Autocomplete in File Editor
Since over a year ago, HA has autocomplete/autofill of entities, services, etc. mostly everywhere.
However, File Editor doesn’t.
I know that Visual Studio exists and I’ve had it in the past (found it slow and excessive for my usage), but I find it weird that File Editor doesn’t.
Is there any limitation for File Editor, or it just hasn’t been implemented?
Thank you
It just hasn’t been implemented. Although I also think it could be tricky to implement. In any case, it’s an external project, so the correct place for the issue would be here: GitHub - danielperna84/hass-configurator: Configuration UI for Home Assistant
As I am the maintainer I can state right away, that I don’t have the time to do this. But as it’s Open Source, someone else can have a try with it.
