I don’ t know if I’ m right to post here but…
… is it possible to introduce a feature that is able to change ALL the name of the entities that I change in all the scripts, automations, others… ?
Because, when I’m change the name of a device, is annoying and very difficult to remember and change all the name of the entities in the different automations, scripts or others…
If you have the Spook add on, it will helpfully tell you automation, script, dashboard, and probably more (areas? groups?) that your now defunct entity ID appears in if you change it to something else, making it easy to track down all the places you need to change.
I need to change the first light name in “Main Garage” (the second one should be “Secondary Garage”)
now I have to change ALL the entity parameter “light.garage” in “light.main_garage” for *ALL my scenes, scripts, automations, …
So, I know that there are a lot of ways to do that but my idea is that would be very important that in HA this feature is totally automated and integrated on the SO.
(sorry for my bad english and for my bad explanation)
The trouble with it being fully automated is if you are intending to change a device to something else, and don’t want it to accidentally break all your scripts and automations. Maybe the UI could offer to make updates elsewhere.
I don’ t know this tool… I have to study it
BTW consider to have 10-12 automations involved (or more) and for each automation maybe 3-4 points where the entity is involved… it’ s a hard work to change manually…
So, if that is automated…it’ s better…
Also, not all the installation (I have raspy3) support VSCode
