(off-top)
None of my dashboards is based on sections due to different glitches.
Using sections for testing only.
Iāve been using them here and there, they have a nice look. It would be nice to get them to work with auto-entities. Iām sure itās doable, auto-entities is in maintenance mode so someone with frontend dev experience will need to add it
have an example there?
using sections everywhere, so I can test if you want.
not much to test, just attempt to use auto entities using custom:hui-grid-sections
as the card type. It will likely crash your browser or cause it to lag.
But what for? What do you want to achieve?
ā¦ a dynamic number of entities inside a section grid. Or dynamic number of cards, doesnāt matter what.
Iām not really asking for help here, Iām explaining that it doesnāt work and warning others that it doesnāt work.
hmm, I only use cards:
everywhereā¦
have only single column views, so no use for grid
: sections yet
only auto-entities that breaks my config is using filter on label.
it did that also in masonry so unrelated.
But, Thomas is back and rewriting some of his cards, maybe he will check auto-entities too
Well, at least this small example work OK w/o errors in console (Chrome).
Here āauto-entitiesā populates Grid card (not that hui-grid thing):
- type: sections
title: 25x
cards: []
sections:
- type: grid
cards:
- type: heading
heading: New section
- type: vertical-stack
cards:
- type: entities
entities:
- entity: input_number.test_number
- type: custom:auto-entities
card:
type: grid
columns: 2
square: false
card_param: cards
filter:
template: >-
{% set NUMBER = states('input_number.test_number')|int(default=0) -%}
{%- for ENTITY in (
states.input_boolean |
selectattr('entity_id','search','\.test_boolean') |
selectattr('state','eq','on') |
sort(reverse=false,attribute='name') | list
)[:NUMBER] -%}
'type': 'entity',
'entity': ENTITY.entity_id
{% endfor -%}
- type: grid
cards:
- type: heading
- type: entities
entities:
- entity: input_boolean.test_boolean
- entity: input_boolean.test_boolean_2
- entity: input_boolean.test_boolean_3
- entity: input_boolean.test_boolean_4
- entity: input_boolean.test_boolean_5
- entity: input_boolean.test_boolean_6
- entity: input_boolean.test_boolean_7
- entity: input_boolean.test_boolean_8
- entity: input_boolean.test_boolean_9
- entity: input_boolean.test_boolean_10
But what you wanted seems to be populating āhui-grid-sectionā to populate a whole section, not a grid card within it.
Actually, I have no idea how it is possible to place
card:
type: custom:hui-grid-section
card_param: ???
filter:
template: ...
into this structure where every entry is supposed to be āgridā:
type: sections
sections:
- type: grid
cards: ...
- type: grid
cards: ...
grid card and grid section are 2 different areas of code.
seeing that you both really want to try this.
type: section
sections:
card:
card_param: cards
fill in the rest
I do not think it is possible.
At least for now.
title: test-3
path: test-3
type: sections
sections:
card:
card_param: cards
filter:
include:
- entity_id: input_boolean.test_boolea*
options:
type: entity
Yes, thatās what Iām saying. It does not work and it causes exceptions upwards of 50 a second.
How do I include a variable list of entities in an entitites card then?
I have all my stuff organized around topics/rooms using entities cards. Therefore, itās breaking the scheme if I can only add the auto-entites if Iām using the auto-entities card.
Do not place this code as a ROW inside Entities card.
Instead, use auto-entities as the āupperā card, list your static entities like in my example.
Ah, I see what you meant. However, it looks like with this approach itās not possible to position the auto-entities somewhere in between other rows and/or use the desired sorting method? Hereās what I mean (with only sections for now, my target card is more complex):
entities:
- type: section
label: Timer
- type: section
label: Wecker
filter:
include:
- entity_id: sensor.google_home_mini_timer_*
options:
type: custom:timer-bar-card
translations:
paused: pausiert
active: beendet
extend_paper_buttons_row:
position: right
buttons:
- icon: mdi:close
- entity_id: sensor.google_home_mini_alarm_*
options:
type: custom:multiple-entity-row
show_state: false
secondary_info:
attribute: end_time
format: datetime
entities:
- icon: mdi:close
exclude:
- state: unavailable
- state: ""
- state: idle
show_empty: false
card:
type: entities
show_header_toggle: false
state_color: false
title: Title
sort:
method: none
Iād want to have āTimerā section > timer auto-entities > āAlarmsā section > alarm auto-entities. In the documentation I couldnāt find a way to ācustom sortā the entities e.g. by setting the position manuallyā¦
You can certainly do that.
Two different auto-entities cards. One for each.
To place static rows between filtered rows - place these rows as filters:
card:
type: entities
entities:
- zone.home
- person.ildar
- type: section
label: xxx
filter:
include:
- entity_id: input_number.test_n*
sort:
count: 3
- type: section
fake_option: 1
- entity_id: sun.sun
- type: section
fake_option: 2
label: yyy
- domain: counter
sort:
count: 2
unique: entity
was on the topic of reusing the area card once again and wanted a quick and dirty auto-entities listing
card:
card_param: cards
filter:
template: |
{% for a in areas() %}
{"type": "area",
"area": a,
{% endfor %}
which shows ok
and with certain classes:
{"type": "area",
"area": a,
"sensor_classes":
{"temperature","humidity"},
"alert_classes":
{"motion","moisture","running","garage_door"},
{% endfor %}
this filter however flukesā¦
what am I not seeing?
Youāre providing sets to motion and sensor_classes, not lists. Change them to lists.
rightā¦
{% for a in areas()
|reject('search','klimaat|main|mobile|huis|test') %}
{"type": "area",
"area": a,
"navigation_path":"/ui-sub-views/"~a,
"sensor_classes":
["temperature","humidity"],
"alert_classes":
["motion","moisture","running","garage_door"],
{% endfor %}
Thanks a lot, your solution is working perfect.
I just had to modify my regex for the search condition of selectattr
to: sensor.calendar_event[1-9]
