Hi all,
Since moving to a docker instance, I have not been able to get auto-discovery to work. To give you a quick recap.
When I first moved to a docker instance, I had a setup at home creating two different subnets. So the wifi was on one IP range and the wired on an other IP range. Auto-discovery did not work, but everything else seems to work, and I even got the wifi shelly plugs to work, even though I had different subnets.
Since I use plejd in my entire house I wanted to add everything to apple homekit, enabling apple homekit on the plejd gateway does not work, it has to be on the same IP range so I removed my old router and instead only use google wifi nest router.
Everything works, and I thought that the discovery should start to work also but it does not. I can’t add my home assistant as a hub to the homekit either, because it says that it can’t find it and connect to it.
Two problems, auto-discovery still does not work and I can’t add my home assistant to apple homekit.
I have a google mesh wifi setup.
Any tips would be helpful
