It would be great to add more condition like Solar power generation, power usage,
It would also be good to have triggers based off room temp or humidity
Looks excellent, thankyou for sharing, i will try
Can you add a scheduler Feature? Variable Times are better
planning what do you mean by a weekly schedule? Operation is planned on an hourly basis which also takes into account the presence at home so as to be more automatic.
A manuell helper scheduler is the best way i think, maby multiple for normal and holiday
What is the best way to troubleshoot this automation.
I can hear the AC getting some type of trigger but it does not turn on.
Only thing I can think of is my HVAC option in local tuya is auto not cold.
How are the seasons defined? I assume it doesn’t use the Season integration? Would it work properly in the southern hemisphere?
Thanks for your contribution!
you change the season manually from the blueprint switch. I didn’t rely on integration to avoid anomalous behavior.
I have a multisplit air conditioner at home with one central unit and multiple splits in different rooms.
And I control the air conditioning with the Sensibo system, which is integrated in Home Assistant, among other things.
Is it possible to run this blueprint with such integration?
I’m in a similar boat - I have 5 mini splits and I’d like to set up an automation that adjusts all of my rooms to different temperatures based on experience of how warm/ cold a room gets compared to another.
For starters I’m going to create a separate automation for each mini split (god I hope they add folders to home assistant for organization soon!!), but would a similar approach work for your hvac system?
