Automatically detect if audio is playing
Hi, I’m using home assistant to play sound on my powered speakers connected directly to 3.5mm audio output. I want to be able to turn them on/off when needed, so I connected them through a smart plug.
Now the challenge is to determine whether any sound is coming out of the computer to trigger on/off automation.
I found this PulseAudio command which gives me output IDLE or RUNNING:
pactl list | grep State
It works great, but I’m struggling to get it working in HA.
My plan is to run automation every 5 seconds which will check for IDLE/RUNNING status and control the smart plug accordingly.
I created shell command for that, but whenever I run it, it returns an error:
shell_command:
  check_audio_output: /bin/bash -c "pactl list | grep State"
output:
stdout: ""
stderr: "/bin/bash: line 1: pactl: command not found"
returncode: 1
Same command works when I run it in terminal.
Anyone has any ideas why does it fail or maybe there is a better way to check for sound playing?
Did you ever find an answer to this? I’m also interested in exposing to my HA whether my Linux desktop is playing audio (ideally, if it’s playing to headphones, but I’ve got to start somewhere).
