Auto sorting of power monitors
First thing, I see posts with what looks to be a screenshot of the yaml code but is able to be copied from the top right corner, how do I do this for my post?, I will add it this to this help request to see what exsist and what I can add to do what I would like to do.
I have a vertical stack of custom bar cards to show me the real time power consumption status of the power hungry item in my home, I would like it to automatically sort them so the highest to lowest is from top to bottom, how would the code look in relation to the existing code I have currently? I will post the configuration when I know how to do it without it being a screenshot.
Cheers for any help.
type: custom:bar-card
icon: mdi:battery
entities:
  - entity: sensor.solahart_power
  - entity: sensor.spa_power
  - entity: sensor.living_ac_power
  - entity: sensor.master_ac_energy_power
  - entity: sensor.bailey_s_ac_energy_power
  - entity: sensor.rhys_s_ac_energy_power
  - entity: sensor.declans_ac_energy_power
  - entity: sensor.washing_machine_power
  - entity: sensor.dishwasher_power
  - entity: sensor.oven_power
  - entity: sensor.cooktop_power
  - entity: sensor.ice_machine_power
min: 0
max: 4000
positions:
  icon: 'off'
  indicator: null
severity:
  - color: Red
    to: 5000
  - color: orange
    to: 2499
  - color: green
    to: 1499
  - color: null
    to: 999
  - color: 'n'
    to: 15
sort:
  - position: null
    to: 0
columns: 1
limit_value: true
Use the “Preformatted text” button…
That button can be hidden under the cog icon button on mobile devices. There is also an alternative method and a lot of other useful information in the Forurn FAQ.
Tried it and all I get is this below, not in a yaml form, what am I doing wrong?
type:%20custom%3Abar-card%0Aicon%3A%20mdi%3Abattery%0Aentities%3A%0A%20%20-%20entity%3A%20sensor.solahart_power%0A%20%20%20%20name%3A%20Solahart%0A%20%20-%20entity%3A%20sensor.spa_power%0A%20%20%20%20name%3A%20Spa%0A%20%20-%20entity%3A%20sensor.living_ac_power%0A%20%20%20%20name%3A%20Living%20AC%0A%20%20-%20entity%3A%20sensor.master_ac_energy_power%0A%20%20%20%20name%3A%20Master%20AC%0A%20%20-%20entity%3A%20sensor.bailey_s_ac_energy_power%0A%20%20%20%20name%3A%20Bailey's%20AC%0A%20%20-%20entity%3A%20sensor.rhys_s_ac_energy_power%0A%20%20%20%20name%3A%20Rhys's%20AC%0A%20%20-%20entity%3A%20sensor.declans_ac_energy_power%0A%20%20%20%20name%3A%20Declan's%20AC%0A%20%20-%20entity%3A%20sensor.washing_machine_power%0A%20%20%20%20name%3A%20Washing%20Machine%0A%20%20-%20entity%3A%20sensor.dishwasher_power%0A%20%20%20%20name%3A%20Dishwasher%0A%20%20-%20entity%3A%20sensor.oven_power%0A%20%20%20%20name%3A%20Wall%20Oven%0A%20%20-%20entity%3A%20sensor.cooktop_power%0A%20%20%20%20name%3A%20Induction%20Cooktop%0A%20%20-%20entity%3A%20sensor.ice_machine_power%0A%20%20%20%20name%3A%20Ice%20Machine%0Amin%3A%200%0Amax%3A%204000%0Apositions%3A%0A%20%20icon%3A%20'off'%0A%20%20indicator%3A%20null%0A%20%20name%3A%20inside%0Aseverity%3A%0A%20%20-%20color%3A%20Red%0A%20%20%20%20from%3A%202500%0A%20%20%20%20to%3A%205000%0A%20%20-%20color%3A%20orange%0A%20%20%20%20from%3A%201500%0A%20%20%20%20to%3A%202499%0A%20%20-%20color%3A%20green%0A%20%20%20%20from%3A%201000%0A%20%20%20%20to%3A%201499%0A%20%20-%20color%3A%20null%0A%20%20%20%20from%3A%20100%0A%20%20%20%20to%3A%20999%0A%20%20-%20color%3A%20'n'%0A%20%20%20%20from%3A%20-5%0A%20%20%20%20to%3A%2015%0Asort%3A%0A%20%20-%20position%3A%20null%0A%20%20%20%20from%3A%204000%0A%20%20%20%20to%3A%200%0Acolumns%3A%201%0Alimit_value%3A%20true%0A
Don’t use the copy button in the three dots icon at the bottom of the card.
Click in the yaml view of the card then Ctrl + A to select everything, then Ctrl + C to copy the YAML, then Ctrl + V to paste in the forum. You can also probably do all that with your right click context menu in your web browser instead of the keyboard shortcuts.
I’m actually on my phone, I already tried highlighting all then copy, then paste, if I paste it into a note pad, it looks ok but not tabbed correctly as yaml looks, yet while the copy is still saved in the phones clip board, I paste the same info here, and I get what you can see above? It’s an iPhone I’m on, is there some other way to do it, the yaml is too long for a single screenshot?
Cheers
Do not post screenshots. We can not easily edit them to help you like we can with yaml.
Yeah it won’t work from your phone, use a desktop PC.
Make sure there is a blank line above and below your code and include them in the marking before clicking the </> icon
Nah it’s not that. Copying from the HA app copies as percent encoded for some reason (at least it does on iOS).
Thanks, did it fro PC when I got home.
Any help re auto sorting fro highest real time on yp to lowest on the bottom would be much arreciated I’m a bit stuck with that bit>
Cheers for anyone’s help.
I use the third party auto-entities card to do that, pretty sure it won’t work with bar card though:
type: custom:auto-entities
card:
  type: entities
  title: Currently Drawing Power
filter:
  include:
    - entity_id: sensor.*_power
  exclude:
    - state: '0.0'
    - state: '-0.0'
    - state: '0'
    - state: '-0'
    - entity_id: sensor.*grid*
    - entity_id: sensor.*lp20*
    - entity_id: sensor.*sb6*
    - entity_id: sensor.import
    - entity_id: sensor.self_total
    - entity_id: sensor.*solar*
    - entity_id: sensor.*ups_*
sort:
  method: state
  numeric: true
  reverse: true
Here is how it will work with the Bar-Card
The sort is based on the “method: state” - as that is the state of the entity
My bar-card has some additional code to make it pretty - so the content under “card-mod” can be omitted -
card:
  title: ''
  width: null
  icon: mdi:battery
  align: split
  columns: 1
  decimal: ''
  height: 30
  max: 100
  unit_of_measurement: '%'
  animation:
    state: 'off'
    speed: 2
  severity:
      to: '20'
      color: red
      to: '40'
      color: orange
      to: '49'
      color: yellow
      to: '100'
      color: green
      hide: false
  card_mod:
    style: |-
      bar-card-value {
        margin-right: 25px;
        font-size: 13px;
        font-weight: bold;
      bar-card-backgroundbar {
       border-radius: 12px;
       margin-top: 9px;
       background: grey;
       opacity: 50%;
      bar-card-currentbar {
      margin-top: 9px;
      bar-card-contentbar {
        margin-top: 9px;
        margin-left: 8px;
entities: []
sort:
  method: state
  numeric: true
  reverse: false
filter:
  include:
    - entity_id: sensor.*battery
  exclude: null
Yeh thanks tom_I, I got it working with custom bar card as well including severity coloring as well, but wanted to wait till I got hoe to be able to copy the yaml to this reply. Also attached is a screen shot. The only thing left to try and clean it up is some kind of exclusion for states of 0 to 15w so that items dont show up with just noise of 3.2w and 8w, but all in all, seems to work well.
Doh! light in my head just switched on, I was over thinking it, rathe than trying to exclude a range from 0.1 to 15.0, I just added this - state: ‘>15’ in the exclusions list to eliminate any sensors with insignificant readings becoming visible. So now its doing everything I wanted it to do. Thanks to all the responces.
filter:
  include:
  exclude:
    - state: '0.0'
    - state: '-0.0'
    - state: '0'
    - state: '-0'
    - state: '>15'
    - entity_id: sensor.energy_monitor_channel_1_power
    - entity_id: sensor.energy_monitor_channel_2_power
sort:
  method: state
  numeric: true
  reverse: true
card:
  min: 0
  max: 4000
  severity:
    - color: Red
      to: 5000
    - color: orange
      to: 2499
    - color: green
      to: 1499
    - color: null
      to: 999
    - color: 'n'
      to: 15
  limit_value: true
  positions:
    icon: 'off'
    indicator: null
