Automatation Match mqtt dimmer to light
Hey guys,
i am going a bit crazy and tried to adapt some of the automations …but with no luck.
I have a tradfri dimmer which i want to match with one of my lights… I created this automation for this:
- id: '1566242994281'
  alias: Ikea
  - platform: mqtt
    topic: zigbee2mqtt/0x000b57fffe728_brightness
  condition: []
  service: light.turn_on
  entity_id: light.wand
  data_template:
    brightness: state_attr(0x000b57fffe728_brightness','brightness')
could you give me a hint why I get a error in the log like :
Error while executing automation automation.ikea. Invalid data for call_service at pos 1: expected int for dictionary value @ data['brightness']
every info is much appreciated!
Correct way to structure a template:
  data_template:
    brightness: "{{ state_attr('0x000b57fffe728_brightness','brightness') | int }}"
But that won’t work. 0x000b57fffe728_brightnes is not an entity id. You need to extract the brightness from trigger.payload
If the payload is an integer this should work:
  data_template:
    brightness: "{{ trigger.payload }}"
But without knowing what the message sent to the topic looks like this is just a guess.
Hey thanks for the fast reply!
I adjusted the template but still there is no effect
- id: '1566249261533'
  alias: Ikea off
    platform: state
    entity_id: sensor.0x000b57fffe72fbd8_brightness
  condition:
    condition: template
    value_template: "{{  trigger.payload|int == 0 }}}"
    service: light.turn_off
    entity_id: light.flur_unten
- id: '1566249317287'
  alias: Ikea on
    platform: state
  condition:
    condition: template
    value_template: "{{ trigger.payload|int != 0}}"
    data_template:
      brightness: "{{ trigger.payload|int}}"
And in the Logfile this apears any time I trigger the dimmer:
2019-08-20 22:03:02 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'dict object' has no attribute 'payload'
That’s because you changed this:
    platform: mqtt
to
    platform: state
"{{ trigger.payload }}"only works with the mqtt trigger.
If you are going to use the state trigger use this template:
  data_template:
    brightness: >
      {{ state_attr('sensor["0x000b57fffe728_brightness"]','brightness') | int }}
Square brackets are required because your object id begins with a number. https://www.home-assistant.io/docs/configuration/templating/#entity_id-that-begins-with-a-number
Okay sounds like I owe big pint …and… Iam gettin really confused with the automation
I guess I will stick to the mqtt plattform because many other devices in my setup are running with mqtt.
therefore i used this code… because lucky me … i realized …i was wrong with the mqtt topic … but i corrected it and adjusted it but at least no error so far… and no reaction
  alias: Ikea off
  - payload: brightness
    platform: mqtt
    topic: zigbee2mqtt/0x000b57fffe72fbd8
  condition:
  - condition: template
    value_template: '{{trigger.payload|int ==0}}}'
  - data:
  alias: Ikea on
    platform: mqtt
  condition:
    value_template: '{{trigger.payload|int != 0}}'
  - data:
    data_template:
      brightness: '{{ trigger.payload|int}}'
But i guess i did there something wrong because in home assistant it self the output is diffrent.
here the example for the ikea on example:
further I double checked with mqtt that i got the right topic in mqtt:
I think I still can’t match the mqtt info of the brightness to the brightness of the lamp … I feelin really dump at this task ^.^
Your patience is really appreciated!
