This is my first post on the HA forums. I’ve begun setting up my HA and right now I have outdoor bulbs automatically turning on triggered by sunset state … indoors I have bulbs automatically turning on, condition: after sunset, triggered by: motion sensor. On the indoor bulbs, I’d like them to turn on, triggered by motion (condition after sunset), color: RED after a certain hour. Is this possible? I’m using Philips Hue bulbs without a hub (zigbee2mqtt).
I did a quick search of the forum and didn’t find anything. Thanks in advance!
depending on the brand it will determine what the commands will be to set the color of the bulb (if it’s supported).
Once you post that info then also post the code that you already have (in the correct format using the instructions above). Then we can see what you have and recommend changes based on your actual entities.
So I got the color working using RGB and I am using the newest gen Philips Hue Color Ambiance bulbs. Exact model is 9290012575A. These are the scripts I’m currently running (no motion detection) but would like to do accomplish the same thing indoors WITH motion detection. For instance, I’d like to walk into the hallway or bathroom after 8pm, lights turn on red, I leave, lights turn off. This is my automations.yaml:
## CHANGE LIGHTS TO RED ON SUNSET
- alias: Auto light change to RED
- platform: sun
event: sunset
offset: "-00:10:00"
- service_template: >
{% if is_state('group.bedroom_lights', 'on') %}
input_boolean.turn_on
{% else %}
input_boolean.turn_off
{% endif %}
entity_id: input_boolean.prev_light_state
- service: light.turn_on
entity_id: group.bedroom_lights
rgb_color: [255, 0, 0]
brightness: 255
transition: 50
- condition: state
state: 'off'
- service: light.turn_off
## CHANGE LIGHTS TO WHITE ON SUNRISE
- alias: Auto light change to WHITE
- platform: sun
event: sunrise
{% else %}
{% endif %}
rgb_color: [255, 255, 204]
brightness: 125
transition: 600
- condition: state
state: 'off'
Adittionally, if possible, I’d like to figure out how to fade the lights in (in the morning, starting from a dim red and fading slowly to a soft white/yellow, like I have now).
Let me Edit: But I have read somewhere on the homepage, that transition is not supported by every light platform. May some (exotic?) devices wouldn’t work
Yes, I’m currently using transition in some of the automation already. How would I incorporate transitioning from one color to another? Currently the bulb uses last state, which is okay as last state will generally be red at full brightness … but I’d like to fade from red at low brightness in the morning, slowly to medium brightness in yellow.
platform: state
entity_id: your_motion_sensor
to: 'on'
condition:
- condition: sun
after: sunset
- condition: sun
before: sunrise
data_template:
brightness: 125
rgb_color: >
{% if now().hour > 19 or now().hour < 7 %}
[255, 255, 204]
{% else %}
what ever color
{% endif %}
- service: whatever other action you want
the time condition is only referenced to midnight so “hour > 19 or < 7” is between the hours of 7 pm & 7 am.
platform: state
to: 'off'
I know this turns the light off, but I want to turn them off after x amount if inactivity. Additionaly, would switch.turn_off be better than light.turn_off?
something like this:
platform: state
to: ‘off’
for:
minutes: 3
This would turn light off after 3 minutes of inactivity, correct? Thank you so much for your help, the rgb “else, endif” makes so much sense seeing it like that.
EDIT: Additionally, could I use the same condition: sunrise and condition: sunset variables for determining when the lights turn red instead of determining, for instance, between 7pm and 7am? Both would be very useful.
I’ve just started to make the transition from zha to zigbee2mqtt myself.
I have a Nortek HUSZBZ-1 stick that’s been acting up lately so I decided to try out Zigbee2mqtt. After waiting for over a month for the equipment to get here from China I finally got the stick flashed a couple of days ago. Now I need to start switching my lights over to the new stick.
Maybe this thread can help me out in figuring out how to use MQTT to set the brightness of the light for my own use, which is something I hadn’t even started to look into yet.
I’ve used MQTT for a while now for just basic things but never needed to look into passing brightness or color settings via MQTT. I suspect it shouldn’t be too hard tho.
