Auto-update ESPHome Devices via Automation
Hi all,
with the recent implementation of updating ESPHome devices within HA, this is a welcomed feature for me as I have 8 devices, and sometimes it can take about 1.5 hrs for it to finish.
Making an automation for this would be a great solution.
I created a basic automation that checks every mid-night if there is an update available for each of my BT Proxies, send a message that there is and then another when its complete.
However, there is a problem with this below, because updating should happen 1 after the other, and not all at once.
UPDATE: this is now updated to include the repeat until done. Thanks @TheFes
UPDATE2: adding the global condition, will prevent this from sending you a message every day
alias: Automatically update ESPHome Devices
description: >-
  Automatically update ESPHome Devices at midnight, and notify when they are
  updated.
  - platform: time
    at: "00:00:00"
  - platform: state
    entity_id:
      - update.esp32_bluetooth_proxy_299fcc_firmware
      - update.esp32_bluetooth_proxy_4ca0c4_firmware
      - update.esp32_bluetooth_proxy_5a63a8_firmware
      - update.esp32_bluetooth_proxy_5f189c_firmware
      - update.esp32_bluetooth_proxy_4ca434_firmware
      - update.esp32_bluetooth_proxy_4cae58_firmware
      - update.esp32_bluetooth_proxy_5e9b38_firmware
      - update.esphome_web_5bdf28_firmware
    to: "off"
  - platform: event
    event_type: timer.finished
    event_data:
      entity_id: timer.esphome_updates_timer
condition:
  - condition: state
    entity_id:
    match: any
    state: "on"
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          # Start a watch-dog timer to make sure things get done.
          - service: timer.start
              duration: 0
          - service: notify.mobile_app_sony_xperia_zx1
              title: ESPHome Devices
              # Pick any ESPHome device below to get the version numbers in your message.
              message: >-
                Your ESPHome devices will now be updated from {{
                state_attr("update.esp32_bluetooth_proxy_299fcc_firmware",
                "installed_version") }} to {{
                "latest_version") }}.
          - alias: Update all ESPHome devices in sequence
            repeat:
              for_each: >-
                {{ states.update | selectattr('state', 'eq', 'on') |
                map(attribute='entity_id') | select('in',
                integration_entities('esphome')) | list }}
              sequence:
                - service: update.install
                    entity_id: "{{ repeat.item }}"
                - wait_template: "{{ is_state(repeat.item, 'off') }}"
      - conditions:
        sequence:
          - service: timer.cancel
            data: {}
              message: >-
                Your ESPHome devices are now all updated to {{
                "installed_version") }}.
      - conditions:
         # In-case the update failed
        sequence:
              message: >-
                There was a problem updating to  {{
                "latest_version") }}. Please check your ESPHome Addon.
mode: single
Wow man, thanks for that. Will fire it tonight the first time. Just saw the new mechanism to update the devices and looked for a solution.
I´ve also the problem that my Dell/ Wyse 5040 needs ages for compiling.
Thanks again!
Yes it’s very useful.
Make sure you have auto update on the ESPHome add-on, and you’ll also have to make a timer via the helpers if you want the Watchdog timer to work. I would set it up to however long it takes to update all your boards plus 40 minutes or however way you like it.
Cheers
I get a message that in need repair my automation because this service is invalid.
Hmm, the service itself is native to HA core. Try in developer tools.
You did make a timer in the helpers, right?
I created the timer:
With a different name :slight_smile: and updated the automation.
timer.helpers_esphome_updater
Home Assistant 2023.2.5
Supervisor 2023.01.1
Operating System 9.5
Frontend 20230202.0 - latest
ahh, ok, got it.
Interesting how I don’t have this repair warning helper but, it should be:
timer.cancel
I’ve updated the above automation.
data: {}
This Blueprint will handle ESPHome updates:
Could the entities be made dynamic? The following template lists the relevant entities (very rough)
{{ states.update
  | selectattr('entity_id', 'match', '\w+.\w+_firmware')
  | selectattr('state','eq','on')
  | map(attribute ='entity_id')
  | list
That is feasible, but why don’t you want to update other entities automatically?
If you take a look at this most recent version of this Blueprint, you can filter out Core updates… isn’t that enough?
Maybe I can create a session specifically for devices’s firmwares (I would like more to use device_class: firmware instead of text searching, as that can be changed by users), with similar options like the Core items… I’m just afraid that too many settings (add-ons, HACS, etc.) will make it cumbersome to setup for entry level users.
How about this point of view to the automation?
I created a group with all my esphome entities in it.
When a esphome entity have an update the group goes ON. Then the repeat start.
When all entities are updated and go off the group goes off… Then it will send a done notification.
I have automation updated. I think this will work.
Here is my automation:
# ESPHOME UPDATER
- id: "793aebec-d390-4a9c-8f2c-725283c2853f"
  alias: "System - Automatically update ESPHome Devices"
  mode: single
    - platform: time
      at:
        - "09:00:00"
        - "12:00:00"
        - "15:00:00"
    - platform: state
      entity_id: group.helpers_esphome_updates
      to: "on"
    - platform: state
      to: "off"
  condition: []
    - choose:
          # When platform time is fires
        - conditions:
          sequence:
            - service: script.mobile_notify_no_actionable
                title: "System - ESPHome Devices"
                message: >-
                  state_attr("update.meek_toilet_firmware",
                thread_id: "esphome_updater"
            - repeat:
                for_each: >-
                sequence:
          # When devices are updated
        - conditions:
          sequence:
              data: {}
                entity_id: timer.helpers_esphome_updater
                message: >-
          # Will fire when time_pattern start and group is still on
        - conditions:
            - "{{ is_state('group.helpers_esphome_updates', 'on') }}"
          sequence:
                message: "If one or more devices didnt update well, now they are"
            - repeat:
                for_each: >-
                sequence:
That works well also!
I’m actually experiencing an issue at the moment with the ESPHome firmware update entities becoming unavailable
So my automation is not working right now because these entities are the triggers.
This is issue has been reported already by others and myself. If you are experiencing the same problem, check out the issue here and feel free to add something if it was not already mentioned.
I had same but only when HA was restart and ESPhome devices not connected yet via API
I use many ESPhgome switches. So when they become online they trigger some automations.
For those automations that fit on ESPhome states I add this condition to all of the automations:
  condition:
    - "{{ not (to_state == 'on' and from_state == 'unavailable') }}"
    - "{{ not (to_state == 'off' and from_state == 'unavailable') }}"
    - "{{ not (to_state == 'unavailable') }}"
This did the job and everything works perfect
So, I’ve added support for selecting between “All”, “Patches only” or “Don’t update” for Core items, devices firmware and everything else, so now you can select exactly what you want to update.¨
Please let me know if you have any issues.
The code is on Github:
My take on using jinja filters on the updater.state and in_progress attributes. All my nodes are named node** (i.e. node01, node12, etc.) and have entity ids updater.node**_firmware. First time doing this, and it looks a little too short! :sweat_smile: Can anyone point out some missed considerations?
- alias: Update ESPHome nodes
  - platform: time_pattern
    hours: '3'
    minutes: '*'
  condition:
  - "{{ states.update | selectattr('entity_id', 'match', 'update\.node\d+_firmware')
    | selectattr('state', 'eq', 'on') | list | count > 0 }}"
    | selectattr('attributes.in_progress') | list | count == 0 }}"
      entity_id: "{{ (states.update | selectattr('entity_id', 'match', 'update\.node\d+_firmware')
        | selectattr('state', 'eq', 'on') | first).entity_id }}"
  mode: single
Here is my take :grinning:
The script takes two parameters:
integration: Integration for which update-entities should be filtered like hassio, hacs, fritz, shelly, esphome
action: either install or skip
  sys_update:
# platforms: shelly, esphome, hacs, fritz, hassio
    sequence:
      - variables:
          updates: |
            {{ expand(integration_entities(integration)
                | select('match','update.'))
               | selectattr('attributes.in_progress','eq', false)
               | selectattr('attributes.latest_version','ne','attributes.skipped_version')
               | list
      - service: "update.{{action}}"
          entity_id: "{{ updates }}"
      - wait_template: "{{ expand(updates) | selectattr('attributes.in_progress','eq', true) | list | count == 0 }}"
      - service: script.notify
            type: "text"
            severity: "info"
            target: "sys"
            notification_id: "update"
            title: "Updates {{action}}ed"
            message: |
              (*{{ states('sensor.date_time') }}*)
              {% if updates | count > 0 -%}
                Die Updates für **{{integration}}** wurden auf den folgenden Geräten **{{ iif( action == 'skip', 'übersprungen', 'installiert') }}**:
                 - {{ updates | join('\n - ') }}
              {% else -%}
                Keine Updates fĂĽr **{{integration}}** gefunden
              {% endif %}
Of course you can call this script with whatever trigger in an automation:
service: script.sys_update
  integration: shelly
  action: skip
My only consideration is that you are calling all the updates at the same time. This is not wrong, but you should take a look on how will be your system’s resources (CPU, memory, CPU temperature, etc) when you call dozens of updates at the same time. Maybe not a big problem when you are just updating firmware of a device where HA is not very much involved, the device is handling most of the load, then it’s probably ok, but if HA host machine have something to do (ESPHome?) then it could be an issue.
Or maybe you create a repeat loop and call the updates one by one. It might take a bit longer, but that is probably ok in most cases.
The ESPhome updates are installed sequentially, even if you call the update service with a list of entities, just how the “update all” on the ESPHome interface works.
I understand that is the case when you click in the “Update all” button, but are you sure this is the case when you all the update service and add all the ESPHome in the entity list? In my understanding most of the services runs almost a parallel call to multiple entities, so are you sure there is an exception for the update service when addressing ESPHome updates?
If they are sequential, then you are probably ok, but if they try to update in parallel, then it can be an issue.
Yes, I am sure, had plenty of opportunity lately :smiley:
I get notified, when a device reboots, and they do one after the other with ample time between them.
