I spent a lot of time working on this, so I thought I would share.
I have two entrances to my place, a garage door (connected via MQ and appears as a cover) and my front door, which uses a Schlage Z-wave device. When the front door has been opened, I would like it to automatically lock after a few minutes. However there are times of the week when I’m doing work outside, or have workers at the house where this quickly became a pain in the neck. So I wrote this “AutoLock” function that is initially in the “on” state meaning it will automatically lock or notify me when a specified device has been left open. When I turn AutoLock “off” usually by voice or google assistant, locking and notification stops for 8 hours.
The original code I wrote had another slight annoyance. I liked to have the front door lock after 15 minutes, but my wife wanted it to lock after 5 minutes. So we came up with a compromise. During daylight hours the front door locks after 15 minutes, and in periods of dark, it locks after 5 minutes.
I’ll break down the code via the files I created.
timers.yaml
Create this file and add the following to your configuration.yaml via
timer: !include timers.yaml
This defines three timers (and default values) for how long the garage remains opened before sending a notification. Note, the front_door timer doesn’t have a default value for the timer, as that is selected in a script. The auto_lock_disable defines how long before AutoLocking resumes.
garage_door:
duration: '00:15:00'
front_door:
auto_lock_disable:
duration: '08:00:00'
Add the following to your scripts.yaml. You can modify the day/nighttime door lock values by changing the 00:15:00
and 00:05:00
accordingly. This script simply starts the front door timer, but uses dusk and dawn values to determine how long the timer should last.
start_front_door_custom_timer:
sequence:
- service: timer.cancel
entity_id: timer.front_door
- service: timer.start
data_template: # if next_dusk happens sooner than next_dawn, then (next_dusk - next_dawn) < 0
duration: >
{% if ((((as_timestamp(states.sun.sun.attributes.next_dusk)) - (as_timestamp(states.sun.sun.attributes.next_dawn)))) < 0) %}
00:15:00
{% else %}
00:05:00
{% endif %}
AutoLock.yaml
Note: You will need to create an input_boolean named autolock
which you can connect to the personal assistant of your choice to enable/disable autolocking
- alias: Front Door Unlocked
entity_id: lock.schlage_be469_touchscreen_deadbolt_locked_2
platform: state
to: unlocked
condition:
condition: state
entity_id: input_boolean.autolock
state: 'on'
- service: script.turn_on
entity_id: script.start_front_door_custom_timer
- alias: Front Door Locked
platform: state
to: locked
- alias: Lock Timer Finished
platform: event
event_type: timer.finished
event_data:
condition:
condition: state
state: 'on'
service: lock.lock
- alias: autolock finished
platform: event
event_data:
entity_id: timer.auto_lock_disable
service: input_boolean.on
- alias: Disable Auto Lock
platform: state
to: 'off'
entity_id:
- timer.garage_door
- timer.front_door
- alias: Enable Auto Lock
platform: state
to: 'on'
entity_id:
- timer.garage_door
- timer.front_door
- timer.auto_lock_disable
- service: lock.lock
- service: cover.close_cover
entity_id: cover.garage_door_opener
- alias: Toggle Front Door
platform: webhook
webhook_id: !secret frontdoor_token
service_template: >
{%- if is_state('lock.schlage_be469_touchscreen_deadbolt_locked_2', 'locked') -%}
lock.unlock
{%- else -%}
lock.lock
{%- endif -%}
GarageTimer.yaml
I don’t want the garage closing automatically, so instead I send a message to IFTTT which will then trigger a notification to my phone. I could have done this with other HA notification components, but I already had this working for my ISY hub, so why reinvent the wheel?
- alias: Garage Opened
hide_entity: True
- platform: state
to: 'open'
condition:
- condition: state
state: 'on'
entity_id: timer.garage_door
- alias: Garage Closed
hide_entity: True
- platform: state
to: 'closed'
- alias: Garage Opened Timer Finished
hide_entity: True
- platform: event
event_data:
condition:
- condition: state
state: 'open'
- condition: state
state: 'on'
- service: ifttt.trigger
data: {"event": "GarageLeftOpened"}
