I’m running Home Assistant OS on a virtual machine on my ESXI server. Generally it works great. I don’t think I’ve had any issues with the OS itself, but HA occasionally breaks down for unknown reasons and just stops.
I have HA being monitored by UptimeRobot, so I get alerted when it’s no longer available. It’s rare that it crashes, but it happens often enough that I want a better recovery solution.
Is there a way to configure Home Assistant OS to automatically restart HA if it crashes?
The HA service crashes and doesn’t come back up. I get notified by UptimeRobot that the URL is no longer available, so I remote into the server to check and I’m only able to see the final few lines of the log indicating that HA terminated all processes so it’s in a failed state. I’m able to just restart the service at that point and it loads back up fine.
Is the supervisor a separate service or is it running under the same process as HA itself? If it’s a separate process, I haven’t checked to see if it’s still available or not, but it doesn’t bring HA back up after the crash, so I assumed it was the same process.
I’d like to better be able to examine the logs, but I can’t pipe the log command to “less” since it’s not installed on HA OS. Do you know of a better way to actually view all of the logs?
