% else %}
    mdi:alert-circle
  {% endif %}
tap_action: |
    "action": "url",
    "url_path": {
      "https://t.17track.net/en#nums={{ state_attr(config.entity, 'tracking_number')}}"
card_mod:
  style: |
    :host {
      --card-mod-icon-color:
          blue
          green
          red
          orange
          red
          grey
          purple
        {% else %}
          red
        {% endif %}
tap_action template works, animation has been deleted.
Can anyone tell me why this template is not working in my auto-entities card? It works to produce a list in developer tools so Iā€™m at a loss.
card:
  type: entities
  state_color: true
  title: ''
filter:
  template: |
    {{ states
    | selectattr('entity_id', 'in', integration_entities('zha'))
    | selectattr('state', 'in', ['off'])
    | map(attribute='entity_id')
    | map('device_attr', 'name_by_user')
    | reject('match', 'None')
    | unique
    | list
I am getting this as the card output:
The developer tools output is this:
As you are effectively using the standard HA entities card, you need to provide the entity_id under the entity: key, not the friendly name. Thatā€™s what the error is telling you anyway.
Test removing | map('device_attr', 'name_by_user')
Yes, that does produce something. I was hoping to have a list that would just show unique devices, though, and not the various entities for each device.
Appreciate it. I removed the "| map(ā€˜device_attrā€™, ā€˜name_by_userā€™) " as suggested by another commenter and it produces something. I was ultimately wanting a list of unique devices but maybe that is not possible with the auto-entities card.
You could build a list of the entities and include device_id. Then, get them by unique id.
Use the second code section in this post as an example
Devices and Areas - Configuration / Frontend - Home Assistant Community (home-assistant.io)
can it be that the Action-Taps in templtes doenst work any more? (you use it right? @Mariusthvdb )
when i add it, no enteties are there, without all fine
  template: |-
    {% for state in states.climate %}
      {%- if state.entity_id | regex_match("climate.*_klimaanlage", ignorecase=False)
        and state.state in ["auto", "cool", "heat", "dry"] -%}
            'type': "tile",
            'entity': state.entity_id,
            'name': state.attributes.friendly_name.split(' Klimaanlage')[0]
            'icon_tap_action': {'action':'toggle'}
      {%- endif -%}
    {% endfor %}
