Automatically set sensor state at HA startup
Im having an issue with a siren in my environment. Everytime HA is restarted, two of the settings are returned to 0, while i need one of them to be ‘3’
sensor.vision_zm1601eu5_battery_operated_siren_alarm_type
How (and where) can I define that this value is ‘3’ every time the service starts?
Thanks.
that value should surely be saved in the device itself. I use Hass.IO and go to the z-wave config page where you can assign these values and it sends them out to the device. If you are not using Hass.IO I guess you will need to do this from OpenZWave Control Panel or whatever
The Z-Wave control panel is in all the installs of Home Assistant, and has been since before Hass.io was released :wink:
As @sparkydave said, those are provided by, and stored in, the device.
Yeah, that’s what I meant. I use Hassio so it’s built in rather than openzwave CP which seems like a lot more effort from what I can tell.
Thanks lads, I was using AIO and just recently switched to hassbian. so used to ozwcp. Found the setting and fixed it.
<3
Hi Vince,
I see you are using the Vision ZM1601.
Can you tell me what Z-Wave Entity I need to put this device into Strobe only?
The documentation talks about parameters, but not z-wave entity instances.
Thanks in advance,
Olav
