I think there might be an issue with the Ecobee integration. I’m trying to set my ecobee to “off” if the door is opened while the HVAC mode is set to “cool” but it’s not working.
I’ve managed to get the automation to trigger using the following YAML (I’m using the GUI actually):
the automation never fires. I’ve also tried using the “state” type as well:
condition: state
entity_id: climate.home
state: cool
and it STILL doesn’t fire. Though when I try a different device or state (a light for example) everything works as expected.
Is there an issue with the ecobee integration that I don’t know about or perhaps I should be using something other than “cool” for the state (even though that’s what is displayed in the states tool)?
Hm, I have a ton of things in Home Assistant, however I don’t use the “device” stuff, the services and states just work a lot better for me, especially when you switch things around
I hear you and I don’t mind using the “state” though I wish I could determine whether this is a bug or not and then makes the devs aware. Is there a way to see the state of a device?
Thank you both for this. For any other noobs having Ecobee and HA issues, here’s my YAML code for the automation. I set a group for all my door sensors. Tested and working! Obviously remember to change the timing. I left it short so you can test it faster!
alias: AC Door Trigger
description: >-
Turn off AC when doors are open. Turn back on AC when doors have been closed
for 5 minutes.
- platform: state
entity_id: binary_sensor.door_sensors
to: 'on'
for:
hours: 0
minutes: 0
seconds: 1
condition:
- condition: state
entity_id: climate.ecobee_thermostat
state: cool
- service: climate.turn_off
data: {}
- wait_for_trigger:
- platform: state
to: 'off'
for:
hours: 0
minutes: 0
seconds: 5
continue_on_timeout: true
- service: ecobee.resume_program
entity_id: climate.thermostat
mode: restart
