Automate the Litra Beam
I recently automated my Litra Beam and wanted to share the results. So this is a semi-complicated process, so I’ll break it down into 4 Parts IoTLink, Downloading and installing hidapitester, Creating the buttons and input number stuff, and creating the automations. I’ll loosely go over everything, but if you have any questions, let me know.
IotLink Setup (Download Here)
Getting IoTLink setup is pretty easy if you know what you’re doing. But you’ll have to setup the MQTT Config to get it going. Just make sure you have the “Commands” option checked when you install it. Open the configuration by searching “Edit Configuration File” in the start menu. Put in your username and pass and a client ID and Home Assistant should auto-discover a bunch a stuff. This part is done.
Getting hidapitester
This program is the thing that will interface with the Litra Beam. Download it from here. Copy the .exe to C:\hidapitester. Optionally, you can add it to the “PATH” if needed, but we really won’t need to.
Creating the Buttons
Creating the buttons is kinda easy. You can find the config below:
mqtt:
  button:
    - unique_id: litra_beam_on
      name: "Turn On Litra Beam"
      command_topic: "iotlink/workgroup/clientId/commands/run"
      command_template: '{ "command": "C:\\hidapitester\\hidapitester.exe", "args": " --vidpid 046D/B901 --usagePage ff43 --open --send-output 0x11,0xFF,0x04,0x1D,0x01", "path": "C:\\hidapitester\\", "user": "", "visible": false, "fallback": true }'
    - unique_id: litra_beam_off
      name: "Turn Off Litra Beam"
      command_template: '{ "command": "C:\\hidapitester\\hidapitester.exe", "args": " --vidpid 046D/B901 --usagePage ff43 --open --send-output 0x11,0xFF,0x04,0x1D,0x00", "path": "C:\\hidapitester\\", "user": "", "visible": false, "fallback": true }'
    - unique_id: litra_beam_20_percent
      name: "Set Litra Beam to 20%"
      command_template: '{ "command": "C:\\hidapitester\\hidapitester.exe", "args": " --vidpid 046D/B901 --usagePage ff43 --open --send-output 0x11,0xFF,0x04,0x4F,0x00,0x38", "path": "C:\\hidapitester\\", "user": "", "visible": false, "fallback": true }'
    - unique_id: litra_beam_40_percent
      name: "Set Litra Beam to 40%"
    - unique_id: litra_beam_60_percent
      name: "Set Litra Beam to 60%"
      command_template: '{ "command": "C:\\hidapitester\\hidapitester.exe", "args": " --vidpid 046D/B901 --usagePage ff43 --open --send-output 0x11,0xFF,0x04,0x4F,0x00,0x54", "path": "C:\\hidapitester\\", "user": "", "visible": false, "fallback": true }'
    - unique_id: litra_beam_80_percent
      name: "Set Litra Beam to 80%"
      command_template: '{ "command": "C:\\hidapitester\\hidapitester.exe", "args": " --vidpid 046D/B901 --usagePage ff43 --open --send-output 0x11,0xFF,0x04,0x4F,0x00,0x94", "path": "C:\\hidapitester\\", "user": "", "visible": false, "fallback": true }'
    - unique_id: litra_beam_100_percent
      name: "Set Litra Beam to 100%"
      command_template: '{ "command": "C:\\hidapitester\\hidapitester.exe", "args": " --vidpid 046D/B901 --usagePage ff43 --open --send-output 0x11,0xFF,0x04,0x4F,0x00,0xFA", "path": "C:\\hidapitester\\", "user": "", "visible": false, "fallback": true }'
    - unique_id: litra_beam_cool
      name: "Set Litra Beam Temperature to Cool"
      command_template: '{ "command": "C:\\hidapitester\\hidapitester.exe", "args": " --vidpid 046D/B901 --usagePage ff43 --open --send-output 0x11,0xFF,0x04,0x9D,0x19,0x64", "path": "C:\\hidapitester\\", "user": "", "visible": false, "fallback": true }'
    - unique_id: litra_beam_medium_cool
      name: "Set Litra Beam Temperature to Medium Cool"
      command_template: '{ "command": "C:\\hidapitester\\hidapitester.exe", "args": " --vidpid 046D/B901 --usagePage ff43 --open --send-output 0x11,0xFF,0x04,0x9D,0x13,0x88", "path": "C:\\hidapitester\\", "user": "", "visible": false, "fallback": true }'
    - unique_id: litra_beam_neutral
      name: "Set Litra Beam Temperature to Neutral"
      command_template: '{ "command": "C:\\hidapitester\\hidapitester.exe", "args": " --vidpid 046D/B901 --usagePage ff43 --open --send-output 0x11,0xFF,0x04,0x9D,0x11,0x30", "path": "C:\\hidapitester\\", "user": "", "visible": false, "fallback": true }'
    - unique_id: litra_beam_medium_warm
      name: "Set Litra Beam Temperature to Medium Warm"
      command_template: '{ "command": "C:\\hidapitester\\hidapitester.exe", "args": " --vidpid 046D/B901 --usagePage ff43 --open --send-output 0x11,0xFF,0x04,0x9D,0x0D,0x48", "path": "C:\\hidapitester\\", "user": "", "visible": false, "fallback": true }'
    - unique_id: litra_beam_warm
      name: "Set Litra Beam Temperature to Warm"
      command_template: '{ "command": "C:\\hidapitester\\hidapitester.exe", "args": " --vidpid 046D/B901 --usagePage ff43 --open --send-output 0x11,0xFF,0x04,0x9D,0x0A,0x8C", "path": "C:\\hidapitester\\", "user": "", "visible": false, "fallback": true }'
Paste this config in your configuration.yaml File. If you already have something like this there, you’ll need just paste the items under mqtt->buttons. Make sure you replace clientId With your machine’s client ID.
Next we need to create the input numbers. You can create those by heading to Settings > Devices & Services > Helpers > Create Helper. You’ll need to create two helpers
  • Create a input number helper called “Litra Beam Brightness” (or whatever you prefer) and make the input min amount 0, and the input max amount 255. The step size should be 1.
  • Create a input number helper called “Litra Beam Temperature” (or whatever you prefer) and make the input min amount 150, and the input max amount 500. The step size should be .1.
We Also need to create a few switches. The code for that is below (This is used for the initial on/off state and remembering the state):
switch:
    switches:
      litra_beam:
        friendly_name: "Litra Beam"
        turn_on:
          service: button.press
            entity_id: button.turn_on_litra_beam
        turn_off:
            entity_id: button.turn_off_litra_beam
      desk_key_light:
        unique_id: desk_key_light
        friendly_name: "Desk Key Light"
        value_template: "{{ is_state('switch.litra_beam', 'on') }}"
        turn_on:
          service: switch.turn_on
            entity_id: switch.litra_beam
        turn_off:
          service: switch.turn_off
Lastly, We need to create the light. You can do that be using the light template below
light:
    lights:
      desk_key_light:
        level_template: "{{states('input_number.desk_key_light_brightness') | int}}"
        temperature_template: "{{states('input_number.desk_key_light_temperature') | int}}"
        turn_on:
        turn_off:
        set_level:
          service: input_number.set_value
          data_template:
            entity_id: input_number.desk_key_light_brightness
            value: "{{ brightness }}"
        set_temperature:
          data_template:
            entity_id: input_number.desk_key_light_temperature
            value: "{{ color_temp }}"
Creating the Automation
Creating the automation is a bit straightforward. You just need to press the button if any of the input number values are between a certain amount (this is due to the Litra Beam’s Non granular brightness control. You can find the automation code below:
Brightness:
description: ""
  - platform: state
    entity_id:
      - input_number.desk_key_light_brightness
condition: []
  - choose:
      - conditions:
          - condition: numeric_state
            above: -0.1
            below: 51
        sequence:
          - service: button.press
            data: {}
              entity_id: button.set_litra_beam_to_20
      - conditions:
            above: 51
            below: 102
        sequence:
            data: {}
              entity_id: button.set_litra_beam_to_40
      - conditions:
            above: 102
            below: 153
        sequence:
            data: {}
              entity_id: button.set_litra_beam_to_60
      - conditions:
            above: 153
            below: 204
        sequence:
            data: {}
              entity_id: button.set_litra_beam_to_80
      - conditions:
            above: 204
            below: 256
        sequence:
            data: {}
              entity_id: button.set_litra_beam_to_100
mode: single
Temperature:
alias: Update Litra Beam Temperature
description: ""
  - platform: state
    entity_id:
      - input_number.desk_key_light_temperature
condition: []
  - choose:
      - conditions:
            above: 149
            below: 220
        sequence:
            data: {}
              entity_id: button.set_litra_beam_temperature_to_cool
      - conditions:
            above: 220
            below: 290
        sequence:
            data: {}
              entity_id: button.set_litra_beam_temperature_to_medium_cool
      - conditions:
            above: 290
            below: 360
        sequence:
            data: {}
              entity_id: button.set_litra_beam_temperature_to_neutral
      - conditions:
            above: 360
            below: 430
        sequence:
            data: {}
              entity_id: button.set_litra_beam_temperature_to_medium_warm
      - conditions:
            above: 430
            below: 501
        sequence:
            data: {}
              entity_id: button.set_litra_beam_temperature_to_warm
mode: single
That’s pretty much it after that, Should just work! if you choose to change the names in there, make sure you change them in other places as well.
Is this work with Logitech G Logitech Litra Beam LX for the RGB light too? I’m thinkign to buy two of them and i want it to make them smart as my yeelight lights. Thanks!
To use this with the LX you can send the output 0x11,0xFF,0x06,0x1F,0x01 for on, and 0x11,0xFF,0x06,0x1F,0x00 for off. This is for the main light. I might continue working on getting the rest of the payloads but no guarantees
Toggling the rear light:
On 0x11,0xFF,0x0A,0x4F,0x01
Off 0x11,0xFF,0x0A,0x4F,0x00
Great one Devin. I’ve been looking for a solution to use my spare Litra Beam. Thanks to you, I had something to start with. Since my home server is on Debian, I installed hidapitester for Linux and then I made a bash script which listens to specific mqtt topic. Once message is received it runs hidapitester command to control the light.
One thing which I noticed - for hidapitester to work in my setup –length parameter was required. Without this command had no effect whatsoever.
So instead of:
./hidapitester --vidpid 046D/B901 --usagePage FF43 --open --send-output 0x11,0xff,0x04,0x1d,0x01
I used
./hidapitester --vidpid 046D/B901 --usagePage FF43 --length 20 --open --send-output 0x11,0xff,0x04,0x1d,0x01
Works like a charm.
You’re awesome man, this was racking my brain as of late!
Isn’t there a way to integrate the Litra Beam via its Bluetooth connection function? Would be more standard and not dependent on your Windows PC.
Hi!
Building this PR (on Linux):
I managed to control my Litra Beam using Bluetooth:
hidpp20-illumination-light-control -v /dev/hidraw10 toggle
I’ll try to automate it with Home Assistant without needing to connect it via USB.
Cheers!
hey y’all - purchased a litra beam lx a while back and it was driving me nuts not being able to control it alongside the other lights in my office. spent the last two days with claude punching at it and was able to get it functioning in HAOS for myself and thought i’d share the configs i’m currently using.
Features
  • :white_check_mark: White Light: On/Off | Brightness Control | Temperature Control
  • :white_check_mark: RGB Light: On/Off | Brightness Control | Color Selection (as a single zone)
  • :white_check_mark: Auto-detection of device path via sysfs — no hardcoded paths
Limitations
  • Requires the Litra to be plugged into your host via USB :pensive:
    • will see if I’m able to get any BT functionality unlocked (at least the power toggle as edubxb seems to have managed to unlock in the post above)
first time ever trying something like this so my apologies if it’s a mess of a setup - will try to continue working on some additional features in the future if possible.
hope this helps someone and would love to hear any thoughts / success stories if you have them!
This looks really interesting. I wonder if you could connect this to HA host via a USB-over-IP device like a ESP32. I will try to look into it, but great work!
hey y’all - i just found this (and didn’t see it posted in this thread already) - not sure if it was posted elsewhere but it was absolutely the seamless integration i was looking for.
MQTT paired with the lamp on the first try, and i was able to control the lamp way better than my own integration attempt prior including color and brightness control on both sides to match my other lamps in the room.
@Alevale thank you for your work on this!
