Automated Daily Snapshot uses an unknown service
I’m struggling with getting an automated backup running. I’ve tried two different solutions, with the same result for both, an error that I can’t troubleshoot:
This is from the blueprint exchange, but it’s the same error I was getting with the previous functionality. Here’s the yaml:
alias: Automated Daily Snapshot (3am)
description: ""
use_blueprint:
  path: vorion/create-automated-backups-every-day.yaml
  input:
    trigger_time: "03:00:00"
    send_notification: true
    notify_device: f6c2366187c7979acc525ad0219583b5
I have googled this pretty extensively and cannot figure out how to move forward. Happy to keep troubleshooting, I just don’t know what the next step should be. If anyone can point me in the right direction, I’d appreciate it. Thanks very much!
How did you install HA? hassio.snapshot_full requires HA OS or HA Supervised, it is not availabe on HA Container (docker install) or HA Core (venv)
Installed on an Rpi 4 with the standard setup that you get from the imager. I did it that because I understood that was the easiest way to get all the components?
One other thing, I am running HA on an SSD, as opposed to the SD card.
Ok, I see already, you are using an outdated blueprint
afbeelding
Change hassio.snapshot_full to hassio.backup_full
It is really long time ago that snapshots were renamed to backups
Ahhh, ok, gotcha. Will give it whirl. Thank you for the assist!
There are add-ons that might work for you as well…
They provide copying the backup to another location so it is accessible if you get a total crash and need to start over. They also provide a clean way to schedule.
And another:
I have a video about it if that helps as well…
Ok! This worked last night, so thank you again!
Perfect! I wanted to get the basic one running first and this was exactly where I wanted to go next so I appreciate the perfectly timed info! Great user name, too. Thanks much!
GoodEnough is a play off the initials of the employer I retired from.,…
If we have solved your issue please consider clicking solution on the post that helped you out.
