johanb7
(Johan)
April 24, 2020, 9:56am
1
Hi All,
I created the following Automation but the action (push) is still send even if the state is None:
alias: Send push if today is Restafval
description: ''
value_template: '{{ is_state(''sensor.afvalinfo_today'', ''restafval'') }}'
- at: '11:50'
platform: time
condition: []
- data:
message: Grijze container buitenzetten
title: Alert
service: notify.mobile_app_PHONE
I’ve also tried:
value_template: '"{% if is_state(''sensor.afvalinfo_today'', ''restafval'') %}true{%endif%}"'
But that isn’t working also.
Regards,
Johan
tom_l
April 24, 2020, 10:25am
2
value_template: "{{ is_state('sensor.afvalinfo_today', 'restafval') }}"
johanb7
(Johan)
April 24, 2020, 10:36am
3
changed to :
but still getting the push message
tom_l
April 24, 2020, 10:38am
4
What does this resolve to in the developer tools template editor:
Mutt
(Muttley)
April 24, 2020, 10:51am
6
Are you triggering this automation manually to test it by any chance ?
Your spacing is off, I count 3 spaces for some lines and 5 spaces for others (spacing should always be multiples of 2)
What about adding a condition (say) : -
condition:
- condition: template
value_template: "{{ states('sensor.afvalinfo_today') != 'none' }}"
I know that you specifically are triggering on == ‘restafval’
but the time trigger doesn’t
Mutt
(Muttley)
April 24, 2020, 10:52am
7
Binary sensors say false, how is that sensor constructed ?
johanb7
(Johan)
April 24, 2020, 10:58am
8
I just move the time and wait.
I’ll get the following error:
Error rendering template: TemplateSyntaxError: unexpected ‘%’
I think that time means check on the time if state is ‘restafval’ or am I incorrect?
Mutt
(Muttley)
April 24, 2020, 11:05am
9
sorry, corrected above, i cut and pasted a more complex condition, then simplified it but i made an error, corrected now.
post the yaml for the sensor
Your automation is triggering by time, not by the template.
Remove the time trigger, job done.
johanb7
(Johan)
April 24, 2020, 12:05pm
11
Seems to work when I change the state manually.
my interpretation of the time tigger is different that how it works
tom_l
April 24, 2020, 12:25pm
12
It’s a pretty simple trigger. At the time you specify it triggers. How did you think it worked?
