I found an automation for switching the HVAC mode based on the temperature of the room, but it doesn’t seem to be automatically running. If I manually run the script, it works perfect. The climate & sensor are in the description line.
Any ideas?
alias: BR Climate Auto Mode
description: sensor.br_th_temperature climate.br_climate
value_template: >
{% set mode = states('climate.br_climate') %}
{% set trg = state_attr('climate.br_climate', 'temperature')|float %}
{% set cur = states('sensor.br_th_temperature')|float %}
{{ mode == 'heat' and trg <= cur - 2 or mode == 'cool' and trg >= cur + 2 }}
- service: climate.set_hvac_mode
entity_id: climate.br_climate
data_template:
hvac_mode: >
{{ 'heat' if mode == 'cool' else 'cool' }}
mode: single
