Automated Plant Watering v1
This blueprint handles keeping my garden / flower bed watered while taking into account soil moisture and the forecast for the day. There are a lot more details on my blog at Automated Plant Watering | The Comfy Seat
I have one instance of the blueprint associated with each flower bed. The blueprint also allows you to account for needing to water each bed separately as I have found that there isn’t enough water volume when watering them at the same time. This is accomplished via the Pre-actions section of the blueprint like shown here:
The screenshot shows a 1 minute delay as the first part of the pre-action. This is to give the other instance of the blueprint time to start running. The other instance has similar valve checks for the dahlia bed, but no delay. That one will water first and then this one will water when its finished. If I add a third valve, I may have to change the logic here. On the plus side, you can put any logic you want in this section.
blueprint:
  name: Garden Sprinkler Control
  description: >-
    Control sprinklers based on soil moisture with limits based on the day of the
    week. The idea is to lightly water every other day and water heavier once
    every two weeks.
  domain: automation
  input:
    garden_name:
      description: >-
        The name of this garden that will be used in notifications.
        The notification will make the most sense if this name is all lower case.
      default: flower bed
      selector:
        text:
    soil_moisture_sensor:
      name: Soil Moisture Sensor
      description: >-
        The sensor that tracks the moisture of the area to be watered by the sprinklers.
        This sensor should be in range of the water spare of at least one sprinkler so that
        accurately records the change in moisture resulting from the sprinklers running.
      selector:
        entity:
          filter:
            - domain: sensor
              device_class: humidity
    water_valve:
      description: The water valve that sends water to the sprinklers
      selector:
        entity:
          filter:
            - domain: valve
    last_watered_helper:
      name: Last Watered Helper
      description: input_datetime helper to track when the sprinkler was last turned on
      selector:
        entity:
          filter:
            - domain: input_datetime
    hourly_forecast_sensor:
      name: Hourly Forecast Sensor
      description: >-
        The name of the sensor containing hourly forecast data under the "forecast" attribute.
      selector:
        entity:
          filter:
            - domain: sensor
    pre_actions:
      description: >-
        Actions to put at the before all other actions. The default 1ms delay is here as a place
        holder since something must be specified. It can be removed in favor of other actions, if desired.
        The use case for this is to allow adding in a delay and/or wait based on another valve being open.
      default:
        - delay:
            hours: 0
            minutes: 0
            seconds: 0
            milliseconds: 1
      selector:
    notification_service:
      description: >-
        The service to send notifications to. Note that only message is set in the service call
        as that is all that is needed by the Telegram Bot notification service.
      default: telegram_bot.send_message
      selector:
        text:
    first_window_start:
      name: First Watering Window Start Time
      description: >-
        The earliest time in the day that watering can occur. Generally, this will
        be some time in the morning.
      default: "08:00:00"
      selector:
        time:
    first_window_end:
      name: First Watering Window End Time
      description: The latest time that watering can occur before the heat of the day
      default: "13:00:00"
      selector:
        time:
    second_window_start:
      name: Second Watering Window Start Time
      description: >-
        The earliest time in the evening that watering can occur. Generally, this will
        be some time after the heat of the day.
      default: "17:30:00"
      selector:
        time:
    second_window_end:
      name: Second Watering Window End Time
      description: The latest time in the evening that watering can occur.
      default: "19:30:00"
      selector:
        time:
    minimum_soil_moisture:
      name: Minimum Soil Moisture
      description: Below what percentage moisture should the sprinklers come on?
      default: 41
      selector:
        number:
          min: 0
          max: 100
          unit_of_measurement: "%"
          mode: box
    minutes_to_water_lite:
      name: Minutes To Water Lite
      description: >-
        Most days are a lite watering. During these, how many minutes should
        the sprinklers run for?
      default: 2
      selector:
        number:
          min: 1
          max: 5
          unit_of_measurement: minutes
          mode: box
    minutes_to_water_heavy:
      name: Minutes To Water Heavy
      description: >-
        Roughly every other Sunday a longer watering is done. During this one,
        how many minutes should the sprinklers run for?
      default: 8
      selector:
        number:
          min: 5
          max: 20
          mode: box
mode: single
variables:
  second_window_start: !input second_window_start
  soil_sensor: !input soil_moisture_sensor
  hourly_forecast_entity: !input hourly_forecast_sensor
  sprinkler_valve: !input water_valve
  garden_bed_name: !input garden_name
  last_watered_helper_entity: !input last_watered_helper
  - platform: numeric_state
    entity_id:
      - !input soil_moisture_sensor
    below: !input minimum_soil_moisture
condition:
  - condition: and
    conditions:
      - condition: template
        value_template: "{{ (now().day % 2) == 0 }}"
        alias: Test if even number date
      - alias: Test time & precipitation odds
        condition: or
        conditions:
          - alias: Within first watering window and precipitation unlikely?
            condition: and
            conditions:
              - condition: time
                after: !input first_window_start
                before: !input first_window_end
                value_template: >-
                  {% set evening_start_hour = int(second_window_start.split(':')[0]) %}
                  {% set hours_til_evening_window = (evening_start_hour - now().hour) %}
                  {% if hours_til_evening_window > 0 %}
                  {{ (state_attr(hourly_forecast_entity,
                  'forecast')[:hours_til_evening_window] |
                  map(attribute='precipitation_probability') | list | max) < 50
                  {% else %}
                  {{ false }}
                  {% endif %}
                alias: Rain likely before evening window
          - condition: time
            after: !input second_window_start
            before: !input second_window_end
            alias: Within second watering window?
      - alias: Not watered yet today
        condition: template
        value_template: >-
          {{ as_datetime(states[last_watered_helper_entity].state).day !=
          now().day }}
  - alias: "Run the pre-action(s)"
    choose: []
    default: !input pre_actions
  - service: !input notification_service
    metadata: {}
      message: >
        Started watering the {{ garden_bed_name }}. Its current soil moisture is
        {{ states(soil_sensor) }}%.
    alias: Send started watering
  - service: valve.open_valve
    metadata: {}
    data: {}
      entity_id: !input water_valve
    enabled: true
  - service: input_datetime.set_datetime
    metadata: {}
      datetime: "{{ now() }}"
      entity_id: !input last_watered_helper
  - if:
        value_template: "{{ (now().weekday()) == 6 }}"
        alias: If Sunday
    then:
      - delay:
          hours: 0
          minutes: !input minutes_to_water_heavy
          seconds: 0
          milliseconds: 0
        enabled: true
    else:
      - delay:
          hours: 0
          minutes: !input minutes_to_water_lite
          seconds: 0
          milliseconds: 0
        enabled: true
    alias: If Sunday water for longer
  - service: valve.close_valve
    metadata: {}
    data: {}
    enabled: true
    metadata: {}
      message: >-
        Finished watering the {{ garden_bed_name }}
    alias: Send finished watering
Hi there
Thanks for your blueprint.
HHCC xiaomi plant monitor are not detected as a soil moisture sensor. So I can configure the plan.
Could you show me?
Maybe customize the entity so that it does indeed show up… seems like it should work, in theory. Home Assistant Core Integration - Home Assistant
Unfortunately I have the same problem. I tried to rename my moisture-entity to humidity, since these are the sensors that are found, but no luck :frowning:
Since there are no github repo to contribute then I added extra domain to work with switch and moistures.
      description:
        the sprinklers. This sensor should be in range of the water spare of at least
        one sprinkler so that accurately records the change in moisture resulting
      selector:
        entity:
          filter:
            - domain:
                - sensor
              device_class:
                - humidity
                - moisture
          multiple: false
          reorder: false
    water_valve:
      selector:
        entity:
          filter:
            - domain:
                - valve
                - switch
          multiple: false
          reorder: false
