Another ESPHome powered Sonoff Basic implemented.
Heat pad added to bathroom Mirror. Light/heat control changed from hardwired pull switch to Sonoff basic. Pull cord as input. Relay as output. Auto off after 60mins. Some challenges on de-bouncing the incredibly awful pull cord switch but “multi-click” got me there. Thats full Control, with custom firmware working exactly how I want it, updateable over WiFi…for a £5 sonoff basic and a few hours tinkering time.
Just have to stop and appreciate how remarkable that is ! Thanks so much to the people that contribute to all the software components but especially @OttoWinter and ESPHome !
YAML…here. Took a while to get the multi_click format and details right. The key is the “invalid_cooldown” being disabled (0s)
Template Sensor needed to track the Switch to give “on_state” option to trigger the 60minute delayed power off.
# Enable logging
logger:
level: INFO
# Enable Home Assistant API
api:
ota:
time:
- platform: homeassistant
substitutions:
switch_id: "esp_sf03"
- platform: wifi_signal
name: "${switch_id} WiFi Signal Sensor"
update_interval: 60s
switch:
# Restart Switch in HA
- platform: restart
# Relay output
- platform: gpio
pin: 12
name: "${switch_id} Relay 1"
status_led:
# Use Sonoff LED as Status LED
pin:
number: 13
inverted: True
# Green LED Output
binary_sensor:
# Std Sonoff Push Button - Not very relevant, it's inside the Mirror
- platform: gpio
internal: true
pin: 0
name: " Touch Switch 1"
filters:
- invert:
on_click:
min_length: 50ms
max_length: 350ms
then:
- switch.toggle: ${switch_id}_out_relay1
# Pull Switch - Soldered to GPIO2/Grnd
- platform: gpio
internal: true
pin:
number: 2
mode: INPUT_PULLUP
name: " Touch Switch 2"
on_multi_click:
- timing:
- ON for at least 200ms
then:
- logger.log: "Debounced ON"
invalid_cooldown: 0s
- timing:
- OFF for at least 200ms
then:
- logger.log: "Debounced OFF"
# Template to track Relay and give "on_state"
name: "${switch_id} Template 1"
internal: true
lambda: |-
if (id(${switch_id}_out_relay1).state) {
return true;
} else {
return false;
on_state:
- if:
condition:
- binary_sensor.is_on: ${switch_id}_template1
then:
- delay: 60min
- switch.turn_off: ${switch_id}_out_relay1
