I recently started learning ESPHome. The problem is the following: I have several light bulbs and I want to control them through mqtt. In the future I want to buy more, if I can with these. But I don’t want to create an almost individual topic for each lamp. Is it possible to automate this? I wanted to use the MAC address, but I can’t figure out how to bind it to the name
See ESPHome Core Configuration — ESPHome - use name_add_mac_suffix
Unfortunately, I did not achieve the desired result. The Device name is changed, but when I want to use this name as a topic name in mutt, the name is written without the suffix
i want to get that lamp name with suffix as topic
Something like:
lamp27-(mac_suffix)/status
I suspect I didn’t quite understand how to use this and would appreciate it if you could provide an example.
How many lamp27’s do you have?
Your yaml and log may help.
Now I have 3 of them, but I want to replace all the lamps.
substitutions:
device_name: lamp27
esphome:
name_add_mac_suffix: True
esp8266:
board: esp01_1m
# WIFI Setting's
wifi:
networks:
- ssid: !secret wifi_ssid
priority: 5.0
- ssid: Lamp.update
password: IDoNotKnow
priority: 10.0
ap:
ssid: ...
password: ...
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: !secret api_encryption
# Configuration entry
ota:
password: !secret ota_password
captive_portal:
# MQTT Setting's
mqtt:
broker: test.mosquitto.org
username: ...
password: ....
discovery: true
discovery_prefix: Lamp27-150/homeassistant
log_topic: ${device_name}/logs
on_connect:
then:
- switch.toggle: red_light
- delay: 5s
on_disconnect:
then:
- switch.toggle: blue_light
- delay: 25s
switch:
- platform: gpio
pin: GPIO4
- platform: gpio
pin: GPIO12
- platform: gpio
pin: GPIO14
- platform: gpio
pin: GPIO13
# Output's pin on lamp27
output:
- platform: esp8266_pwm
pin: GPIO4
pin: GPIO12
pin: GPIO14
pin: GPIO13
light:
- platform: rgbw
red: output_red
green: output_green
blue: output_blue
white: output_white
color_interlock: true
default_transition_length: 0.2s
command_topic: esphome/ota_mode/${device_name}
effects:
- pulse:
update_interval: 0.2s
- pulse:
transition_length: 1s
update_interval: 1s
Please forgive me if the code is badly written.
It seems to be formatted, as in the instructions.
no ideas?
variant 1:
substitutions:
topic: esp/esp02
esphome:
switch:
- platform: gpio
pin: GPIO12
state_topic: "${topic}/gpio12"
command_topic: "${topic}/set/gpio12"
variant2:
substitutions:
esphome:
switch:
- platform: gpio
pin: GPIO12
state_topic: "${name}/gpio12"
command_topic: "${name}/set/gpio12"
Thanks for the answer, but I still have to create a different configuration file for each device.
I’d like to use the standard function.
For example, as in the name if you activate the mac-suffix function.
esphome:
In this case, in the name of the device on the network, I see this.
lamp27-6761b6
Here I would like to use the same name, but in the mqtt topic, but I can’t understand why esp ignores the name change.
Hi.
@Hromodeus
I had the same issue. Now I’m working on the PR for the esphome.
This will add mac address to mqtt name.
You are welcome to test it.
It also introduces <topic_prefix>
placeholder which can be used in customized topic names and subscribe/publish actions. It is essential if your devices with mac in the name need to receive messages.
by default all device topics are <topic_prefix>/xxxxx
, but you may want to customize some of the topics to be <topic_prefix>/abcdef/my/custom
or even home/lights/<topic_prefix>/status
Where <topic_prefix> will be expanded to device-name-AABBCC
if name_add_mac_suffix: True
Here is an example of config
mqtt:
broker: !secret mqtt_broker
discovery: False
birth_message:
topic: <topic_prefix>/my_availability
payload: online
will_message:
payload: offline
on_message:
- topic: <topic_prefix>/on_message_topic
then:
- logger.log: Received on_message_topic
- mqtt.publish:
topic: <topic_prefix>/on_message_topic_confirmation
payload: "Received on_message_topic"
- mqtt.publish:
topic: <topic_prefix>/on_json_message_topic
payload: "{ \"Received\": \"on_message_topic\" }"
And here are the results
[20:35:04][C][mqtt:168]: MQTT:
[20:35:04][C][mqtt:169]: Server Address: xxx
[20:35:04][C][mqtt:171]: Username: ''
[20:35:04][C][mqtt:172]: Client ID: 'esp-sensor-551495-48e729551495'
[20:35:04][C][mqtt:177]: Topic Prefix: 'esp-sensor-551495'
[20:35:04][C][mqtt:179]: Log Topic: 'esp-sensor-551495/debug'
[20:35:04][C][mqtt:182]: Availability: 'esp-sensor-551495/my_availability'
[20:35:04][C][api:139]: API Server:
[20:35:04][C][api:140]: Address: esp-sensor.local:6053
[20:35:04][C][api:144]: Using noise encryption: NO
[20:35:04][C][mqtt:709]: MQTT Message Trigger:
[20:35:04][C][mqtt:710]: Topic: 'esp-sensor-551495/on_message_topic'
[20:35:04][C][mqtt:711]: QoS: 0
[20:35:04][C][mqtt:727]: MQTT JSON Message Trigger:
[20:35:04][C][mqtt:728]: Topic: 'esp-sensor-551495/on_json_message_topic'
[20:35:04][C][mqtt:729]: QoS: 0
