I did a thing, now I’m fat
But now I can make charts in Google Sheets. So there’s that.
Synopsis
Step on scale - weight auto-records to a Google Sheet for daily tracking
Requirements
None. I was bored, found a bargain bin BT scale and then this just happened. I learned a few things along the way.
The scale
A SPRI branded scale that broadcasts weight to the world using a Cheapsea manufacturer id. I learned how to extract hex byte array data, so that’s good.
The important ESPHome yaml bits;
unit_of_measurement: 'lb'
esp32_ble_tracker:
on_ble_advertise:
- mac_address: '5c:ca:d3:ff:60:45' # MAC address in lowercase of Cheapsea-BLE
then:
- lambda: |-
ESP_LOGD("ble_adv", " Advertised manufacturer data:");
for (auto data : x.get_manufacturer_datas()) {
ESP_LOGD("ble_adv", " - %s: (length %i)", data.uuid.to_string().c_str(), data.data.size());
ESP_LOGD("ble_adv", " - %s:", format_hex_pretty(data.data).c_str());
if(data.data.size() == 18) {
uint16_t weight = uint16_t(data.data[2]) | (uint16_t(data.data[3]) << 8);
weight = weight / 4.533333333333333;
id(myweight).publish_state(weight);
There are a bunch of Github repo’s/gists based around these scales (OpenScale…) but they didn’t match the bytearray length or indexes. So be prepared to run the dev branch of the ESPHome Add-On if you need to use format_hex_pretty()
HA Automation
As straighforward as they get…
- platform: state
entity_id: sensor.embarrassment
condition:
- condition: template
value_template: '{{ states(''sensor.embarrassment'') not in [''unavailable'',''unknown'',''none'']
- service: shell_command.submit_weight_form
data: {}
mode: single
The Google parts
Getting the data into HA is pretty straightforward. Getting the data “into Google” took some investigation as it was a new endeavor for me. Sometimes when there are lots of libraries, API’s, modules, etc, it can be overwhelming.
I started looking at API keys, restricting IP’s and POST’ing data, but then found this idea. Use a Google Form to append a Google Sheet. Is it open and insecure? Yes. Do I have a requirement for security? No. Will people complain about this? Yes. Find my form
The great part about Google Chrome is that the Developer Tools literally gives you a copy/paste curl command for any form submission.
shell_command:
submit_weight_form: curl 'https://docs.google.com/forms/u/0/d/e/top_secret_form_id/formResponse' --data-raw 'entry.11235325423={{states("sensor.embarrassment")}}' --silent >/dev/null
