Auto-Update ESPHome Devices After Add-On Update
:arrows_counterclockwise: Blueprint: Auto-Update ESPHome Devices After Add-On Update
:warning: USE AT YOUR OWN RISK
Firmware updates — especially automated ones — can occasionally break ESPHome devices.
In rare cases, devices may become unavailable, fail to boot, or even become permanently unresponsive depending on hardware, flash health, or power stability during the update.
Make sure you have physical access to your ESPHome devices and that you can connect them via USB if recovery is needed.
This blueprint only automates the update trigger — it cannot prevent firmware-related issues caused by the update itself.
:pushpin: Description
This blueprint automatically updates all your ESPHome devices right after the ESPHome add-on itself gets updated.
It removes the need to manually check each device for firmware updates whenever the add-on updates.
Here’s what it does:
  • Monitors the installed_version attribute of the update.esphome_update entity.
  • When the add-on updates, it waits for a configurable delay.
  • Scans all ESPHome update entities (update.*) and selects only those:
    :heavy_check_mark: that belong to ESPHome
    :heavy_check_mark: that report an update available
    :heavy_check_mark: that are not already in updating state
  • Sends a persistent notification listing all ESPHome devices that will be updated.
  • Updates the devices sequentially, with a configurable pacing delay between updates.
  • Sends a final persistent notification listing all devices that were successfully updated.
Everything runs hands-free — once configured, it just works.
:hammer_and_wrench: How it works
  1. Import the blueprint using the button below.
  2. Create an automation using this blueprint.
  3. Configure two parameters:
  • Delay after add-on update – waiting time before scanning ESPHome devices.
  • Pacing between installs – seconds to wait between sequential firmware updates.
  1. Whenever the ESPHome add-on updates, the automation triggers automatically.
  2. It sends a notification, performs updates one by one, then sends a final summary.
:bell: Notifications
This blueprint uses persistent notifications inside Home Assistant:
  • Before updates begin:
    Lists all devices that will be updated.
  • After updates finish:
    Lists all devices that were actually updated.
This keeps you fully informed without manual checking.
:star: Benefits
  • Fully automated firmware updates for ESPHome devices after the add-on updates.
  • Prevents forgetting to update individual devices.
  • Safe sequential updating prevents congestion or connection issues.
  • Clean notifications before and after the process.
  • Zero maintenance once set up.
:warning: Notes & Recommendations
  • Ensure your ESPHome devices expose an update.* entity (default behavior).
  • The automation mode is single — repeated triggers won’t overlap.
  • If you have many ESPHome devices, start with a longer pacing delay.
  • Review firmware changes if you run critical devices.
:inbox_tray: Install the Blueprint
Click below to import directly into Home Assistant:
Import blueprint to Home Assistant
:heart: Support
If this blueprint helped you, a GitHub star would be greatly appreciated:
:arrow_right: GitHub - zenguru84/my-ha-toolbox: Reusable things for Home Assistant
And if you want to buy me a beer, you can do it here :beer::point_down:
:arrow_right: https://www.buymeacoffee.com/zenguru84
Enjoy your automated ESPHome updates! :rocket:
While i appreciate your work i can’t help wondering (just a friendly reminder for all users, i mean nothing bad) …i hope that you are aware of danger part of such a blueprint? There are breaking things often in new esphome versions which MUST be read BEFORE you do any update since they can break your devices (render them useless or unavailable). Often some parts of code must be changed, removed, added… while some of these devices are easily accessible and flashable via USB some aren’t (like glued shelly’s etc…) so this can actually sends such device directly to special waste bin.
Not to mention that there’s also a couple of times mentioned golden rule: “don’t repair if it ain’t broken”. Don’t update if nothing has changed for your device program, since nothing WILL be changed apart version number.
You are right. Thanks!
I will include something about this in my post.
I have lots of ESPHhome devices and never had a situation like you described above. Not saying it’s not possible to happen, just never happen to me.
I have this at almost every major update. Especially a lot after the recent idf change…
@sender you have what? “bricked” devices after updates?
I think regularly updates lower the chances of breaking things.
I also update my devices regularly, but it’s quite annoying to click each one individually. Thank you for creating the blueprint.
@eigger with pleasure! :slight_smile:
use it wisely!
Yes and yes
None of my devices has been bricked due to updates since I stopped updating them.
But when I did update them, they got bricked and had issues caused by the updates.
You are gambling with your setup, just because it hasn’t happened yet doesn’t mean it won’t happen.
And when it will happen then thanks to your blueprint, it will happen on all devices at the same time.
@Hellis81 you just proved my point.
if you skip tens of updates, and then you decide to update, chances to brick something are high. and hard to fix, because the cause can reside in any of the skipped updates. :slight_smile:
QED
i’ll use it at my own risk. i can physically connect to any of my devices in no time.
Use wisely is an impossible suggestion. You use it and pray it does not break things, or you do not use it and be safe about it.
I agree with Herllis81 auto updates on all devices at once is a big risk. Look at yesterdays release notes and see how much changed. It may all work, it may not.
What I do is check release notes first. If I feel there’s not much in it for me I skip all update using a script (see below). If they are nice, I try one or two that are lower risk and can alert me to possible problems. If some are still scary, I skip those ESP’s. for the ones I do want to update, I run another script to update the esps that were not marked as skipped:
Skip all ESP updates:
alias: Skip all ESP updates
sequence:
  - action: update.skip
    metadata: {}
    data: {}
      entity_id: >-
        {{ states.update | selectattr('attributes.title','eq','ESPHome') |
        selectattr('state','eq','on') | map(attribute='entity_id') |
        reject('eq','update.esphome_update') | list }}
description: ""
icon: mdi:memory
No longer skip the ESP updates that I previously skipped:
alias: Unskip all ESP updates
sequence:
  - action: update.clear_skipped
    metadata: {}
    data: {}
      entity_id: >-
        map(attribute='entity_id') | reject('eq','update.esphome_update') | list
description: ""
icon: mdi:memory
Install all ESP updates that are not skipped:
alias: Install all non-skipped ESP updates
sequence:
  - action: update.install
    metadata: {}
    data: {}
      entity_id: >-
description: ""
icon: mdi:memory
These scripts require the firmware update entities to be enabled, they are not by default.
I believe you did not understand my post then…
Sadly it’s rather other way around… Each programming of esp can go wrong at any time, even if program is ok… Devs, and also many others often point out that it’s IMPERATIVE to read changelog in detail BEFORE doing ANY update (valid for HA and addons also!!!).
But, as said many times already, many (if not majority) never does that, but rather ask for their problems here afterwards… And this blueprint quite nicely bypasses exactly this most important part: reading the changelog. Then number of questions like “my esp doesn’t work after update” then rises above acceptable, consequently same and same answers are given hundreds of times… (as those people many times also don’t use search much to find already answered problems).
Think this way: say that you have version, say, “a” and in your esp you have one i2c sensor for temperature/humidity. Now, version “b” is different from version “a” in, say, modified switch configuration, but it doesn’t touch sensor or i2c part nor wifi, ap… When/if you update code for i2c and sensor is exactly the same - down to the last bit. So, apart from time wasted you only needelssly wear out flash and risk of something going wrong, nothing else. Oh, yeah, there IS one “plus”: shiny new and latest esphome version number…
Some of my esp’s still run 2023 code… and they work flawlessly.
As “sender” said: latest idf changes “bricked” quite some esp’s… there were quite some questions here about that (because people didn’t read changelog before doing update). Then there were changes in type naming, like in template: bme280 → bme280_i2c and similar.
You completely turned around hellis’s point… .again, it’s quite contrary: when - after long time - you decide to update certain esp you do that not because “you feel like it” but because you add or modify something. In this case compiler will warn you that things aren’t ok (anymore) and you’ll be forced to correct them BEFORE esp will be updated. So, no bricked devices.
After all-… do you take your car to a service when service buys some new shiny tool or when your car needs it?
Even if I want to change something after a long time, then I use legacy ESP Home to make sure I do not get in to issues.
Only on devices that it doesn’t really matter do I update.
Like bluetooth proxys, they only do that and if they break then I just recreate it with the new code.
But updating my old devices from several years ago, no way!
They work fine the way they do. There is no reason for me to update them.
guys, you are totally right, and i’m sure you had those bad experiences.
i’ll continue to use this blueprint, and if i’ll run into issues, i’ll fix them.
if there is anyone thinking like me on the subject, they’ll use it too. :slight_smile:
I thought this blueprint was a great idea that solves a real problem, but it needed some guardrails.
I made an automation based on this excellent blueprint:
alias: ESPHome Update with Approval
description: Notify when ESPHome updates, wait for approval before updating devices
mode: single
triggers:
  - alias: ESPHome add-on version changed
    trigger: state
    entity_id: update.esphome_device_builder_update
    attribute: installed_version
conditions:
  - alias: Version actually changed (not just attribute refresh)
    condition: template
    value_template: |
      {{ trigger.from_state is not none and trigger.to_state is not none
         and (trigger.from_state.attributes.installed_version | default('')) !=
             (trigger.to_state.attributes.installed_version | default('')) }}
actions:
  - alias: Reset changelog reviewed flag
    action: input_boolean.turn_off
      entity_id: input_boolean.esphome_changelog_reviewed
  - alias: Wait for HA to detect available device updates
    delay:
      minutes: 5
  - alias: Gather update info and pending devices
    variables:
      new_version: >-
        {{ state_attr('update.esphome_device_builder_update',
        'installed_version') }}
      changelog_url: https://github.com/esphome/esphome/releases/tag/{{ new_version }}
      to_update: |
        {{ integration_entities('esphome')
           | select('match', '^update\\.')
           | reject('is_state_attr', 'in_progress', true)
           | select('is_state', 'on')
           | list }}
  - alias: Only proceed if devices need updating
    if:
      - condition: template
        value_template: "{{ to_update | count > 0 }}"
        alias: If 1 or more devices can be updated
    then:
      - alias: Show notification with changelog and dashboard links
        action: persistent_notification.create
          notification_id: esphome_update_approval
          title: 🔄 ESPHome {{ new_version }} Available
          message: >
            {{ to_update | count }} device(s) ready to update.
            [📋 Changelog]({{ changelog_url }}) · [⚙️ Review &
            Approve](/dashboard-esphome/0)
      - alias: Wait for approve/skip button or 24h timeout
        wait_for_trigger:
          - alias: Approve button pressed
            trigger: state
            entity_id: input_button.esphome_update_approve
          - alias: Skip button pressed
            trigger: state
            entity_id: input_button.esphome_update_skip
        timeout:
          hours: 24
        continue_on_timeout: true
      - alias: Clear the approval notification
        action: persistent_notification.dismiss
      - alias: Handle user response
        choose:
          - alias: User approved - run updates
            conditions:
                value_template: >-
                  {{ wait.trigger and wait.trigger.entity_id ==
                  'input_button.esphome_update_approve' }}
            sequence:
              - alias: Show in-progress notification
                  notification_id: esphome_update_status
                  title: ⏳ ESPHome Update In Progress
                  message: Updating {{ to_update | count }} device(s)...
              - alias: Update each device with pacing delay
                repeat:
                  for_each: "{{ to_update }}"
                  sequence:
                    - alias: Install update on device
                        entity_id: "{{ repeat.item }}"
                    - alias: Brief pause before next device
                      delay:
                        seconds: 10
              - alias: Show completion notification
                  title: ✅ ESPHome Update Complete
                  message: "{{ to_update | count }} device(s) updated."
        default:
          - alias: Handle timeout vs manual skip differently
            choose:
              - alias: Manual skip - mark updates as skipped
                conditions:
                    value_template: "{{ wait.trigger is not none }}"
                sequence:
                  - alias: Show skipped notification
                      title: ⏭️ ESPHome Update Skipped
                      message: Skipped by user.
                  - alias: Mark all pending updates as skipped
                    repeat:
                      sequence:
            default:
              - alias: Timeout - just notify, don't skip
                  title: ⏭️ ESPHome Update Timed Out
                  message: No response after 24h. Updates still pending.
Then I made an ESPHome Update Approval dashboard, that links to the appropriate changelog:
  - title: Home
    sections:
      - type: grid
        cards:
          - type: vertical-stack
            cards:
              - type: markdown
                content: >
                  {% set version =
                  'installed_version') %} {% if version %}
                    {% set parts = version.split('.') %}
                    {% set changelog_version = parts[0] ~ '.' ~ parts[1] ~ '.0' %}
                    ## [📋 ESPHome {{ parts[0] }}.{{ parts[1] }} Changelog](https://esphome.io/changelog/{{ changelog_version }}/)
                  {% endif %}
              - type: entities
                entities:
                  - entity: input_boolean.esphome_changelog_reviewed
                    name: I've reviewed the changelog
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  type: horizontal-stack
                  cards:
                    - type: button
                      icon: mdi:check-circle
                      tap_action:
                        action: call-service
                        service: input_button.press
                    - type: button
                      icon: mdi:skip-next
                      tap_action:
              - type: custom:auto-entities
                card:
                  type: entities
                  title: Pending Updates
                filter:
                  include:
                    - integration: esphome
                      domain: update
                      state: 'on'
    header: {}
The end result is I get a persistent notification when there is a new version, with a button that links to my approval dashboard. The approval dashboard has the link to the changelog for easy review. After I acknowledge that I have reviewed the changelog, I can then choose to update all the devices or skip the update for all devices with one click. I haven’t tested thoroughly but it worked for 2025.12.2 updates today. Thanks again for the great work on the initial blueprint!
