Well I think I’ve come a long way with this process. But, I’m stuck with a couple of issues I’m not sure how to get past.
I’m trying to figure out a way for the action to run when the thermostat goes from eco to none on the preset. I’m not finding an automation trigger for that.
I tried this and it didn’t do the trick so I assume it doesn’t exist?
The script below not following the condition to ensure that the thermostat is NOT in eco mode. So, it overrides eco mode when it executes. Not sure where I’m off here?
alias: HVAC temps Spring and Fall 0800 - 1945 to 75 and 70
- platform: time
at: "08:00:51"
- platform: device
device_id: 9c2059a1a21eb91033f498f8fcb0baab
domain: climate
entity_id: d99887dac1440f472ba4ccdddb91f776
type: hvac_mode_changed
to: heat_cool
condition:
- condition: time
before: "19:45:00"
after: "08:00:00"
- condition: device
domain: climate
type: is_preset_mode
preset_mode: none
- condition: or
conditions:
- condition: template
value_template: "{{ (4, 10) <= (now().month, now().day) <= (6, 9) }}"
value_template: "{{ (9, 16) <= (now().month, now().day) <= (11, 15) }}"
- condition: or
conditions:
- condition: zone
entity_id: device_tracker.pixel_7_pro_3
zone: zone.local_area
- condition: zone
zone: zone.home
- condition: zone
entity_id: device_tracker.g_pixel_7_pro
- condition: zone
zone: zone.home
- service: climate.set_hvac_mode
hvac_mode: heat_cool
area_id: entryway
- service: climate.set_temperature
target_temp_low: 70
target_temp_high: 75
area_id: entryway
Yeah that came from the UI automation tool. Just kept it as I went to YAML.
I’ll try that for issue #1.
Any thoughts on #2 where the condition to confirm preset isn’t working? Or is the theory here that the UI use of hex IDs causing it to fail to respect that condition?
Well none of this makes damn sense. The automation isn’t running now, it will detect a FALSE, and not continue. Great. But, each time I run the automation it somehow triggers Nest to changes from ECO to normal mode. It’s almost like just checking the condition makes Nest change.
Start by looking at the state of your climate.entryway in Developer Tools / States; and see if you can successfully change the preset_mode with Developer Tools / services.
Well I got super annoyed, pulled the power on the AC unit so the Nest would die off for a bit, rebooted the whole network and HomeAssistant host. It “seems” to be working now! I’m at a complete loss as to WTF but yeah.
Thanks so much for putting up with me @Troon throughout this annoyance.
Now to dream up more things to do with this automation to piss my wife off more.
