Okay, then Iām glad that everything is good between us. I donāt know if I could get there on my own in the future, Iām still at the beginning with HA. And sometimes, as a beginner, you need support in the right direction.
But one more thing: Yes, it is exactly what is shown. A list of all active scenes. I use python_script.set_state in automation to set a custom attribute to the scenes when they are active or not active. The conditions are numeric_state of the attributes of the corresponding entities. And trigger the activation of the scene or attribute changes of the corresponding entities.
But none of that belongs in this thread anymore. So see you soon and all the best.
Itās strange, before the update to 2024.7 there was no such problem, or it was almost unnoticeable, the indent was a couple of extra pixels, but now the indent is at least 15 pixelsā¦
I did say āminimalā with a purposeā¦
you cant expect the community to test your config to the minimal state it show the issue you experience.
please strip everything from that config to the bare minimum still showing your problem in the Dashboard
also, tell us what view you are using.
if it is the Sections view, it might very well be that causing more space than you expect. Itās still experimental and has several flukes we hope will get ironed out
@Mariusthvdb Well this is the bare minimum, which shows the configuration in a vertical stack of several custom:auto-entities cards with the show_empty: false option, i.e. when they are empty, they create an empty space of about 15 pixels each, when they have selected entities, and all are displayed, then everything is fine.
I use the old regular panel, just a dark theme.
Thanks!
In 2023.x there was same margin in vertical-stack if auto-entities=empty. May be it was changed later & then again changed by 2024.7 - no idea.
I do not think that a stack knows somehow that an inner card is not shown. Similar case described there: āplace 3 stock conditional cards inside a vertical stack - and make these conditions āfalseāā. Note - with hidden stock cards ā same margin.
Maybe I donāt remember when I added these cards. Before 2024.7 I saw a slight increase in spacing (about 1-2 pixels per card) but it didnāt look that out of place. In 2024.7 itās very noticeable.
Yes, I saw it once, but I donāt remember if there was a solution to this problem.
Just specify āvisibilityā for the whole stack as a workaround.
Or may be card-mod (display: none) for the stack; but I would choose the 1st way (although it is more complex since you have to create a binary sensor which is OFF if list is empty; visibility does not support templates if I am not mistaken).
Then I probably misunderstood you.
You said you have 3 auto-entities (empty) inside a stack; since they are empty - they are not supposed to be shown; but a stack has some inner margin anyway. Means - you need to hide the whole stack somehow either by visibility or by card-mod.
thanks for the edit, that indeed is what I had hoped you did.
I see Ildar helped you out now, and he is correct about the conditional for the container card.
Its default behavior with any of those containers, they are agnostic to their content
It should however be possible to get rid of the stack-card-gap you are seeing between the fixed cards and the auto-entities if the auto-entities were empty
Iāll try to move all auto-entities to a separate stack and take a look. How can I do this with card mod? I mean hide the entire stack? Do you have an example in your card_mod thread?
