I suspect there’s something wrong with the code, most probably indentation problem. If you go to Settings page>Logs page you should find a detailed error. It will show exactly which line in your configuration has problem.
yeah, I checked in the logs, this is what I see:
Logger: homeassistant.config
Source: config.py:374
First occurred: 5:37:46 PM (5 occurrences)
Last logged: 5:38:01 PM
The configuration file configuration.yaml does not contain a dictionary
not sure which dictionary is it referring to or perhaps something im missing to install?
How about line 6; im not sure if that’s supposed to be there?
ok I resolved that by adding some of the old stuff, now it looks like this:
default_config:
discovery:
media_extractor:
sun:
- platform: time_date
display_options:
- 'time'
- 'date'
- 'date_time'
- 'date_time_iso'
- 'time_date'
- 'time_utc'
- 'beat'
- platform: rest
json_attributes:
- data
resource: "http://api.aladhan.com/v1/timings?latitude=43.21824&longitude=-79.7875487&method=2&school=1"
value_template: '{{ value_json["data"]["meta"]["method"]["name"].title() }}'
scan_interval: 3600
sensors:
fajr_prayer_time:
friendly_name: "Fajr Prayer Time"
value_template: >
{{ today_at(state_attr('sensor.prayer_times','data').timings['Fajr']).strftime("%I:%M %p") }}
dhuhr_prayer_time:
friendly_name: "Dhuhr Prayer Time"
value_template: >
{{ today_at(state_attr('sensor.prayer_times','data').timings['Dhuhr']).strftime("%I:%M %p") }}
asr_prayer_time:
friendly_name: "Asr Prayer Time"
value_template: >
{{ today_at(state_attr('sensor.prayer_times','data').timings['Asr']).strftime("%I:%M %p") }}
maghrib_prayer_time:
friendly_name: "Maghrib Prayer Time"
value_template: >
{{ today_at(state_attr('sensor.prayer_times','data').timings['Maghrib']).strftime("%I:%M %p") }}
isha_prayer_time:
friendly_name: "Isha Prayer Time"
value_template: >
{{ today_at(state_attr('sensor.prayer_times','data').timings['Isha']).strftime("%I:%M %p") }}
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
so the error is gone. Going to wait now and see if the next prayer gets triggered or not. Will update you. Thank you.
@chintito4ever , I noticed something odd. and I think it could be in the code. Everything runs well, but the Maghrib prayer, I have to manually trigger for it to run.
This is what I see in the error log:
2022-07-29 06:49:24 WARNING (MainThread) [homeassistant.components.template.trigger] Error initializing 'template' trigger for 'Maghrib Adhan': ValueError: Template error: strptime got invalid input 'unknown' when rendering template '{% set x = states('sensor.mughrib_prayer_time') %} {{ now() >= today_at(strptime(x, "%I:%M %p").time()) }}' but no default was specified
2022-07-29 06:49:24 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template("{% set x = states('sensor.mughrib_prayer_time') %} {{ now() >= today_at(strptime(x, "%I:%M %p").time()) }}")
How do I troubleshoot the above?
this is the snippet from configuration.yaml for mughrib
- alias: Maghrib Adhan
value_template: '{% set x = states(''sensor.mughrib_prayer_time'') %} {{ now() >= today_at(strptime(x, "%I:%M %p").time()) }}'
- service: media_player.volume_set
entity_id:
- media_player.family_room_speaker
- media_player.master_bedroom_speaker
- media_player.main_floor_speaker
volume_level: '1.0'
- service: media_extractor.play_media
entity_id:
media_content_id: http://192.168.1.160/aud/adhan/adhan_al-maghrib_madinah.mp3 #media_content_id: http://192.168.1.160/aud/adhan/bahrain_tv_athan_akmagraib.mp3
media_content_type: audio/mp3
- delay: '00:03:37' # adhan_al-maghrib_madinah
try changing sensor name from sensor.mughrib_prayer_time
to sensor.maghrib_prayer_time
as @chintito4ever suggested, use sensor.magrib_prayer as indicated in the Islamic Prayer Times entities
Salaam Brothers,
I have the automation working perfectly minus one small thing. The Islamic Prayer Time integration doesn’t have a calculation for the UK, the closest is MWL but it isn’t correct. Is there a way I can correct this without having to change anything constantly.
Salaam Brother,
I also want to set up azan automation working my amazon echo, I have currently install Islamic prayer times and alexa media.
can you kindly share your config & auto script.
Salam @sshaikh - I’ve just added this integration to my HA and hoping it will resolve all the issues i’ve had with setting offsets on all the prayer times as mentioned in the thread.
If this works - You will be remembered in the coming month of Ramadan I’A
Please add to HACS when you have time and create a blueprint also. This will make life easier for those who are not as tech savy.
Original Detailed Instructions as I ran out of character limit when updating the post for Node-RED.
Detailed Instructions: I am fairly new to Home Assistant and YAML, please excuse my messy code. There is likely easier and more compressed way to write the automation scripts, modified suggestions would be appreciated. I am just happy I got it to work
You should not add Islamic Prayer Times integration using config file, please use the standard Home Assistant Integration page to do this under “Devices and Services”.
configuration.yaml
homeassistant:
latitude: !secret lat
longitude: !secret long
display_options:
- 'time'
- 'date'
- 'date_time'
- 'time_date'
- 'time_utc'
- 'beat'
- platform: islamic_prayer_times
calculation_method: makkah
sensors:
- fajr
- sunrise
- dhuhr
- asr
- maghrib
- isha
- midnight
#Google Home
cast:
media_player:
- host: 10.0.0.36
- host: 10.0.0.53
- host: 10.0.0.51
- host: 10.0.0.50
#Input Boolean - used to synchronize between multiple speakers
input_boolean:
adhan:
initial: off
#Play media from URL - this is another way to play the Adhan from Youtube
media_extractor:
For the below automation, please note that I have a lot of speakers and media devices which are mostly controlled via Harmony Hubs and via Bose SoundTouch component. Please see my comments embedded in the automation script.
automations.yaml
# Automation for Dhuhr, Asr, Maghrib, and Isha Adhan
- id: '1517693010922'
alias: Adhan
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_dhuhr"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_asr"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_maghrib"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_isha"), "%Y-%m-%dT%H:%M:%S")) }}'
condition: []
#Basement Media Pause/Mute
- service: remote.send_command
entity_id: remote.basement_remote
command:
- Pause
device: 17712304
command:
- Pause
device: 52012635
- service: media_player.volume_mute
entity_id: media_player.home_theater_speaker
is_volume_muted: true
entity_id: media_player.gym_speaker
volume_level: 0.0
#Living Room Media Pause/Mute
entity_id: remote.living_room_remote
command:
- Pause
device: 47973307
command:
- Pause
device: 48904860
command:
- Mute
device: 47973310
entity_id: media_player.kitchen_speaker
volume_level: 0.0
entity_id: media_player.living_room_speaker
volume_level: 0.0
#Bedroom Media Pause/Mute
entity_id: remote.bedroom_remote
command:
- Pause
device: 49622856
command:
- Pause
device: 52828759
command:
- Mute
device: 49622863
#Set Desired Volume for Google Home
entity_id: media_player.basement_google
volume_level: 0.6
entity_id: media_player.living_room_google
volume_level: 0.7
entity_id: media_player.green_room_google
volume_level: 0.6
entity_id: media_player.bedroom_google
volume_level: 0.5
#Turning on the input boolean to trigger the Google Homes to start playing the Adhan
entity_id: input_boolean.adhan
#The daly is based on how long the actual Adhan audio is, for this Adhan, it is just around 2 minutes and 14 seconds
- delay: '00:02:14'
#Basement Media Resume/Un-Mute after Adhan is completed
command:
- Play
device: 17712304
command:
- Play
device: 52012635
is_volume_muted: false
volume_level: 0.55
#Living Room Media Resume/Un-Mute after Adhan is completed
command:
- Play
device: 47973307
command:
- Play
device: 48904860
command:
- Mute
device: 47973310
volume_level: 0.6
volume_level: 0.7
#Bedroom Media Resume/Un-Mute after Adhan is completed
command:
- Play
device: 49622856
command:
- Play
device: 52828759
command:
- VolumeUp
device: 49622863
#Seperate automation for the Fajr prayer (~5 AM)
- id: '151769301092'
alias: Adhan Fajr
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_fajr"), "%Y-%m-%dT%H:%M:%S")) }}'
condition: []
#Set the volume of Google Home Speaker to very low, too early for loud audio :)
volume_level: 0.3
volume_level: 0.3
volume_level: 0.3
volume_level: 0.1
#Turn on the input boolean to trigger playing the Adhan on Google Home Speaker
- delay: '00:02:14'
#After the delay, set the volume back to higher level for Google Home devices
volume_level: 0.6
volume_level: 0.7
volume_level: 0.6
volume_level: 0.6
#Below 4 automation simply plays the Adhan on 4 of my speakers at the same time
- id: '1013100'
alias: Play Adhan Bedroom
- entity_id: input_boolean.adhan
platform: state
to: 'on'
condition: []
#Below commented section is an exmaple of how you can use mmedia_extractor component
# - service: media_extractor.play_media
# data:
# entity_id: media_player.bedroom_google # replace with your Google Home's id
# media_content_id: https://www.youtube.com/watch?v=ADLO-Hm_nCQ # replace with your choice of Adhan
# media_content_type: audio
- service: media_player.play_media
media_content_id: https://kazihome.duckdns.org:8123/local/Adhan1.mp3 # replace with your choice of Adhan
media_content_type: music
- delay: '00:00:10'
- service: input_boolean.turn_off
- id: '1013101'
alias: Play Adhan Greeen Room
platform: state
to: 'on'
condition: []
entity_id: media_player.green_room_google # replace with your Google Home's id
- delay: '00:00:10'
- id: '1013101'
alias: Play Adhan Living Room
platform: state
to: 'on'
condition: []
entity_id: media_player.living_room_google # replace with your Google Home's id
- delay: '00:00:10'
- id: '1013101'
alias: Play Adhan Basement
platform: state
to: 'on'
condition: []
entity_id: media_player.basement_google # replace with your Google Home's id
- delay: '00:00:10'
Hi after the latest HA update my adhan doesn’t work anymore. I had to write “Country: AU” in the config or else i will get an error in the system saying i they can’t read where is my location. After typing the country code, all the adhan time totally mess up and automation doesn’t even work. Can someone help?
config:
homeassistant:
latitude: xxxxxxx
longitude: xxxxxxx
elevation: xx
unit_system: metric
time_zone: Australia/Perth
country: AU
default_config:
discovery:
media_extractor:
# Example configuration.yaml using a non-default calculation method
islamic_prayer_times:
calculation_method: mwl
# Sensors
display_options:
- 'time'
- 'date'
- 'time_date'
sensors:
salah_fajr:
friendly_name: "Salah Fajr"
value_template: >
{%- set a = states("sensor.fajr_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.fajr_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_dhuhr:
friendly_name: "Salah Dhuhr"
value_template: >
{%- set a = states("sensor.dhuhr_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.dhuhr_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_asr:
friendly_name: "Salah Asr"
value_template: >
{%- set a = states("sensor.asr_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.asr_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_maghrib:
friendly_name: "Salah Maghrib"
value_template: >
{%- set a = states("sensor.maghrib_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.maghrib_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_isha:
friendly_name: "Salah Isha"
value_template: >
{%- set a = states("sensor.isha_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.isha_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
# Text to speech
tts:
automation
- action:
- alias: Azan
entity_id: media_player.verydisco
media_content_id: https://www.islamcan.com/audio/adhan/azan2.mp3
- data:
volume_level: ‘0.9’
alias: Adhan
- alias: Restart HA
platform: time
at: 01:00:00
- service: homeassistant.restart
- id: '1680081209833'
alias: Adhan
description: ''
condition: []
- alias: Azan
device_id:
- 038e96310faedd96dc4dfdc854289aca
- 2a99c55c7a524b68954b220e0f236a17
- f28547ceff3a4eed950561de23cae35a
- 2fbf7b1857049124ba8ad4c021a01608
- db2898a1ccd54375aa1bc0825886ce84
- fbbdc0625444442a840a468b3fef7453
- data:
volume_level: 0.47
mode: single
Hi, you should not use the config file to add the integration, but rather use the default Home Assistant “Add Integration” option and you can configure the calculation method there.
i did this already. The restarting HA automation is working just fine, just the adhan is the problem
This is exactly what im looking for, thanks heaps for all the work youve done so far.
I am really new to all this and am a little bit confused with what you’ve documented on how to setup the automation using node-red. Is this part of that installation/configuration? or is this the “original” way you set it up before moving onto node-red?
I changed the timezone to the country and city im from. pointed the sensor for my google hub. All the other bits you’ve added are not really necessary in my case but also shouldn’t prevent it from continuing as far as i can tell.
I feel like i followed your instructions but I am not sure how to confirm whether this is actually working or not. … well not until the time for a prayer starts. I should probably be a bit more patient - sorry if its been discussed already.
Hi, the original method should still work, but I have moved everything over to Node Red. It’s just much easier to manage. You don’t have to wait until prayer time to test, you can go to the developer tools - - >States to update the prayer times to test the automation. I will plan to make a video recording and share link here of my setup for node red this weekend.
I would recommend watching this video to install Node Red and understand the basics.
Thanks for that. Updating the state for the prayer time helped diagnose a few things but I am still stuck. I have for the most part setup node red (using HA supervisor + node-red). So far I have managed to get the trigger to work on notifying me the Athan has not played on my mobile.
I am not familiar with how you setup the Prayer Call Status “input_boolean.prayer_call” though. That for me is currently showing as “not found”. If i understood right, the input_boolean.whatever can be created in the configuration.yaml. I’ve been reading up on it but im not sure exactly how to add it.
You can create input boolean under devices - - >helpers in settings. Or the existing configuration yaml option works too. Restart home assistant or reload the input boolean and ensure it shows up under developer tools states. If it does, make sure to turn it on.
So i have that, and the state shows as Prayer call status “off” but I am not sure exactly how to get it to identify the prayer time so it can be “on”. I set the time for the prayer and it continues to pass the message to my mobile HA app saying it didn’t play the adhan. I feel like there is a part missing or incomplete.
In my configurations.yaml:
input_boolean:
prayer_call:
initial: off
I did read about how you said you can add it in the helpers but that was not clear which option to chose e.g. Button or Group. there were a lot of options to chose from and it just wasn’t clear which one to use. Putting into the confiugrations.yaml seemed the easier choice for now.
omg… ok. Fasting brain here. It all clicked once I checked the helpers and seen it there. I have it in my dashboard now (for some reason it took me a while to get what that part was actually doing). Brilliant work. Thank you again. I think i might actually have this setup right now.
You’re welcome and glad it worked out.
