I think something like this might work for you:
- alias: Turn off air purifier office
platform: numeric_state
entity_id: fan.xiaomi_air_purifier_office
value_template: "{{ state.attributes.aqi }}"
below: 15
for:
minutes: 3
- service: fan.turn_off
- service: fan.xiaomi_miio_set_favorite_level
level: X
- alias: Turn on air purifier office
above: 15
for:
minutes: 3
- service: fan.turn_on
- service: fan.set_speed
data_template:
speed: >
{% if trigger.to_state.attributes.aqi | int > 30 %}
favorite
auto
- alias: Change favourite level air purifier office
platform: template
value_template: >
{{ is_state('fan.xiaomi_air_purifier_office', 'on') and
state_attr('fan.xiaomi_air_purifier_office', 'aqi')|int > NN }}
- wait_template: >
{{ is_state('fan.xiaomi_air_purifier_office', 'off') or
state_attr('fan.xiaomi_air_purifier_office', 'aqi')|int <= NN }}
timeout: '00:10:00'
continue_on_timeout: 'true'
- condition: template
value_template: >
level: Y
Let me know if you have any questions.
artkrz
(Artur Krzywanski)
November 30, 2018, 7:33pm
3
Thank You, will try it out and report back.
artkrz
(Artur Krzywanski)
December 1, 2018, 11:10pm
4
@pnbruckner Your solution works (did not test setting favourite level yet) but will the “on” part with numeric state trigger once? Or will evaluate AQI constantly? For example, AQI is 16, so automation set purifier to “on” and mode to “auto”, what if in the meantime AQI jumps to 35? Will the automation change the mode to “favourite”? Or will it stay at “auto”?
A numeric_state trigger will trigger when the condition (e.g., above 15) becomes true, and will not trigger again until that condition becomes false (e.g., 15 or below) and then becomes true again (back above 15.)
But you also have “for 3 minutes.” That means the “above 15” condition needs to stay true for that long before it actually triggers.
So, let’s say it raises to 16. Then let’s say it stays above 15 for 3 minutes. At that time the action will run, and depending on what the value is at that time (above 30 or not) it will set the speed accordingly. Let’s say it’s 30 or below at that time (so it sets the speed to auto) and then, without going to 15 or below, eventually goes to above 30. Since it hasn’t gone to 15 or below first it won’t trigger again, so the speed will stay at auto.
If you want it to trigger again if it goes above 30, then you need to add another trigger:
- platform: numeric_state
above: 15
for:
minutes: 3
above: 30
data_template:
speed: >
favorite
auto
Now once it goes above 30 it will trigger again and set the speed to favorite. You can add the “for” clause to this second trigger, too, if you want.
blackhu
(Xiaoluohao)
December 20, 2018, 1:37am
6
pnbruckner:
我觉得这样的事情对你有用:
HI artkrz. I have a problem , my xiaomi air purifiers used xiaomi_miio compose setting fan. In homekit just a switch,can not change speed mode.please help me
artkrz
(Artur Krzywanski)
December 20, 2018, 8:44am
7
Not using homekit but here’s my current setup for controlling the Air Purifier 2s:
# Set input states when HA starts or states change
- alias: Set state for air purifier office mode input
- platform: homeassistant
event: start
- platform: state
entity_id: sensor.xiaomi_air_purifier_mode_office
service: input_select.select_option
data_template:
entity_id: input_select.air_purifier_mode_office
option: '{{ states.fan.xiaomi_air_purifier_office.attributes.mode }}'
- alias: Set state for air purifier office favorite level input
event: start
- platform: state
entity_id: sensor.xiaomi_air_purifier_favorite_level_office
service: input_number.set_value
data_template:
entity_id: input_number.air_purifier_favorite_level_office
value: '{{ states.fan.xiaomi_air_purifier_office.attributes.favorite_level | int }}'
# Inputs
- alias: Air purifier mode office
platform: state
entity_id: input_select.xiaomi_air_purifier_mode_office
data_template:
speed: '{{ states.input_select.xiaomi_air_purifier_mode_office.state }}'
- alias: Air purifier favorite level office
platform: state
entity_id: input_number.xiaomi_air_purifier_favorite_level_office
data_template:
level: '{{ states.input_number.xiaomi_air_purifier_favorite_level_office.state | int }}'
# Automatic control
value_template: "{{ states.fan.xiaomi_air_purifier_office.attributes.aqi | int }}"
below: 10
for:
minutes: 10
- condition: state
entity_id: 'fan.xiaomi_air_purifier_office'
state: 'on'
above: 10
for:
minutes: 10
- condition: state
state: 'off'
- service: fan.speed
speed: auto
- alias: Set favorite fan speed for air purifier office
platform: time
minutes: '/5'
seconds: 00
- condition: state
state: 'on'
speed: favorite
data_template:
level: >
{% if states.fan.xiaomi_air_purifier_office.attributes.aqi | int > 30 %}
15
{% elif states.fan.xiaomi_air_purifier_office.attributes.aqi | int > 25 %}
10
{% elif states.fan.xiaomi_air_purifier_office.attributes.aqi | int > 20 %}
5
{% elif states.fan.xiaomi_air_purifier_office.attributes.aqi | int > 15 %}
3
{% elif states.fan.xiaomi_air_purifier_office.attributes.aqi | int > 10 %}
1
0
- service: input_select.select_option
data_template:
data_template:
value: '{{ states.fan.xiaomi_air_purifier_office.attributes.favorite_level }}'
@artkrz thank you for sharing this… I’ve just used your code and it works perfect. thanks for sharing this and other for help having it working.
Do I need to change the name instead of office?
kouny
October 12, 2019, 1:00pm
10
Since I want to be able to force the purifier in ON or OFF state without touching Home Assistant, I defined the automations to work only when I leave the purifier (either on or off) in Auto mode. If I set it to Silent or Favorite the automations won’t do anything.
My goal was to have the Mi Air Purifier PRO turn on at a certain AQI value, turn off when the value drops below a threshold for at least some time, and to turn on the fan every two hours to move the air and hopefully get a more reliable AQI reading. I used Silent mode to avoid other automations to interfere. After that 10 minutes, the fan is switched back to Auto so that the other automations take over.
Checking the speed (Auto, silent, favorite) works only when the device is on, therefore I used the “mode” attribute that is retained and readable also when off.
Setting any speed automatically turns on the fan.
I used “state_attr()” and similar everywhere because this is the correct way to do it, not using “states.attributes.xxx”. See https://www.home-assistant.io/docs/configuration/templating/
Apparently using “numerical_state” avoids the need of casting into “int” the value of the attribute.
In configuration.yaml :
fan:
- platform: xiaomi_miio
name: "Air Purifier Living room"
host: 192.168.yyy.xxx
token: xxx
model: zhimi.airpurifier.v6
In automations.yaml :
# turn off only if below AQI value and in AUTO mode, not in silent or manual (favourite)
- alias: 'Auto off air purifier living room'
entity_id: 'fan.air_purifier_living_room'
value_template: "{{ state_attr('fan.air_purifier_living_room', 'aqi') }}"
below: 10
for:
minutes: 5
condition: and
conditions:
- condition: state
state: 'on'
value_template: "{{ is_state_attr('fan.air_purifier_living_room', 'mode', 'auto') }}"
# turn on if AQI above specified value and in AUTO mode last time
- alias: 'Auto on air purifier living room'
above: 16
condition: and
conditions:
- condition: state
state: 'off'
# turn on every two hours for some minutes to move air around, keep silent for that
- alias: 'Silent on air purifier living room'
platform: time_pattern
hours: "/2"
minutes: 0
condition: and
conditions:
- condition: state
state: 'off'
# turns on automatically when speed is changed
# - service: fan.turn_on
# entity_id: 'fan.air_purifier_living_room'
speed: 'Silent'
- delay: 0:10
speed: 'Auto'
kouny
October 12, 2019, 7:13pm
11
Actually the Purifier-auto-off automation is not reliable, sometimes it fires, usually not.
If I disable the “for 5 minutes” then it works fine.
Any idea? Since it’s a more generic question, I’m opening a different thread to keep this one about the automations and about debugging generic features of the automation.
artkrz
(Artur Krzywanski)
October 12, 2019, 8:07pm
12
I have no idea. I’m happy with my approach apart of the crap readings from the built in sensor. I’m adding SDS011 as triggers.
artkrz
(Artur Krzywanski)
December 3, 2019, 7:38pm
13
I have finally build new sensors based on sds011 and esp. Here’s new automation rules including 1st attempt on using pm10 as well as pm2.5. Works really nice but probably could be improved. Here’s a package for 2s in my office (requires pm2.5 and pm10 readings in mqtt sensor:
homeassistant:
customize:
sensor.air_purifier_office_aqi:
icon: mdi:weather-fog
sensor.air_purifier_office_humidity:
device_class: humidity
sensor.air_purifier_office_temerature:
device_class: temperature
sensor.air_purifier_office_mode:
icon: mdi:transition
sensor.air_purifier_office_favorite_level:
icon: mdi:weather-windy
fan:
host: 10.0.40.14
token: !secret xiaomi_air_purifier_office
name: Xiaomi Air Purifier Office
group:
air_purifier_office:
view: no
entities:
- fan.xiaomi_air_purifier_office
- input_select.xiaomi_air_purifier_mode_office
- sensor.air_purifier_office_mode
- input_number.xiaomi_air_purifier_favorite_level_office
- sensor.air_purifier_office_favorite_level
- sensor.air_purifier_office_aqi
- sensor.air_purifier_office_temperature
- sensor.air_purifier_office_humidity
automation_office:
view: no
icon: mdi:robot
entities:
- automation.set_favorite_fan_speed_for_air_purifier_office
- automation.set_state_for_air_purifier_office_favorite_level_input
- automation.set_state_for_air_purifier_office_mode_input
- automation.turn_off_air_purifier_office
- automation.turn_on_air_purifier_office
input_number:
xiaomi_air_purifier_favorite_level_office:
initial: 0
min: 0
max: 14
step: 1
input_select:
xiaomi_air_purifier_mode_office:
options:
- auto
- favorite
- silent
- idle
sensors:
value_template: '{{ states.fan.xiaomi_air_purifier_office.attributes.mode }}'
sensors:
value_template: '{{ states.fan.xiaomi_air_purifier_office.attributes.favorite_level }}'
sensors:
value_template: '{{ states.fan.xiaomi_air_purifier_office.attributes.aqi }}'
unit_of_measurement: "µg/m3"
sensors:
air_purifier_office_temperature:
value_template: '{{ states.fan.xiaomi_air_purifier_office.attributes.temperature }}'
unit_of_measurement: "°C"
sensors:
value_template: '{{ states.fan.xiaomi_air_purifier_office.attributes.humidity }}'
unit_of_measurement: "%"
sensors:
air_purifier_office_child_lock:
value_template: '{{ states.fan.xiaomi_air_purifier_office.attributes.child_lock }}'
sensors:
air_purifier_office_led:
value_template: '{{ states.fan.xiaomi_air_purifier_office.attributes.led }}'
sensors:
air_purifier_office_buzzer:
value_template: '{{ states.fan.xiaomi_air_purifier_office.attributes.buzzer }}'
switch:
switches:
air_purifier_child_lock_office:
friendly_name: "Blokada"
value_template: "{{ is_state('sensor.air_purifier_office_child_lock', 'True') }}"
turn_on:
service: fan.xiaomi_miio_set_child_lock_on
turn_off:
service: fan.xiaomi_miio_set_child_lock_off
icon_template: >-
{% if is_state('sensor.air_purifier_office_child_lock', 'True') %}
mdi:lock
mdi:lock-open
switches:
air_purifier_led_office:
friendly_name: "Led"
value_template: "{{ is_state('sensor.air_purifier_office_led', 'True') }}"
turn_on:
service: fan.xiaomi_miio_set_led_on
turn_off:
service: fan.xiaomi_miio_set_led_off
icon_template: >-
{% if is_state('sensor.air_purifier_office_led', 'True') %}
mdi:led-off
mdi:led-on
switches:
air_purifier_buzzer_office:
friendly_name: "Dzwięk"
value_template: "{{ is_state('sensor.air_purifier_office_buzzer', 'True') }}"
turn_on:
service: fan.xiaomi_miio_set_buzzer_on
turn_off:
service: fan.xiaomi_miio_set_buzzer_off
icon_template: >-
{% if is_state('sensor.air_purifier_office_buzzer', 'True') %}
mdi:volume-high
mdi:volume-mute
automation:
event: start
- platform: state
data_template:
event: start
- platform: state
data_template:
# Inputs
platform: state
data_template:
platform: state
data_template:
# Automatic control
entity_id: sensor.office_pm_2_5
value_template: "{{ states('sensor.office_pm_2_5') | int }}"
below: 5
for:
minutes: 10
- condition: state
state: 'on'
above: 5
for:
minutes: 5
- condition: state
state: 'off'
speed: auto
minutes: '/5'
seconds: 00
- condition: state
state: 'on'
speed: favorite
data_template:
level: >
{% if states('sensor.office_pm_2_5') | int > 30 or states('sensor.office_pm_10') | int > 50 %}
10
{% elif states('sensor.office_pm_2_5') | int > 20 or states('sensor.office_pm_10') | int > 40 %}
5
{% elif states('sensor.office_pm_2_5') | int > 10 or states('sensor.office_pm_10') | int > 20 %}
3
{% elif states('sensor.office_pm_2_5') | int > 5 or states('sensor.office_pm_10') | int > 10 %}
1
0
data_template:
data_template:
artkrz
(Artur Krzywanski)
December 18, 2019, 10:19pm
14
For anyone that runs into:
Service not found for call_service at pos 1: Unable to find service fan/xiaomi_miio_set_favorite_level
Just rename fan.xiaomi_miio_*
to xiaomi_miio.fan_*
and everything should be OK.
I coud not get the fan available after the 0.103 update (breaking change in xiaomi_miio). I cannot understand what I have to change… Am I wrong in something?
fan:
host: 192.168.0.xx
token: "xxxxxxxxxxxxxx"
model: zhimi.airpurifier.v2
artkrz
(Artur Krzywanski)
December 23, 2019, 11:43am
16
There is no need to change this. You only have to change service calls.
Neofitos
(sergey)
January 5, 2020, 9:37pm
17
Appaer more errors with Buzzer, Led, and Lock Child
namexless
(Namexless)
January 6, 2020, 5:44pm
18
Did anyone came into issue that automation for setting Air Purifier favorite level (speed) does not work unless it is triggered manually?
artkrz
(Artur Krzywanski)
January 13, 2020, 1:33pm
20
You sure you have all automations enabled?
namexless
(Namexless)
January 13, 2020, 2:26pm
21
100% sure. I resolved that issue by splitting it to separate automations for turning on/off and for setting speed based on aqi.
For turning on I use “for: minutes: 5” numeric_state trigger and for speed setting i use “minutes ‘/5’” time_pattern trigger. Code below.
Before that change I used only two automations – one for turning off and one for turning on & speed setting (numeric_state trigger with “for: minutes: 5”). Maybe I shouldn’t.
Automation code
# Xiaomi Air Purifier 2S – automation
- id: purifier_off
alias: 'Purifier Off'
initial_state: true
hide_entity: true
entity_id: fan.xiaomi_miio_device
value_template: '{{ state.attributes.aqi }}'
below: 5
for:
minutes: 5
- condition: state
state: 'on'
- id: purifier_on
alias: 'Purifier On'
initial_state: true
hide_entity: true
above: 5
for:
minutes: 3
- condition: state
state: 'off'
speed: Auto
### Purifier Auto
- id: purifier_auto
alias: 'Purifier Auto'
initial_state: true
minutes: '/5'
seconds: 00
- condition: state
entity_id: 'fan.xiaomi_miio_device'
state: 'on'
speed: Favorite
- service: xiaomi_miio.fan_set_favorite_level
data_template:
level: >
{% if state_attr('fan.xiaomi_miio_device', 'aqi') | int > 35 %}
14
{% elif state_attr('fan.xiaomi_miio_device', 'aqi') | int > 30 %}
10
{% elif state_attr('fan.xiaomi_miio_device', 'aqi') | int > 25 %}
7
{% elif state_attr('fan.xiaomi_miio_device', 'aqi') | int > 20 %}
4
{% elif state_attr('fan.xiaomi_miio_device', 'aqi') | int > 15 %}
2
{% elif state_attr('fan.xiaomi_miio_device', 'aqi') | int > 10 %}
1
0
