How many vehicles do you have on your account?
Two, but only one is tracked (i.e. track: false in known_devices.yaml for the unused vehicle)
Doesn’t the below fire when either vehicle is started?
- alias: "AutoPro Real-Time Event: ignition on"
hide_entity: true
platform: event
event_type: automatic_update
event_data:
type: "ignition:on"
Can someone help me understand how one retrieves the websocket object data once the event is triggered? For example, in the case of trip:finished, how do I access vehicle id, started_at, ended_at, etc fields? In other words, the items listed in this example:
EXAMPLE TRIP FINISHED OBJECT WEBSOCKET
"id": "f61ba3d5-a68e-43eb-a731-0db871b4d3a3",
"user": {
"id": "U_ffd955ba63db5c25",
"url": "https://api.automatic.com/user/U_ffd955ba63db5c25/"
"type": "trip:finished",
"created_at": "2015-04-12T17:45:18.123Z",
"time_zone": "America/Los_Angeles",
"location": {
"lat": 37.757076,
"lon": -122.448120,
"accuracy_m": 10,
"created_at": "2015-04-12T17:45:01.123Z"
"vehicle": {
"id": "C_507d6f1bd6d9b855",
"url": "https://api.automatic.com/vehicle/C_507d6f1bd6d9b855/"
"device" : {
"id": "021ac91c826b12eca99e685c"
"trip" {
// Trip Object (matches REST API)
@Coolie1101 Knowing that, one could then simply check the vehicle_id token in a condition to make sure it’s the vehicle of interest.
Yeah I have the exact same scopes as you but not getting real time location …
this is my setup
- platform: automatic
client_id: !secret automatic_client_id
secret: !secret automatic_secret
current_location: true
How do you enable / install Websocket in HA for Heartbeat functionality ?
Here’s my configuration:
device_tracker:
… and of course I have the Event Delivery Preference set to WEBSOCKET at Automatic Developer site.
Client type ?
Cofidential / Web or Public / Native ???
I am getting an error don’t know why
2017-09-17 19:59:54 INFO (Thread-6) [homeassistant.components.device_tracker.netgear] Scanning
2017-09-17 19:59:54 INFO (Thread-6) [pynetgear] Get attached devices
2017-09-17 19:59:54 INFO (MainThread) [aioautomatic.client] Creating session from oauth code.
2017-09-17 19:59:56 INFO (MainThread) [aioautomatic.session] Fetching vehicles.
2017-09-17 19:59:56 INFO (MainThread) [aioautomatic.session] Fetching trips.
2017-09-17 19:59:56 INFO (MainThread) [aioautomatic.client] Opening websocket connection.
2017-09-17 19:59:57 INFO (MainThread) [homeassistant.components.device_tracker.automatic] Websocket connected.
2017-09-17 20:00:02 ERROR (MainThread) [homeassistant.components.device_tracker.automatic]
Client Type: Confidential/Web
Thanks !!
Did you request to switch to production mode ?
No I did not
NEW PROBLEM:
While real time location tracking/events work fine right after an HASS restart, they stop working after about 12 hours. Best I can tell this problem surfaced at the same time the OAuth2 updates were made, but I can’t be sure (lots of reboots since then).
From the LOG:
2017-09-17 14:38:31 ERROR (MainThread) [homeassistant.components.device_tracker.automatic] err_invalid_refresh_token
**Typical (and expected) error at restart but OAuth2 authentication goes thru without issue + real time events work fine
14 Hours Later:
2017-09-18 04:59:11 ERROR (MainThread) [homeassistant.components.device_tracker.automatic] Websocket error detected. Connection closed.
2017-09-18 04:59:17 ERROR (MainThread) [homeassistant.components.device_tracker.automatic] Error opening websocket connection:
**ALL real time events stop (ignition:on/off, heartbeat location tracking, etc )…
ANYBODY ELSE having this issue?
Yes I am having the same issue after the fix in 0.52. Works fine after restart/reauth, but then stops working after sometime. I just restarted again this morning, so I will try to see exactly when it happens again.
I have two automatic pros…
Oh finally , Tommy this is what I was talking about … same problem here …
I just noticed that today it started updating again, even though I haven’t rebooted in 2-3 days.
However, I’m still getting the following error sporadically:
2017-09-19 11:01:17 ERROR (MainThread) [homeassistant.components.device_tracker.automatic] Websocket error detected. Connection closed.
Do you know how I can apply the above to the Automations below?
alias: Vehicle Started
trigger:- platform: event
event_data:
type: “ignition:on”
- platform: event
service: notify.telegram
message: Vehicle has Started. -
alias: Vehicle Speeding
event_data:
type: “notification:speeding”
action: - service: notify.telegram
message: Vehicle is speeding.
- platform: event
I currently have Automations setup for the following which fires when the event is updated, but I have no Idea how to get the additional info like which vehicle or if possible the vehicle location.
Getting :
err_internal_error
Any ideas
Starting getting this today too after upgrading to 0.54
