Airpurifier Automation
Hey guys,
I’m pretty new and actually have no clue what I’m doing here. Sound like a good start at least to me.
So I found a automation Script here and “edited” it to my liking (and use).
It looks like that now:
- alias: Set state for air purifier mode input
    - platform: homeassistant
      event: start
    - platform: state
      entity_id: sensor.xiaomi_miio_device
    - service: input_select.select_option
      data_template:
        entity_id: input_select.xiaomi_miio_device
        option: '{{ states.fan.xiaomi_miio_device.attributes.mode }}'
- alias: Set state for air purifier favorite level input
      event: start
    - platform: state
    - service: input_number.set_value
      data_template:
        entity_id: input_number.xiaomi_miio_device
        value: '{{ states.fan.xiaomi_miio_device.favorite_level | int }}'
# Inputs
- alias: Air purifier Mode
    platform: state
    - service: fan.set_speed
      data_template:
        entity_id: fan.xiaomi_miio_device
        speed: '{{ states.input_select.xiaomi_miio_device.state }}'
- alias: Air purifier User Mode
    platform: state
    - service: fan.xiaomi_miio_device_set_favorite_level
      data_template:
        level: '{{ states.input_number.xiaomi_miio_device.state | int }}'
# Automatic control
- alias: Air purifier ausschalten
    platform: numeric_state
    value_template: "{{ states.fan.xiaomi_miio_device.attributes.aqi | int }}"
    below: 20
    for: '00:03:00'
  condition:
    - condition: state
      entity_id: 'fan.xiaomi_miio_device'
      state: 'on'
    - service: fan.turn_off
- alias: Air purifier Nacht
    above: 100
    for: '00:03:00'
  condition:
    - condition: state
      state: 'on'
    - service: fan.turn_on
    - service: fan.speed
        speed: favorite
    above: 20
    for: '00:03:00'
  condition:
    - condition: state
      state: 'off'
        speed: silent
#- alias: Set favorite fan speed for air purifier
#  trigger:
#    platform: time_pattern
#    minutes: '/5'
#  condition:
#    - condition: state
#      entity_id: 'fan.xiaomi_miio_device'
#      state: 'on'
#  action:
#    - service: fan.set_speed
#      entity_id: fan.xiaomi_miio_device
#      data:
#        speed: favorite
#    - service: fan.xiaomi_miio_device_set_favorite_level
#      data_template:
#        level: >
#            {% if states.fan.xiaomi_miio_device.attributes.aqi | int > 30 %}
#              15
#            {% elif states.fan.xiaomi_miio_device.attributes.aqi | int > 25 %}
#              10
#            {% elif states.fan.xiaomi_miio_device.attributes.aqi | int > 20 %}
#              5
#            {% elif states.fan.xiaomi_miio_device.attributes.aqi | int > 15 %}
#              3
#            {% elif states.fan.xiaomi_miio_device.attributes.aqi | int > 10 %}
#              1
#            {% else %}
#              0
#            {% endif %}
#    - service: input_select.select_option
#      data_template:
#        entity_id: input_select.xiaomi_miio_device_mode_airpurifier
#        option: '{{ states.fan.xiaomi_miio_device.attributes.mode }}'
#    - service: input_number.set_value
#      data_template:
#        entity_id: input_number.xiaomi_miio_device_favorite_level_airpurifier
#        value: '{{ states.fan.xiaomi_miio_device.attributes.favorite_level }}'
But I get this error on startup (altough it looks like it is working anyway):
2019-05-27 18:52:47 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.set_state_for_air_purifier_mode_input. Service not found for call_service at pos 1: (ServiceNotFound(...), 'Service input_select.select_option not found')
I just wanna make sure I actually understand kinda what the definitions there are since I will need some more Automations… So is there anything wrong in my part?
My guess is that when the automation is triggered at startup, the input_select component hasn’t loaded yet. Therefore when the automation attempts to call the input_select.select_option service, it’s unavailable.
Examine the log to see the sequence of startup events. The order of the startup sequence will reveal if my guess has any merit.
Or he doesn’t have it defined at all, just add:
  xiaomi_miio_device:
    icon: mdi:flattr
    options:
     - auto
     - favorite
     - silent
     - idle
That would definitely cause the problem! :slight_smile:
Thanks for the answers.
I can check the log as soon the automation gets loaded again… I just destroyed everything. Seeing my other problem regarding “groups”.
I’m missing this definition at all I guess? But it is working though. I just don’t want to use the auto-mode at all, that’s why I commented the last part out completely.
I added it now and can test as soon as it works again. :slight_smile:
Btw. I got it fixed and it works just fine as of now. It looks like that now:
# Set input states when HA starts or states change
- alias: Set state for air purifier input
      event: start
    - platform: state
      entity_id: sensor.xiaomi_miio_device_mode
    data_template:
      event: start
    - platform: state
      entity_id: sensor.xiaomi_miio_device_favorite_level
    data_template:
      entity_id: input_number.air_purifier_favorite_level
      value: '{{ states.fan.xiaomi_miio_device.attributes.favorite_level | int }}'
# Inputs
- alias: Air purifier mode
    platform: state
    entity_id: input_select.xiaomi_air_purifier_mode
      data_template:
        speed: '{{ states.input_select.xiaomi_air_purifier_mode.state }}'
- alias: Air purifier favorite level
    platform: state
    entity_id: input_number.xiaomi_air_purifier_favorite_level
    - service: fan.xiaomi_miio_set_favorite_level
      data_template:
        level: '{{ states.input_number.xiaomi_air_purifier_favorite_level.state | int }}'
# Automatic control
- alias: Turn off airpurifier
    below: 30
    for: '00:01:00'
  condition:
    - condition: state
      state: 'on'
- alias: Set favorite fan speed for airpurifier
    minutes: '/1'
#  condition:
#      state: 'on'
        speed: favorite
      data_template:
        level: >
            {% if states.fan.xiaomi_miio_device.attributes.aqi | int == 600 %}
              12
            {% elif states.fan.xiaomi_miio_device.attributes.aqi | int > 400 %}
              10
            {% elif states.fan.xiaomi_miio_device.attributes.aqi | int > 300 %}
              8
            {% elif states.fan.xiaomi_miio_device.attributes.aqi | int > 150 %}
              6
            {% elif states.fan.xiaomi_miio_device.attributes.aqi | int > 100 %}
              4
            {% elif states.fan.xiaomi_miio_device.attributes.aqi | int > 30 %}
              2
            {% else %}
              0
            {% endif %}
      data_template:
      data_template:
cat input_select/airpurifier_mode.yaml
icon: mdi:flattr
options:
 - auto
 - favorite
 - silent
 - idle
Where exactly? :slight_smile:
