Automate Islamic Adhan (also called Azan or Azzan) or other prayer calls - Updated 3_24_2023 for Node-RED
Hi guys,
I am new here so need help first of all…everyone done great jobs
so I am looking to display let say fajr time still as true or active in between within until 1 hour after fajr time. so let say it is 6am until 7 am it will show me that still time to pray.
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M,
%Y-%m-%d”)) > as_timestamp(strptime(states(“sensor.dhuhr_prayer”), “%Y-%m-%dT%H:%M:%S”))
thank you for help !!!
Hi Guys, i am a newbie and having issues running the adhaan. Configuration is below:
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: -35.473469
longitude: 149.012375
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 719m
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: List of tz database time zones - Wikipedia
time_zone: Australia/ACT
Customization file
customize: !include customize.yaml
whitelist_external_dirs:
- ‘/config/www’
Show the introduction message on startup.
#introduction:
Discover some devices automatically
discovery:
media_extractor:
#Sensors
Weather prediction
  • platform: yr
  • platform: time_date
    display_options:
    • ‘time’
    • ‘date’
    • ‘date_time’
    • ‘time_date’
    • ‘time_utc’
    • ‘beat’
      #sensor:
  • platform: islamic_prayer_times
    calculation_method: makkah
    sensors:
    • fajr
    • sunrise
    • dhuhr
    • asr
    • maghrib
    • isha
    • midnight
Text to speech
tts:
  • platform: google translate
service_name: google_say
#Google Home
cast:
media_player:
#- host: xxx.xxx.x.xxx #Google Home Mini
- host: xxx.xxx.x.xxx #Google Nest Hub
#input Boolean - used to synchronize between multiple speakers
input_boolean:
adhan:
initial: off
media_extractor:
Automation.yaml:
Automation for Dhuhr, Asr, Maghrib, and Isha Adhan
  • action:
    • alias: ’ ’
      entity_id: media_player.family_room_speaker
      media_content_id: https://www.islamcan.com/audio/adhan/azan5.mp3 # replace with your choice of Adhan
      media_content_type: audio/mp3
      service: media_extractor.play_media
    • data:
      volume_level: ‘0.7’
      service: media_player.volume_set
      alias: Adhan
      condition: [ ]
    • platform: template
      value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_dhuhr”), “%Y-%m-%dT%H:%M:%S”))+240 }}’
      value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_asr”), “%Y-%m-%dT%H:%M:%S”))+3960 }}’
      value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_maghrib”), “%Y-%m-%dT%H:%M:%S”))+360 }}’
      value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_isha”), “%Y-%m-%dT%H:%M:%S”))-2220}}’
Separate Automation for Fajr Adhan
  • action:
    • alias: ‘’
      entity_id: media_player.family_room_speaker # replace with your Google Home’s id
      media_content_id: https://www.islamcan.com/audio/adhan/azan1.mp3
      replace with your choice of Fajr Adhan
    • data:
      volume_level: ‘0.5’
      alias: Fajr Adhan
      condition: [ ]
      value_template: ‘{{as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_fajr”), “%Y-%m-%dT%H:%M:%S”))+1200 }}’
you can try to use the following code to adjust SG prayer time.
    sensors:
      salah_fajr:
        friendly_name: "Fajr"
        value_template: "{{ (as_timestamp(states('sensor.fajr_prayer')) - 480) | timestamp_custom('%Y-%m-%dT%H:%M:%S+00:00', false) }}"
        device_class: timestamp
    sensors:
      salah_dhuhr:
        friendly_name: "Dhuhr"
        value_template: "{{ (as_timestamp(states('sensor.dhuhr_prayer')) + 60) | timestamp_custom('%Y-%m-%dT%H:%M:%S+00:00', false) }}"
Hi, thank you but I solved this a few years ago…
How did you solve it? any dynamic way?
I’m using Node-Red with HomeAssistant. So the time adjustment is done in Node-Red. Previously I did something like what you posted… I think I posted it somewhere in this thread or the original thread for this integration.
Because Ramadan is approaching, I was considering creating an automation that would send me a voice alert on my google speaker 10 minutes before iftar. What is the best way for me to do this?
Just use the method posted above for an offset of -10 :
* Template warning: 'strptime' got invalid input '2022-04-21T18:20:00+00:00' when rendering template '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.dhuhr_prayer"), "%Y-%m-%dT%H:%M:%S")) }}' but no default was specified. Currently 'strptime' will return '2022-04-21T18:20:00+00:00', however this template will fail to render in Home Assistant core 2022.1
I keep getting this error. Does anyone know how to resolve it or what can I use to replace ‘strptime’? If someone could point in the right direction, I would appreciate it.
I found a solution from another post. I am going to link his answer here. Azan or Adhan automation Islamic Prayer Times - #5 by 123 Thanks @123
Hello, with latest ha version the get template has error.
Do you have a workaround please
My adhan automation stopped working after updating to latest version
Dear all my brothers & sisters,
After the recent update on my HA, my Adhan suddenly stop working, upon searching the error in log, it’s likely due to the time template.
For those who have similar issues, please refer below ‘before’ and ‘after’ changes in my template.
BEFORE
  sensors:
    subuh_selangor:
      friendly_name: 'Subuh'
      value_template: '{{ states.sensor.prayer_selangor.attributes.data.timings["Fajr"] | timestamp_custom("%H:%M") }}'
    zuhur_selangor:
      friendly_name: 'Zuhur'
      value_template: '{{ states.sensor.prayer_selangor.attributes.data.timings["Dhuhr"] | timestamp_custom("%H:%M") }}'
    asar_selangor:
      friendly_name: 'Asar'
      value_template: '{{ states.sensor.prayer_selangor.attributes.data.timings["Asr"] | timestamp_custom("%H:%M") }}'
    maghrib_selangor:
      friendly_name: 'Maghrib'
      value_template: '{{ states.sensor.prayer_selangor.attributes.data.timings["Maghrib"] | timestamp_custom("%H:%M") }}'
    isyak_selangor:
      friendly_name: 'Isyak'
      value_template: '{{ states.sensor.prayer_selangor.attributes.data.timings["Isha"] | timestamp_custom("%H:%M") }}'
AFTER
  sensors:
    subuh_selangor:
      value_template: '{{ states.sensor.prayer_selangor.attributes.data.timings["Fajr"] }}'
    zuhur_selangor:
      value_template: '{{ states.sensor.prayer_selangor.attributes.data.timings["Dhuhr"] }}'
    asar_selangor:
      value_template: '{{ states.sensor.prayer_selangor.attributes.data.timings["Asr"] }}'
    maghrib_selangor:
      value_template: '{{ states.sensor.prayer_selangor.attributes.data.timings["Maghrib"] }}'
    isyak_selangor:
      value_template: '{{ states.sensor.prayer_selangor.attributes.data.timings["Isha"] }}'
MY WORKABLE FULL CONFIGURATION
#Time Data
- platform: time_date
  display_options:
    - 'time'
    - 'date'
    - 'date_time'
    - 'time_date'
    - 'time_utc'
    - 'beat'
#selangor
- platform: rest
  name: "Prayer selangor"
  json_attributes:
    - data
  resource: "http://api.aladhan.com/v1/timings?latitude=3.333333&longitude=333.33333&method=3"
  value_template: '{{ value_json["data"]["meta"]["method"]["name"].title() }}'
  scan_interval: 86400
  sensors:
    subuh_selangor:
    zuhur_selangor:
    asar_selangor:
    maghrib_selangor:
    isyak_selangor:
In summary what i did, is to remove the ‘timestamp_custom’ line from the template. Hope it helps.
If you want to keep the timestamp_custom filter, this is what it should look like now that de default parameter is a required parameter:
timestamp_custom("%H:%M", default = 0)
Updating Templates with the new default values in 2021.10.x
Edwin
i tried your above method but got all my time 0.
tttttt
That would normally happen if the value before is undefined. Wat exactly is displayed if you remove ithe filter entirely?
Hello, I am using version 2022.7.4, I have installed islamic prayer times, all is well, but the adhan won’t go off automatically. I have put my configuration files below for your idea. The scripts below used to work on an extremely old version of HA that I was running for the past few years. Since my old raspberry died, I’ve put this on a vmware esxi server for more stability. Please let me know if you can see what am I missing.
config/configuration.yaml
homeassistant:
latitude: 43.21824
longitude: -79.7875487
elevation: 106
unit_system: metric
time_zone: America/Toronto
default_config:
discovery:
media_extractor:
sun:
    display_options:
    • ‘time’
    • ‘date’
    • ‘date_time’
    • ‘date_time_iso’
    • ‘time_date’
    • ‘time_utc’
    • ‘beat’
    calculation_method: isna
    sensors:
    • fajr
    • sunrise
    • dhuhr
    • asr
    • maghrib
    • isha
    • midnight
Text to speech
tts:
  • platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
config/automation.yaml
Fajr Adhan
  • alias: Fujr Adhan
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_fajr”), “%Y-%m-%dT%H:%M:%S”)) -3600 }}’ # Activate this in November right after the time change
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_fajr”), “%Y-%m-%dT%H:%M:%S”)) +3600 }}’ # Activate this in March right after the time change
  value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_fajr"), "%Y-%m-%dT%H:%M:%S")) }}'       # Always the Normal
- service: media_player.volume_set
entity_id:
- media_player.family_room_speaker
- media_player.master_bedroom_speaker
volume_level: ‘0.40’
# Fujr Adhan
- service: media_extractor.play_media
    entity_id:
    media_content_id: http://192.168.1.160/aud/adhan/adhan_fajr_makkah.mp3
    #media_content_id: http://192.168.1.160/aud/adhan/adhan_al-aqsa.mp3
- delay: '00:03:50'
#- delay: '00:04:15'
# Adhan Dua
    entity_id:
    media_content_id: http://192.168.1.160/aud/dua/dua-e-adhan.mp3
- delay: '00:00:19'
#- service: media_player.volume_set
#  data:
#    entity_id:
#        - media_player.family_room_speaker
#        - media_player.guest_room_wifi
#    volume_level: '0.29'
# 96 Surah Al'Alaq
#- service: media_extractor.play_media
#  data:
#    entity_id:
#    media_content_id: http://192.168.1.160/aud/surah/quran_96.mp3
#    media_content_type: audio/mp3
#- delay: '00:02:46'
# 109 Surah Al'Kafirun
#  data:
#    entity_id:
#    media_content_id: http://192.168.1.160/aud/surah/quran_109.mp3
#- delay: '00:01:19'
# 110 Surah An'Nasr
#  data:
#    entity_id:
#    media_content_id: http://192.168.1.160/aud/surah/quran_110.mp3
#- delay: '00:00:57'
# 01 Surah Al'Fatiha
    entity_id:
    media_content_id: http://192.168.1.160/aud/surah/quran_01.mp3
- delay: '00:01:28'
# 112 Surah Al'Ikhlas
    entity_id:
    media_content_id: http://192.168.1.160/aud/surah/quran_112.mp3
- delay: '00:00:41'
# 113 Surah Al'Falaq
    entity_id:
    media_content_id: http://192.168.1.160/aud/surah/quran_113.mp3
- delay: '00:00:56'
# 114 Surah An'Nas
    entity_id:
    media_content_id: http://192.168.1.160/aud/surah/quran_114.mp3
- delay: '00:01:17'
# Ayat'ul Kursi
    entity_id:
    media_content_id: http://192.168.1.160/aud/ayah/ayat_ul-kursi.mp3
Dhuhr Adhan
  • alias: Dhuhr Adhan
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_dhuhr”), “%Y-%m-%dT%H:%M:%S”)) -3600 }}’ # Activate this in November right after the time change
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_dhuhr”), “%Y-%m-%dT%H:%M:%S”)) +3600 }}’ # Activate this in March right after the time change
  value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_dhuhr"), "%Y-%m-%dT%H:%M:%S")) }}'       # Always the Normal
entity_id:
volume_level: ‘0.5’
    entity_id:
    #media_content_id: http://192.168.1.160/aud/adhan/adhan_makkah.mp3
#- delay: '00:03:22'
- delay: '00:04:15'
    entity_id:
- delay: '00:00:19'
entity_id: media_player.family_room_speaker_2
media_content_id: http://192.168.1.160/aud/surah/quran_36.mp3
    entity_id:
- delay: '00:01:28'
    entity_id:
- delay: '00:00:41'
    entity_id:
- delay: '00:00:56'
# 114 Surah An'Nas
    entity_id:
- delay: '00:01:17'
# Ayat'ul Kursi
    entity_id:
Asr Adhan
  • alias: Asr Adhan
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_asr”), “%Y-%m-%dT%H:%M:%S”)) -3600 }}’ # Activate this in November right after the time change
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_asr”), “%Y-%m-%dT%H:%M:%S”)) +3600 }}’ # Activate this in March right after the time change
  value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_asr"), "%Y-%m-%dT%H:%M:%S")) }}'       # Always the Normal
entity_id:
volume_level: ‘0.5’
    entity_id:
- delay: '00:04:15'
    entity_id:
- delay: '00:00:19'
    entity_id:
- delay: '00:01:28'
    entity_id:
- delay: '00:00:41'
    entity_id:
- delay: '00:00:56'
# 114 Surah An'Nas
    entity_id:
- delay: '00:01:17'
# Ayat'ul Kursi
    entity_id:
Maghrib Adhan
  • alias: Maghrib Adhan
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_maghrib”), “%Y-%m-%dT%H:%M:%S”)) -3600 }}’ # Activate this in November right after the time change
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_maghrib”), “%Y-%m-%dT%H:%M:%S”)) +3600 }}’ # Activate this in March right after the time change
  value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_maghrib"), "%Y-%m-%dT%H:%M:%S")) }}'       # Always the Normal
entity_id:
volume_level: ‘1.0’
    entity_id:
    #media_content_id: http://192.168.1.160/aud/adhan/bahrain_tv_athan_akmagraib.mp3
    media_content_id: http://192.168.1.160/aud/adhan/adhan_al-maghrib_madinah.mp3
- delay: '00:03:37' # adhan_al-maghrib_madinah
    entity_id:
    volume_level: '0.5'
- delay: '00:00:19'
    entity_id:
- delay: '00:01:28'
    entity_id:
- delay: '00:00:41'
    entity_id:
- delay: '00:00:56'
# 114 Surah An'Nas
    entity_id:
- delay: '00:01:17'
# Ayat'ul Kursi
    entity_id:
Isha Adhan
  • alias: Isha Adhan
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_isha”), “%Y-%m-%dT%H:%M:%S”)) -3600 }}’ # Activate this in November right after the time change
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_isha”), “%Y-%m-%dT%H:%M:%S”)) +3600 }}’ # Activate this in March right after the time change
  value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_isha"), "%Y-%m-%dT%H:%M:%S")) }}'       # Always the Normal
entity_id:
volume_level: ‘0.5’
    entity_id:
- delay: '00:04:15'
    entity_id:
- delay: '00:00:19'
    entity_id:
- delay: '00:01:28'
    entity_id:
- delay: '00:00:41'
    entity_id:
- delay: '00:00:56'
# 114 Surah An'Nas
    entity_id:
- delay: '00:01:17'
# Ayat'ul Kursi
    entity_id:
This is what I have on my dash board: (Please ignore the lines that are appearing as heading (bolded and enlarged) as they have a # for comment in the code)
Please Help! :confused:
Hi @Edwin_D, please Sir, when you have a chance, can you help me out? :slight_smile:
Hey! I’m sharing my configuration here so you may adopt it. First of all, you have go to https://api.aladhan.com and choose whatever method you’d like to. Here I am using Hanafi method so I chose “1”. Secondly, you have to find longitude and latitude of your home address and then modify it in the link I shared here.
Paste these codes into your configuration.yaml file:
  - platform: rest
    json_attributes:
      - data
    resource: "http://api.aladhan.com/v1/timings?latitude=40.0000000&longitude=-23.00000&method=2&school=1"
    scan_interval: 3600
    sensors:
      fajr_prayer_time:
        friendly_name: "Fajr Prayer Time"
        value_template: >
          {{ today_at(state_attr('sensor.prayer_times','data').timings['Fajr']).strftime("%I:%M %p") }}
      dhuhr_prayer_time:
        friendly_name: "Dhuhr Prayer Time"
        value_template: >
          {{ today_at(state_attr('sensor.prayer_times','data').timings['Dhuhr']).strftime("%I:%M %p") }}
      asr_prayer_time:
        friendly_name: "Asr Prayer Time"
        value_template: >
          {{ today_at(state_attr('sensor.prayer_times','data').timings['Asr']).strftime("%I:%M %p") }}
      maghrib_prayer_time:
        friendly_name: "Maghrib Prayer Time"
        value_template: >
          {{ today_at(state_attr('sensor.prayer_times','data').timings['Maghrib']).strftime("%I:%M %p") }}
      isha_prayer_time:
        friendly_name: "Isha Prayer Time"
        value_template: >
          {{ today_at(state_attr('sensor.prayer_times','data').timings['Isha']).strftime("%I:%M %p") }}
And add these codes to automation.yaml file:
- id: '1517693010923'
  alias: Adhan
    value_template: '{% set x = states(''sensor.fajr_prayer_time'') %} {{ now() >=
      today_at(strptime(x, "%I:%M %p").time()) }}'
    value_template: '{% set x = states(''sensor.dhuhr_prayer_time'') %} {{ now() >=
    value_template: '{% set x = states(''sensor.asr_prayer_time'') %} {{ now() >=
    value_template: '{% set x = states(''sensor.isha_prayer_time'') %} {{ now() >=
  condition: []
  - data:
      volume_level: 0.3
      entity_id:
  - alias: ''
      entity_id: media_player.master_bedroom_speaker
      media_content_id: https://yourHomeAssistantIP/local/azaan.mp3
      media_content_type: music
    service: media_player.play_media
Hi @chintito4ever , Thank you for your kind help.
I removed everything from my configuration.yaml and added the above you mentioned, like so:
  - platform: rest
    json_attributes:
      - data
    resource: "http://api.aladhan.com/v1/timings?latitude=43.21824&longitude=-79.7875487&method=2&school=1"
    scan_interval: 3600
    sensors:
      fajr_prayer_time:
        value_template: >
      dhuhr_prayer_time:
        value_template: >
      asr_prayer_time:
        value_template: >
        value_template: >
      isha_prayer_time:
        value_template: >
I’ve updated latitude/logitude im assuming method=2 means ISNA and I have no idea about school=1.
but when I save and try to restart, I get the following error message:
Logger: homeassistant.components.hassio
Source: components/hassio/__init__.py:682
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 5:38:01 PM (1 occurrences)
Last logged: 5:38:01 PM
The system cannot restart because the configuration is not valid: Error loading /config/configuration.yaml: The configuration file configuration.yaml does not contain a dictionary
What am I missing?
