Hey all,
I’m extremely new to Home Assistant and please bare with me as I’m still learning. I researched this online, but can’t get an immediate answer.
In a nutshell, I set up OwnTracks and MQTT to integrate with my iPhone. With the appropriate settings, Home Assistant knows when my device is at home or away. What I’m trying to accomplish is to get my alarm.com panel to disarm when I’m close to my house. I know there is a forum to where there is an alarm.com issue. But that is unaffected by me under OSX. I can arm and disarm to my content.
Here is what I configured within my configuration.yaml
automation:
platform: state
entity_id: device_tracker.myphone_deviceiphone
# trigger for determining when at home
to: 'home'
service: alarm_control_panel.alarm_disarm
entity_id: alarm_control_panel.ha_alarm
I renamed the config to “myphone” just for security purposes. With this config, my system does not disarm. If I look at the Logbook within the UI, here is what I see:
1:33 PM "Myphone is Away"
2:21 PM "Myphone is at home"
2:21 PM "Automation, 0 has been triggered"
If I’m understanding correctly, the problem is with the trigger? I’m guessing that maybe the problem is with “not_home”. If I look at the history, maybe this should be “not home” since that is what’s displayed in history. I was simply following an example. Also, is there a way that I can run my action somewhere in Homeassistant, just to make sure that’s correct.
I know some of you may caution me about disarming with geolocation. This is just a proof of concept. In addition, I’m doing extensive auditing by using a separate alarm.com account for all these actions. I appreciate any input you may have on where I went wrong with this rule.
