Hello everyone
I am trying to automate the colour temperature of my Sengeld bulbs in home assistant, but I cannot find it in my action items list. It is available in my dashboard and I can play with it manually (cf picture attached) but cannot control through automations. The light bulbs are connected through Zigbee protocol for which I use a Sonoff dongle on my HA mini-computer.
Again, I would really appreciate any pointers you may have!
In your automation use the Light: Turn on service. Once you choose your bulb there should be a section lower that says Color temperature. Check that and choose the temperature that you would like.
That is from the device not the Light: turn on service. When you add an action just type turn on and the light one should be the first choice.
These are the only options I have. For “turn on VA light” I can only choose the brightness for some reason. And I also try changing " Set value for sengled E21-N1EA Start-up color temperature" manually but it doesn’t do anything.
Not in the options. Delete that and when you click add actions.
![Screenshot 2024-06-10 164410](https://community-assets.home-assistant.io/original/4X/8/7/e/87ef940d188f61bdc1e565a5d7530bf80faf8ac9.png)
Choose Light: Turn on from there. Then choose which light from the entities.
![Screenshot 2024-06-10 164443](https://community-assets.home-assistant.io/original/4X/6/b/4/6b49fbaad377f7dcdb601870ca0425759a953104.png)
Thanks this is super helpful!!
