Deno is a new JavaScript and TypeScript runtime. It runs on Windows/Mac/Linux and is easy to install because it is just a single executable.
I wrote some helper methods to make it easy to connect to Home Assistant, stream the latest state and use that to automate things. It is available at balloob/home-assistant-deno.
To give a taste of how scripts can look, here is an example script to keep one entity in the opposite state of another:
import { parse } from "https://deno.land/[email protected]/flags/mod.ts";
import {
getConnection,
subscribeEntities,
callService,
HassEntities,
HassEntity,
} from "https://raw.githubusercontent.com/balloob/home-assistant-deno/master/mod.ts";
const args = parse(Deno.args);
if (!args.from || !args.to) {
console.error("Specify both --from <entity_id> and --to <entity_id>");
Deno.exit(1);
const conn = await getConnection();
// light.kitchen -> light
const serviceDomain = args.to.split(".", 1)[0];
let lastState: HassEntity;
subscribeEntities(conn, async (entities: HassEntities) => {
const fromState = entities[args.from];
if (fromState === lastState) {
return;
lastState = fromState;
const serviceName = fromState.state === "on" ? "turn_off" : "turn_on";
await callService(conn, serviceDomain, serviceName, { entity_id: args.to });
Since you write just JavaScript, you can make your scripts as simple or complex as you want.
