Automated Security: IP-Based Bypass for Cloudflare Zero Trust access to self hosted applications
What this achieves
This setup provides access to locally hosted services (Home Assistant, Immich, Frigate, Paperless, etc.) without sacrificing security. By using an iOS Shortcut that triggers when you leave Wi-Fi, your mobile device automatically adds its current IP address to a “Safe List” in Cloudflare.
This allows you to maintain a strict “MFA-Required” policy for the open internet, while granting a “Bypass” (no login screen) to your trusted mobile devices. It essentially treats your mobile data connection as a “Known Network,” similar to how your home internet functions, making the external access experience much smoother for family members (WIFE FRIENDLY!!)
After almost 12 months of reading posts, AI bots and LOTS of trial and error… below is how I ended up doing it for me and thought others may be interested. This is not just for HA, it is for other applications. Of course I say support Nabu Casa…
1. Create your CF Safe IP List
Navigate to Zero Trust → Reusable components → Lists.
  1. Create manual list:
    • List name: safe-ip-list
    • List type: IP addresses
    • Add entry: Enter one static IP you wish to keep (e.g., your home internet).
  2. Gather IDs for the shortcut & script later on:
    • Click the three dots on your new list → Edit.
    • Check the URL bar. It should look like: https://one.dash.cloudflare.com/ACCOUNT_ID/reusable-components/lists/LIST_ID
    • Save the ACCOUNT_ID and the LIST_ID.
2. Generate API Token
  1. Go to the main Cloudflare Dashboard (top left).
  2. Select 3 dots next to your name → Account API Tokens.
  3. Create Token → Create Custom Token → Get Started.
  4. Permissions:
    • Account → Account Filter Lists → Edit
  5. Save the Bearer TOKEN.
  6. Note: If you run into permission issues, you may also need:
    • Account → Zero Trust → Edit
    • Account → Access: Apps and Policies → Edit
3. Create the Access Policy
Navigate to Zero Trust → Access → Policies → Reusable policies.
  1. Add a policy:
    • Name: IP-Exclude
    • Action: Bypass
    • Session Duration: 24 hours
  2. Add the rule - Navigate to Add rules → Add include
    • Rules: Selector: IP list
    • Value: safe-ip-list
4. Apply Policy to Applications
Navigate to Zero Trust → Access controls → Applications.
  1. Edit your application (e.g., Home Assistant, Immich) – Note; If you don’t currently have an application Add an application → Self-hosted
  2. Under Policies, select IP-Exclude.
  3. Confirm.
Note: Ensure your Tunnel public hostname routes match the Application subdomain under Networks → Connectors → Tunnel → Configure.
If you don’t already have your applications created and host names linked to your local service, you need to do that as well.
Zero Trus → Networks → Connectors → 3 dots next to the tunnel → Configure → Published application routes → Then that subdomain/domain needs to match the application, and you just put the local address of your service below. Ie. HA = http → 192.168.1.10:8123
You need to repeat this process for each application (e.g., Home Assistant, Immich, etc)
It should be noted that I have two policies per application, the above ‘bypass’ as well as an ‘allow’ policy which has email addresses in the include and my country in the require. Please read up or watch videos for further info on how
5. Automate IP Updates (iOS Shortcuts)
  1. Import Shortcut: Cloudflare IP Update Shortcut
  2. Edit Shortcut: Enter your ACCOUNT_ID, LIST_ID, and TOKEN (there are 2 of each, 6 in total to enter).
  3. Create Automation:
    • Open Shortcuts App → Automation → +.
    • Search for Wi-Fi → Select Is Disconnected.
    • Select Run Immediately.
    • Set the action to run the shortcut you just saved.
Note; This process will only add new IP’s, not duplicates. PS. I am currently only using iOS primarily for mobile devices, so I can’t provide the Android equivalent.
6a. Housekeeping (Python Script)
To keep your IP list clean and secure, use this Python script to remove old, inactive mobile IPs.
Requirements
  • Python 3.x
  • Requests library: pip install requests
Save as cloudflare-iplist-cleaner.py:
#!/usr/bin/env python3
import requests
import json
from datetime import datetime
print(f"=== Run started {datetime.now().strftime('%Y-%m-%d %H:%M:%S')} ===", flush=True)
# --- Configuration ---
ACCOUNT_ID = "CF_ACCOUNT_ID"
LIST_ID = "YOUR_LIST_ID"
TOKEN = "YOUR_ACCESS_TOKEN"
TARGET_DESCRIPTIONS = ["Mobile phone IPv6 iOS shortcut", "Mobile phone IPv4 iOS shortcut"]
KEEP_COUNT = 4
URL = f"https://api.cloudflare.com/client/v4/accounts/{ACCOUNT_ID}/gateway/lists/{LIST_ID}"
HEADERS = {
    "Authorization": f"Bearer {TOKEN}",
    "Content-Type": "application/json"
def clean_cloudflare_list():
    response = requests.get(URL, headers=HEADERS)
    if not response.ok:
        print(f"Failed to fetch list: {response.text}")
        return
    data = response.json()
    items = data.get("result", {}).get("items", []) or []
    to_remove_ips = [] # Changed to store just strings
    for desc in TARGET_DESCRIPTIONS:
        filtered_items = [i for i in items if i.get("description") == desc]
        # Sort newest to oldest
        filtered_items.sort(key=lambda x: x['created_at'], reverse=True)
        if len(filtered_items) > KEEP_COUNT:
            excess_items = filtered_items[KEEP_COUNT:]
            for item in excess_items:
                # FIX: Add only the string value, not a dictionary
                to_remove_ips.append(item["value"])
                print(f"Marked for deletion: {item['value']} ({item['description']} - {item['created_at']})")
    if to_remove_ips:
        # The API expects: {"remove": ["1.1.1.1", "2.2.2.2"]}
        payload = {"remove": to_remove_ips}
        patch_response = requests.patch(URL, headers=HEADERS, json=payload)
        if patch_response.ok:
            print(f"Successfully removed {len(to_remove_ips)} old entries.")
        else:
            print(f"Error during removal: {patch_response.text}")
    else:
        print("No cleanup necessary.")
if __name__ == "__main__":
Change the TARGET_DESCRIPTIONS above (Ie. Mobile phone IPv6 iOS shortcut) to suit what you called them in the shortcut description.
Give permission to execute the script
chmod +x cloudflare-iplist-cleaner.py
6b. Housekeeping (Python Script - automation/crontab)
You can run it as often as you like, here is what my crontab looks like:
0 3 * * * /usr/bin/python3 /home/spaldo/cloudflare-iplist-cleaner.py >> /home/spaldo/cf_cleaner.log 2>&1
Disclaimer; I am not a security expert and this may not suit you if you are after super security…
Thanks to @Lewis and @final_blueberry in this forum who also worked on similar solutions.
What secures your python scripts that hold the keys to the kingdom?
Your wife and family’s password to access HomeAssistant?
Your castle may have high walls and a deep moat, but if the drawbridge is left down…
Doctor Spalding!
You took inspo and blasted this past 11!
Nice work!
My meagre contribution is hopefully not outdated…
But I am not sure I knew about the CF API and updating entries programmatically.
Your method would make access even more secure.
Fantastic!
I am not sure I understand the question. The script is hosted locally on one of my VM’s. This may not be for everyone…
Again, I don’t understand the user/pass question, that is entered or stored via the app, nothing to do with this. This is only the method of transport from your device to the hosted service, the logins, etc for Immich, HA, etc are either handled by the browser or respective application.
How do you give your family run only access to your scripts and not read access to examine them.
The family doesn’t need access to the scripts at all. It is only run from my VM by me (crontab). It is just cleaning up old IP addresses from the CF list.
Ok. Makes sense.
this is awesome, thanks for posting it! im just curious, how do you handle joining other wifi networks? for example, you get to a family members home wifi - wouldn’t you lose your ability to hit your apps? seems like the iOS shortcut could compensate for this by looking for events like when you join a particular network, but I’m not too familiar with iOS shortcuts and if it could handle this complexity.
I haven’t really added that because I don’t join many other wifi networks but it would be pretty easy, two methods come to mind and it just depends if you want to keep their IP long term or just temporarily.
  1. Temporarily; this would be the easiest way… just create a new automation in the shortcuts app, instead of triggering the shortcut when you leave a wifi network, you would trigger when you join. Ideally I would say select the wifi name so you’re not doing it for public wifi but you could do all networks as well if you don’t care…
  2. Long term; two methods:
    A) manually add the ip via the CF dashboard in your list
    B) Duplicate the shortcut, then change the descriptions to something else that the cleanup script won’t catch. Then create a new automation in shortcuts (similar to option 1) to fire when you join a wifi, select the duplicate script. Except this won’t wipe the IP in the cleanup script because it has a different description …
Recently we went to a hotel and I just added the IP manually in the CF dashboard. However you also could just run the script (original or duplicate) manually in shortcuts and not automate as well.
Thanks for this, just set it up now. Was having issues with authorization at first, but then realised “Bearer” needs to come before the API key value for the ‘Authorization’ header!
Yep, it has to be exactly like that. You can play around with the full curl command in terminal to check if it gives an error first if you wanted as well
Thank you for sharing this and including all the detailed steps in CF website. I’m so bad at navigating through CF for some reasons, it helps a lot. Previously, I did something similar to this but using the IP whitelist rule only as I didn’t know Zero Trust also has IP rules. I re-did everything with Zero Trust based on your instruction and it works well know, thanks so much!
I added 2 things, first is to notify via Pushover to make sure the cron job running as expected. Second thing is I have a separate iOS shortcut to manually add wifi that is not home wifi (with description as “Not home IPv4 iOS shortcut”). When the cron job run it will delete this and not retain any IP. I added the updated py file below if you want to check it out.
For the Shortcut, I run it when it join and leave my wifi’s SSID name. In the shortcut it will get the Network name, if it is then it will add ipv4 address and otherwise, it will add ipv6.
Edited: “It should be noted that I have two policies per application, the above ‘bypass’ as well as an ‘allow’ policy which has email addresses in the include and my country in the require. Please read up or watch videos for further info on how” >>> this part here, I’m curious how do you set the session for your email policy? Cause if I set it to 1 month (I only want to verify it once per month), then it will keep the session as 1 month and ignore the IP list rule once validated.
import requests
import json
ACCOUNT_ID = ""
LIST_ID = ""
TOKEN = ""
PUSHOVER_USER_KEY = ""
PUSHOVER_APP_TOKEN = ""
# Description: Keep Count
TARGET_DESCRIPTIONS = {
    "Mobile phone IPv6 iOS shortcut": 4,
    "Mobile phone IPv4 iOS shortcut": 4,
    "Not home IPv4 iOS shortcut": 0  # Delete all when cron runs
HEADERS = {
def notify_pushover(message):
    """Send notification to Pushover"""
    print(f"[PUSHOVER Notify] {message}")
    try:
        requests.post(
            "https://api.pushover.net/1/messages.json",
            data={
                "token": PUSHOVER_APP_TOKEN,
                "user": PUSHOVER_USER_KEY,
                "message": message,
                "device": "YOUR_DEVICE_NAME"     #edit with your device name here
    except Exception as e:
        print(f"[ERROR] Failed to send Pushover notification: {e}")
def get_current_ips(items):
    """Extract current IP list as a readable string"""
    ips = [item.get("value") for item in items if item.get("value")]
    return ", ".join(ips) if ips else "No items found"
    if not response.ok:
        error_msg = f"Failed to fetch list: {response.text}"
        print(error_msg)
        notify_pushover(f"CF List Cleaner Error: {error_msg}")
        return
    # === DEBUG: Print all descriptions ===
    print("\n[DEBUG] Current items and descriptions:")
    for item in items:
        print(f"  IP: {item.get('value')} | Description: '{item.get('description')}' | Created: {item.get('created_at')}")
    print()
    # === END DEBUG ===
    to_remove_ips = []
    for desc, keep_count in TARGET_DESCRIPTIONS.items():
        print(f"[DEBUG] Found {len(filtered_items)} items matching '{desc}' (keeping {keep_count})")
        if len(filtered_items) > keep_count:
            excess_items = filtered_items[keep_count:]
    if to_remove_ips:
            success_msg = f"Successfully removed {len(to_remove_ips)} old entries."
            print(success_msg)
            # Fetch updated list to show current state
            updated_response = requests.get(URL, headers=HEADERS)
            if updated_response.ok:
                updated_items = updated_response.json().get("result", {}).get("items", []) or []
                current_ips_str = get_current_ips(updated_items)
                notify_pushover(f"CF List Cleaner: Removed {len(to_remove_ips)} old entries.\n\nCurrent IPs:\n{current_ips_str}")
            else:
                notify_pushover(success_msg)
        else:
            error_msg = f"Error during removal: {patch_response.text}"
            print(error_msg)
    else:
        current_ips_str = get_current_ips(items)
        notify_pushover(f"CF List Cleaner: No cleanup necessary.\n\nCurrent IPs:\n{current_ips_str}")
Thanks for the reply @xzelz and thinking about different options, it is great and I am glad others are looking at it in this way.
Regarding the CF navigation, I totally agree. They do change the layout & naming of areas as well, which is annoying. I fear that in 6+ months it will all change and people will come here posting that the instructions aren’t correct!
I do like how there are so many variations on the shortcuts that you can make to suit your own connection method and needs.
Regarding your question at the bottom, I am not exactly sure I understand it… As long as it is connecting, does it matter if the authorisation is from the session cookie or IP rule? You can change the order in which CF looks at the verification, ie, make IP first or second. But for me (mainly wife) as long as it goes through without prompts, “we” are happy!
Thank you for the response, yes I was a bit overthinking on my end about the IP rule. It should be set Bypass like how you set it. I wanted something like 2 layers of protection, first layer is my Email rule with duration 1 month for example then the next layer would be IP rule. At the end I just set my setup like yours and forget about it :D, the Email policy will act as a fall back I guess.
This is truly a wonderful walkthrough and saved me a lot of time and troubles. I’ve been doing custom headers, but for apps that don’t allow them, I’ve just been twiddling my thumbs.
I saw you were doing an api.ipify.org call in the shortcut. You can simplify this by just using the Get current IP address shortcut which has an ipv4 and ipv6 toggle. Ipify was being a bit buggy for me, so this helped me fix it. Also, for anyone about to set this up, I’d recommend making a Text and Set variable combo for each ID/API key since it’ll help making inserting the contents (make sure to keep Bearer in the API header though or it’ll break).
I also added a the shortcut to my homescreen since I’m mainly using this for an audiobook/podcasting app (not HA lol) that I use when on walks/runs, so if I change cell towers, I can just run the shortcut and it’ll work again after a second.
Hi @nate-griff happy to see any other examples of shortcuts. I had problems with the ipv6 internal method, that’s why I kept both just using ipfy… very happy to see how your shortcut looks compared to mine if you are able to share a sanitised version?
I’m not an expert, although it works for me, I’m always willing to try better methods or tweak mine…
PS. I have my shortcut in the widgets, so you just need to swipe left. But either way works
Just FYI, for those that use this method, Cloudflare has made some type of change that has stopped the single ip list working. Let’s hope it is just a temporary issue and is resolved, but over in this thread one of the guys found a work-around:
https://community.cloudflare.com/t/access-policies-no-longer-match-ip-lists-only-ip-ranges-direct-on-policy/953212/3
If you use IP range policy and add the IPs directly into the policy, this seems to work as a temporary workaround.
I will try to adapt my method later today but FYI for those out there.
Update; Looks like if you change the policy type from ‘IP list’ to ‘IP ranges’ it might be ok. I will confirm later
@nate-griff Can you share your shortcut? I’m brand new with shortcuts and would love the example. I’m having issues with api.ipify.org as well, network connection issues.
