Auto-entities template with static attribute
I’m trying to list all unavailable devices in a auto-entities list. This is what I got so far:
package_unavailable_devices.yaml:
template:
  - sensor:
      - name: "Unavailable Devices"
        unique_id: unavailable_devices
        icon: "{{ iif(states(this.entity_id)|int(0) > 0,'mdi:alert-circle','mdi:check-circle') }}"
        unit_of_measurement: entities
        state: >
          {%- set devices = namespace(entities=[]) -%}
          {%- set entities = states | selectattr('state', 'in', ['unavailable', 'none']) | map(attribute='entity_id') | lis>
          {%- for entity in entities -%}
            {%- set devices.entities = devices.entities + [device_attr(entity, "name_by_user")] -%}
          {%- endfor %}
          {{ devices.entities | unique | list | length}}
        attributes:
          devices: >
            {%- set entities = states | selectattr('state', 'in', ['unavailable', 'none']) | map(attribute='entity_id') | l>
              {%- if device_attr(entity, "name_by_user") -%}
              {%- else -%}
                {%- set devices.entities = devices.entities + [device_attr(entity, "name")] -%}
              {%- endif -%}
            {%- endfor %}
            {{ devices.entities | unique | list }}
Card Configuration:
type: custom:auto-entities
card:
  type: entities
  title: 'Unavailable Devices: '
filter:
  template: |-
    {% set SENSOR = 'sensor.unavailable_devices' -%}
    {%- for attr in states[SENSOR].attributes['devices'] -%}
          'type': 'attribute',
          'entity': SENSOR,
          'attribute': 'unavailable',
          'name': attr
    {%- endfor %}
This works but has a “cosmetic” issue:
Instead of 'attribute': 'unavailable' I only get a dash.
Is there something I could do about that?
@mietz I know you posted this question a while ago, but as I’m currently having exactly the same question, may I ask how you solved the issue? Could you post the code you’re currently using to show unavailable devices? Thanks!
