I have a camera, with an SD card that fills up in about 8 days.
It does not have a function to overwrite the oldest recordings, so if the SD card is full, it stops recording.
Every week, I manually need to erase the SD card via the WebGUI of the camera.
Is there a possibility to automate this in some way ?
To clear the SD card, I need to login to the camera, go to this settings page in a browser, and click on the link to format the SD card, a popup appears to ask if I am sure, and there I need to click on OK.
I looked around in HA docs, and found an integration called scrape.
Would it be possible to format the camera SD card using scrape ?
As I am not a web developer, I will need some help on how to do this.
In the browser, I saved the page to html, and found this.
<a href="" onclick="" style=""><script type="">document.write(str_sdfat32);</script>Format SD Card as fat32</a>
<a href="#" onclick="do_formatsd()" style="color:#6633FF"><script type="text/javascript">document.write(str_sdfat32);</script>Format SD Card as fat32</a>
#do_formatsd()color:#6633FFtext/javascript
and also found a js function that seems to do the formatting
`function do_formatsd()`
`var s = document.getElementById("form_submit");`
`if (confirm(str_ask_sdfat32) == true)`
`s.action = "cgi-bin/hi3510/sdfrmt.cgi";`
`s.submit();`
`else`
`return false;`
When I click on the format SD link, a popup appears to ask if I am sure, and if I then click OK, the camera formats the SD card.
I guess this is the command to format the SD card s.action = "cgi-bin/hi3510/sdfrmt.cgi";
I suppose the yaml config should look a bit like this, but as I am not familiar with html or javascript, I will need someone to help me to get this working correctly.
scrape:
- name: camera
- resource: (http://192.168.0.34/web/admin.html)
authentication: basic
username: ‘username’
password: password
method: post
payload: "cgi-bin/hi3510/sdfrmt.cgi"
scan_interval: 604800
