Automatically Turn off Nest Thermostat at 3 am
Is it possible to set an automation to turn off the thermostat at a certain time?
if the thermostat can be turned off with a command, then yes
  platform: time
  at: '03:00:00'
I’m not sure if it could. Does anyone know?
Did you look at the service options?
Currently there is a single nest.set_mode service available to switch between “away” and “home” modes.
So currently there’s not way to setup automation?
# Example script to set Nest to away.
set_nest_away:
  sequence:
    - service: nest.set_mode
        home_mode: away
automation:
#Runs Script at 3am
  - alias: Set Nest to Away
      - platform: time
        at: '3:00'
      service: script.turn_on
      entity_id: script.set_nest_away
Of course there is, there is just no way to turn to “OFF”. See @Coolie1101 code below.
