137 / 5.000
Risultati della traduzione
Risultato di traduzione
Good evening, I am new to this subject, I wanted to know if there is a command to shut down the system at a certain time of day thanks.
137 / 5.000
Hi, welcome to the forum!
I don’t think there is such an option.
But why would you want to shut down your HA server automatically/scheduled?
If you have integrated HA in your everyday life, how will things run without it.
How about…?
triggers:
- trigger: time
at: "12:00:00"
actions:
- action: homeassistant.stop
Hi Jack, I tried this with HAOS but it doesn’t stop the machine/system over here, only Core.
Yes, I just discovered that too!
This is what I use when my laptop battery is about to die after a power cut:
actions:
- action: hassio.host_shutdown
@marcavatar note that I agree with @Nick4 and personally think that shutting down your server is a bad idea.
I only use it to do a graceful shutdown in case of power loss, and only because I configured my server to automatically start up once power is restored.
What is the reason for wanting to shut your system down every day?
Thanks for sharing that!
I didn’t know that ‘hassio’ is still so much present so tried in the Developer tools with home assistant and that’s how I found homeassistant.stop.
Also looked at the CLI but now I ‘found’:
Sorry if I have not answered you in this time but I have not been at home and thank you for answering me, I tried but it does not work do you have a tutorial I am completely inexperienced in the matter, a second question if you do not mind, I have integrated jellyfin mediaserver, is it possible to create a button to restart the jellyfin service, it is found in docker on openmediavault thanks.
Show what you have already.
for now I only have switches on the screen nothing special just external hard drives that I use every now and then with jellyfin for now I’m inexperienced and so I didn’t want to keep the card on all day then in the future when I get the hang of it maybe I won’t turn it off.
Well in that case, there is a shutdown option on the Settings page (sidebar menu) → 3 dots in the right hand corner so you can manually shut down your server.
Regarding you jellyfin question: can’t help you there.
