Automate Islamic Adhan (also called Azan or Azzan) or other prayer calls - Updated 3_24_2023 for Node-RED
If you are using Google Home Mini, you could also refer to another thread:
Wasallam shamseer.
To create this card it’s simply a Glance card in the Lovelace UI.
Once you have your adhan sensors setup, simply create a lovelace glance card and add the sensors to that.
If you’re referring to the background appearance, I’m just using a different wallpaper for my background.
Assalmu alikum
Thanks for your Reply . I have tried and Success,But cant possible to change background image .
I am not well in coding . if you possible to send me the configuration code it will easy to understand me .
Prayer time
code
type: glance
entities:
  - entity: sensor.fajr_prayer
    format: time
  - entity: sensor.dhuhr_prayer
    format: time
  - entity: sensor.asr_prayer
    format: time
  - entity: sensor.maghrib_prayer
    format: time
  - entity: sensor.isha_prayer
    format: time
title: Prayer Time
I believe you will fix my issue
Walaikum salam.
For lovelace background, I simply have the following line at the top of my lovelace raw config, first line:
background: center / cover no-repeat url("/local/background4.jpg") fixed
You can put your image files into the www folder.
I did not get . When i pasting background config it will effecting all Background .
If you sedn me your code it more help for me
plack prayer
I request you to send me the code for above prayer time .
my code
type: glance
entities:
    format: time
    format: time
    format: time
    format: time
    format: time
title: Prayer Time
background: center / cover no-repeat url("/local/Bed Room.jpg")
Please tell me where i want to add background image code
The line I suggested is for your Lovelace global config, not your card. Doing this line of code will add the background to ALL of your pages in homeassistant.
If you would like to have all your pages with the same background:
  • Place your desired image in the www folder (e.g. 1920x1080 high def background)
  • In your home assistant page, click the ellipsis (3 dots) icon, top right of your page
  • Click the Configure UI selection
Screen Shot 2020-05-10 at 19.32.03
  • Click the ellipsis (3 dots) again, and this time click Raw configuration editor
Screen Shot 2020-05-10 at 19.32.13
  • A code editor will appear. Paste the line of code and hit save.
If you want to have the image for just the one card, you might have to look into using the picture entity card instead:
type: picture-glance
title: Living room
entities:
  - switch.decorative_lights
  - light.ceiling_lights
  - lock.front_door
  - binary_sensor.movement_backyard
  - binary_sensor.basement_floor_wet
image: /local/living_room.png
Thanks for your information and sorry for disturbing you …
The above method i have done all background image .
But i need the background only for the Glance card for prayer time . attaching the sample image .
plack prayer
And i successfully done all background image change with your instruction
Actually i want to change the background of the card only …
Instead of white color on prayer time card want to change
Have a look at the picture-glance card. I posted a link at the end of my post.
I will Try
Assalamualkum
Finally i have changed card background with curved edge through themes.yaml
see screenshot
curved edge
Can someone please help me with this i’m new to this i have no idea what is going on here, i have a google home hub and I’m trying play automatically azan on it
Looking Nice,
How do you connect a TV to home-assistant or to Raspberry PI? I connected A tv to HDMI on the raspberry Pi port and restarted from home assistant but it doesn’t display and dashboard or anything on the display? Any help will be appreciated.
Salaam @shamseer, could you please be so kind and share with us your themes.yaml conf
I like the screenshot
I have tried everything.
Please help.
I would be most grateful if you could kindly help me set up my google nest for adhan automation.
where did you get the id from?
S.A I’ll be more than happy to help. For starters, do you currently have an instance of HA running?
You need the IP address of the Rpi to see the dashboard. if you have a smart tv then you can use the browser to access it. Also, if you have a fire stick you could do that as well, just use a web browser app like silk and navigate to your Pi’s address.
S.A are you currently using home assistant? I’m just trying to figure out where to start. I’ll do my best to help you inshAllah.
Assalamu Alaikum,
Can somebody help me, please? I live in France and I don’t understand why the prayer times don’t correspond to our local calendar the difference is really big it’s not in minutes but in hours !!! I’ve tried every available calculation method without results, an idea ??
Jazakum Allah khayran.
