Automated looping dashboard help?
hey all im not very good at yaml i run most of my home assistant automations through the node red addon. however id like to use Home assistant as my dashboard instead of Dakboard on my tv
my issue. id like to be able to switch between dashboards on a select user (eg: user.mainhub) on a loop (eg every 5 minutes change to “whichever dashboard i select” then 5 minutes later “swich to next choice of dashboard and so on then once the flow is complete start again”)
building the loop in node red i can understand, but i have absololutely no idea how to make a node or callservice or… that can accomplish this or if its even possible.,
and example flow would be
(any device user. Mainhub is logged into) display (dashboard inside) wait 5 minutes (any device user. Mainhub is logged into) display (dashboard outside) etc. and loop to start
sorry in advance if this is a dumb question, id just like to use homeassistant instead of dakboard
