I’m not quite getting multiple conditions and given some of these take a lot of time to test (waiting for temperatures to rise, or other state changes) I’m struggling to successfully test and get working a simple automation to turn off my dryer.
I am using conditions of:
- temp reaches a set high
- humidity reaches a set low
- dewpoint reaches a set low
- dryer has been on at least 1 minute
I am making sure the dryer is on for a set period to at least give the sensor (which is at the dryer exhaust and susceptible to the natural environment) some time to adjust to the internals of the dryer.
My first attempt was to set the trigger as the dryer turning off and the fact none of the other conditions were met, it kept going (as intended) but then the automation never fires again.
I tried changing the mode to restart and queue, but that didn’t do it.
In the end what I did was to set everything as a trigger AND a condition, so that any one of the triggers activated the test against the conditions and if they are all met, the dryer is turned off.
I have seen others create scripts and variables and multiple sets of instructions, but I felt there must be a simpler approach.
I think what I have here now is right, but any improvements would be appreciated.
I’m waiting for this load to finish, but I think I have finally got it right.
alias: Turn the Dryer off
description: ''
- type: temperature
platform: device
entity_id: sensor.laundryth833_am2301_temperature
domain: sensor
above: 40
- type: humidity
platform: device
entity_id: sensor.laundryth833_am2301_humidity
domain: sensor
below: 30
- type: value
platform: device
entity_id: sensor.laundryth833_am2301_dewpoint
domain: sensor
below: 25
- platform: device
type: turned_on
entity_id: switch.laundryth833_laundry
domain: switch
for:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
condition:
- condition: device
type: is_on
domain: switch
for:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- type: is_value
condition: device
domain: sensor
below: 20
- type: is_humidity
condition: device
domain: sensor
below: 30
- type: is_temperature
condition: device
domain: sensor
above: 45
- type: turn_off
domain: switch
mode: restart
In reading this now as submitting it, I suppose the trigger could just be a timed event and a first condition is that the dryer is on? I don’t really want the test to be checking if the dryer wasn’t on to begin with.
