Question is: how can I achieve the same but in a more generic way? I have multiple ZWave devices, so I want an automation that can do the same for each device without having to create 1 entry per device.
I’ve got a sensor setup to detect when a zwave node fails. After 5 minutes, I have an automation run to do the repair. The automation may need some improvement. It only runs once if the node is dead.
sensors:
zwave_failures:
entity_id:
- zwave.back_porch
- zwave.bubble
- zwave.bubble_closet
- zwave.bubble_fan
- zwave.cat_door
- zwave.dining_room
- zwave.dryer
- zwave.foyer
- zwave.front_porch
- zwave.fuzzy_lane
- zwave.fuzzy_lane_closet
- zwave.fuzzy_lane_fan
- zwave.hall_bar
- zwave.hall_bath
- zwave.kitchen
- zwave.kitchen_bar
- zwave.living_room
- zwave.living_room_fan
- zwave.master_bath_toilet
- zwave.master_bath_vanity
- zwave.mermaid_room
- zwave.mermaid_room_closet
- zwave.music_room
- zwave.music_room_fan
- zwave.music_room_outlet
- zwave.unknown_node_33
friendly_name: "Z-Wave Dead Nodes"
value_template: >
{% macro is_failed() %}
{%- set value = true -%}
{%- set domains = ['zwave'] -%}
{%- for domain in domains -%}
{%- for item in states[domain] if ((item.attributes.is_failed is defined and item.attributes['is_failed'] == value))-%}
{% if (item.attributes.is_failed is defined and item.attributes['is_failed'] == value) -%}
{{ item.name }}{% endif -%}
{%- endfor -%}
{%- endfor -%}
{% endmacro %}
{{ is_failed() |trim != "" }}
binary_sensor:
sensors:
zwave_fix:
friendly_name: "Z-Wave Auto Repair"
icon_template: mdi:z-wave
delay_on:
seconds: 300
value_template: "{{ is_state('sensor.zwave_failures', 'True') }}"
automation:
- alias: 'zwave auto repair after 5 minutes'
initial_state: 'on'
platform: state
entity_id:
- binary_sensor.zwave_fix
to: 'on'
- service: zwave.test_network
