Automatic sanitizer using esphome + nodemcu + ultrasonic sensor
I want to make a automatic sanitizer using esphome + nodemcu + ultrasonic sensor + sprayer with motor ,
i have successfully integrated all these items and started it and it is working but there is some problem ,
sometime when the device is restarted or switched off and on , then
the sprayer starts automatically and it does not stops ,
and
sometime the ultrasonic sensor starts to work reverse ,
please help
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  networks:
  # Optional manual IP
  manual_ip:
  ap:
    ssid: "Sanitizer Node Fallback Hotspot"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password:
ota:
  password:
web_server:
  port: 80
  - platform: ultrasonic
    trigger_pin: GPIO4
    echo_pin: GPIO5
    update_interval: 1s
    filters:
      filter_out: nan
    timeout: 3m
switch:
- platform: gpio
  pin:
    number: GPIO14
    inverted: yes
  restore_mode: always off
binary_sensor:
    device_class: presence
#    filters:
#      - invert:
#      - delayed_on: 100ms
#      - delayed_off: 100ms
#      - delayed_on_off: 100ms
    lambda: |-
      if (id(ultrasonic_sensor).state < 0.9) {
        // in range
        return true;
      } else {
        // out of range
        return false;
    on_state:
      then:
        - switch.toggle: relay1
Don’t toggle in on_state, use on_press and on_release. That will be how it’s getting reversed and maybe the other issues as well.
I’m surprised it let you compile this:
It should be:
restore_mode: ALWAYS_OFF
no this did not solve my problem , as i cannot use on_press or on_release as it is a sensor ,
both are correct as it shows (ALWAYS_OFF) while validation .
It’s not documented.
Yes you can, you made a binary sensor.
I’m referring to the presence binary_sensor.
